Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » Failing to update a model that is persisted in the DB [Teneo/Hibernate]
Failing to update a model that is persisted in the DB [Teneo/Hibernate] [message #118778] Thu, 17 April 2008 08:19 Go to next message
Originally posted by: felixostertag.web.de
hi,
i'm trying to implement saving/loading to/from database in a Eclipse EMF
project using Teneo/Hibernate.
saving/loading is also working somewhat fine (creates mapping, tables and
stuff quite fine), but once i've loaded something from the DB i can not
save it anymore.
creating new models and saving them works fine, also loading them from the
DB again is doing well. but i neither can save the same model twice, nor
can i load and then save the model again.
i'm quite new to this kind of stuff, so maybe it is (hopefully) just
because i'm plain stupid and don't see an obvious error.
I hope you can pin down my errors or maybe tell me where to look more
closely. thx for your patience :)
Hibernate version: 3.2.6
Name and version of the database: HSQLDB 1.8.0.9
exeptions that apear are:
Illegal attempt to associate a collection with two open sessions
if i load the model and save afterwards
and:
Don't change the reference to a collection with
cascade="all-delete-orphan"
if i try saving twice.
public static boolean doSaveToDB(String fileName, HbDataStore hbds)
   if (!session.isOpen())
      session = sessionFactory.openSession();
      session.setFlushMode(FlushMode.MANUAL);
      tx = session.getTransaction();
   tx.begin();
   try
session.saveOrUpdate(editingDomain.getResourceSet().getResources().get(0).getContents().get(0));
   } catch (HibernateException e)
      e.printStackTrace();
   session.flush();
   tx.commit();
   if (session.isOpen())
      session.clear();
      session.close();
   return true;
public static Modell loadExistingModellFromDB(String fileName, HbDataStore
hbds)
   URI resourceURI = URI.createURI("hbxml://?dsname=" + fileName);
   Modell model = null;
   tx.begin();
   try
      try
editingDomain.getResourceSet().getResources().get(0).load(Collections.EMPTY_MAP);
      } catch (IOException e)
      BigInteger fileID = new BigInteger(fileName);
      BigInteger ID = null;
      try
         for (int i = 0; !fileID.equals(ID) || (fileID.compareTo(ID) < 0)
; i++)
            editingDomain.getResourceSet().getResources().clear();
            editingDomain.getResourceSet().createResource(resourceURI);
            editingDomain.getResourceSet().getResource(resourceURI, true);
            model = (Modell)
editingDomain.getResourceSet().getResources().get(0).getContents().get(i);
            List models = session.createSQLQuery("SELECT E_ID FROM
\"modell\"").list();
            ID = (BigInteger) models.get(i);
      } catch (RuntimeException e)
         System.err.println("No entry found!");
   } catch (RuntimeException re)
      re.printStackTrace();
   session.flush();
   tx.commit();
      try
         session.clear();
         session.close();
         System.err.println("Session closing failed");
   return model;
public static HbDataStore initializeDataStore(String fileName)
   final HbDataStore hbds = (HbDataStore)
HbHelper.INSTANCE.createRegisterDataStore(fileName);
   final EPackage[] ePackages = new EPackage[] { EcupackPackage.eINSTANCE
   hbds.setEPackages(ePackages);
   final Properties props = new Properties(); // the database settings
   try
      props.setProperty(Environment.DRIVER, "org.hsqldb.jdbcDriver");
      props.setProperty(Environment.URL, "jdbc:hsqldb:hsql://127.0.0.1/" +
"ECUall");
      props.setProperty(Environment.USER, "sa");
      props.setProperty(Environment.PASS, "");
      props.setProperty(Environment.DIALECT,
"org.hibernate.dialect.HSQLDialect");
      props.setProperty(Environment.HBM2DDL_AUTO, "update");
      props.setProperty(Environment.CACHE_PROVIDER,
"org.hibernate.cache.HashtableCacheProvider");
      props.setProperty(Environment.AUTOCOMMIT, "false");
      hbds.setProperties(props);
   } catch (RuntimeException e1)
      e1.printStackTrace();
   try
      hbds.initialize();
   return hbds;
Re: Failing to update a model that is persisted in the DB [Teneo/Hibernate] [message #118791 is a reply to message #118778] Thu, 17 April 2008 08:22 Go to previous messageGo to next message
Hi Felix,
I will look at it but can you reformat the source code in your post a bit, with me (using
thunderbird) all the java code seems to be placed on one line.
gr. Martin
Felix wrote:
> hi, i'm trying to implement saving/loading to/from database in a Eclipse
> EMF project using Teneo/Hibernate. saving/loading is also working
> somewhat fine (creates mapping, tables and stuff quite fine), but once
> i've loaded something from the DB i can not save it anymore.
> the DB again is doing well. but i neither can save the same model twice,
> nor can i load and then save the model again.
> and:
> public static boolean doSaveToDB(String fileName, HbDataStore hbds) {
> if (!session.isOpen())   {      session = sessionFactory.openSession();
>      session.setFlushMode(FlushMode.MANUAL);      tx =
> session.getTransaction();   }   tx.begin();
>   try   {
>   } catch (HibernateException e)   {      e.printStackTrace();   }
> session.flush();   tx.commit();   if (session.isOpen())   {
> session.clear();      session.close();   }
>   return true; }
> HbDataStore hbds) {   if (!session.isOpen())   {      session =
> Modell model = null;   tx.begin();   try   {      try      {
>      } catch (IOException e)      {         e.printStackTrace();      }
>      BigInteger fileID = new BigInteger(fileName);      BigInteger ID =
> null;      try      {         for (int i = 0; !fileID.equals(ID) ||
> (fileID.compareTo(ID) < 0) ; i++)         {
>            model = (Modell)
> \"modell\"").list();            ID = (BigInteger) models.get(i);
> }      } catch (RuntimeException e)      {
> System.err.println("No entry found!");      }   } catch
> (HibernateException e)   {      e.printStackTrace();   } catch
> (RuntimeException re)   {      re.printStackTrace();   }
> session.flush();   tx.commit();   if (session.isOpen())   {      try
>      {         session.clear();         session.close();      } catch
> (HibernateException e)      {         System.err.println("Session
> closing failed");         e.printStackTrace();      }   }
>   return model; }
> public static HbDataStore initializeDataStore(String fileName) {   final
> HbHelper.INSTANCE.createRegisterDataStore(fileName);   final EPackage[]
> ePackages = new EPackage[] { EcupackPackage.eINSTANCE };
> hbds.setEPackages(ePackages);   final Properties props = new
> Properties(); // the database settings   try   {
> "ECUall");      props.setProperty(Environment.USER, "sa");
> hbds.setProperties(props);   } catch (RuntimeException e1)   {
> e1.printStackTrace();   }   try   {      hbds.initialize();   } catch
> (RuntimeException e)   {      e.printStackTrace();   }   return hbds; }
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: Failing to update a model that is persisted in the DB [Teneo/Hibernate] [message #118831 is a reply to message #118791] Thu, 17 April 2008 08:50 Go to previous messageGo to next message
oh, sorry. i've just copy/pasted it from another forum and didnt noticed.
here it comes again (hope its correct now)
(looks fine in the web interface, but if it's still reformating it
strangely, maybe you can have a look here:
http://forum.hibernate.org/viewtopic.php?t=985865
sorry, i never used newsreader before :) )
thx for your help!
tx.begin();
try
session.saveOrUpdate(editingDomain.getResourceSet().getResou rces().get(0).getContents().get(0));
session.flush();
tx.commit();
session.clear();
session.close();
return true;
hbds)
tx.begin();
try
try
editingDomain.getResourceSet().getResources().get(0).load(Co llections.EMPTY_MAP);
try
; i++)
model = (Modell)
editingDomain.getResourceSet().getResources().get(0).getCont ents().get(i);
session.flush();
tx.commit();
try
session.clear();
session.close();
return model;
try
"ECUall");
try
hbds.initialize();
return hbds;
Martin Taal wrote:
> Hi Felix,
with me (using
> gr. Martin
>> and:
>>   try   {
>>   return true; }
>>            model = (Modell)
>> "modell"").list();            ID = (BigInteger) models.get(i);
>>   return model; }
Re: Failing to update a model that is persisted in the DB [Teneo/Hibernate] [message #118857 is a reply to message #118778] Thu, 17 April 2008 09:15 Go to previous messageGo to next message
Hi Felix,
The resource you open using the resourceURI is a HibernateResource. A HibernateResource has its own
session (well not always see the link below...). When an object is loaded into the HibernateResource
from the db then the object (and its collections) are registered with the session of the resource
(this is done by hibernate). So when you try to persist the object from the resource using another
session then you get this exception.
If you want to read something from a resource and then save it using a separate hibernate session
you have to remove the object from the session of the resource. The HibernateResource has a
getSession() method on which you can call evict. However, it is much easier to either choose a
resource approach (load and save through a resource instance) or not use resources at all and work
with direct hql queries and the hibernate session (as you also do in your code).
Here is some more info on the hibernate resource:
http://www.elver.org/hibernate/hibernateresources.html
After a quick glance I would rewrite your for-loop a bit to:
Resource res = editingDomain.getResourceSet().createResource(resourceURI);
for (int i = 0; !fileID.equals(ID) || (fileID.compareTo(ID) < 0) ; i++)
model = (Modell)res.getContents().get(i);
List models = session.createSQLQuery("SELECT E_ID FROM \"modell\"").list();
Let me know if you have more questions.
gr. Martin
> and:
>   try   {
>   return true; }
>            model = (Modell)
>   return model; }
The Netherlands
Re: Failing to update a model that is persisted in the DB [Teneo/Hibernate] [message #118883 is a reply to message #118857] Thu, 17 April 2008 09:41 Go to previous messageGo to next message
thanks for your really fast answer!
i'll try it and hope i understood the problem finaly :)
Re: Failing to update a model that is persisted in the DB [Teneo/Hibernate] [message #119664 is a reply to message #118857] Wed, 23 April 2008 04:28 Go to previous messageGo to next message
hi again,
i now have implemented the save/load routines with the resource aproach
and its working fine... until i need locking mechanism :-/
so far i use:
Resource res = editingDomain.getResourceSet().getResources().get(0);
res.save(Collections.EMPTY_MAP);
to save and catch the IOException thrown by the res.save.
i tryed to let 2 clients load the same model and both modify it. the first
attempt to save is working fine, but the second one ends with some
exceptions:
org.hibernate.StaleObjectStateException: Row was updated or deleted by
another transaction (or unsaved-value mapping was incorrect): [...#4]
Exception in thread "main"
org.eclipse.emf.teneo.hibernate.HbMapperException: Exception when saving
resource 1
Caused by: org.hibernate.StaleObjectStateException: Row was updated or
deleted by another transaction (or unsaved-value mapping was incorrect):
[...#4]
i guess thats because of the automatic versioning hibernate does
(optimistic loading?), what is ok so far. the problem is that the resource
has neither a .merge() method nor are there unhandled exceptions where i
can handle what should happen when there are conflicts.
what i try to do is, i want to let multiple users load the model, but if
one changes the model the others should get a warning and have to save
with a different name.
is there a (simple ;) ) way to do this?
thx for your help
Re: Failing to update a model that is persisted in the DB [Teneo/Hibernate] [message #119690 is a reply to message #119664] Wed, 23 April 2008 07:30 Go to previous messageGo to next message
Hi Felix,
Teneo does not provide a server-client notification mechanism. The cdo project provides this. Within
the Teneo context I would try the following:
Before saving a resource get the modified eobjects (call: getModifiedEObjects), for each of the
objects read the version from the db (using a query which only reads the version column) and compare
it with the version in the object itself (or make a more efficient query in which you also use the
in-mem version). If the version in the object < than the db version then you know that it was
updated and that the user needs to be notified.
I did an extensive check if hibernate supports this functionality out of the box but it does not.
Btw, can you enter a bugzilla feature request for this so that I can add the above functionality to
the HibernateResource? I am not sure when I have time to do this but then it is on the list at least.
The above strategy works fine if the nr. of modified objects per save is fairly modest. If the
number of modified objects is huge then the only way is to use a client-server notification
mechanism (which is not part of Teneo).
gr. Martin
Felix wrote:
> hi again,
> so far i use:
> first attempt to save is working fine, but the second one ends with some
> exceptions:
> resource 1
> [...#4]
> resource has neither a .merge() method nor are there unhandled
> exceptions where i can handle what should happen when there are conflicts.
> thx for your help
The Netherlands
Re: Failing to update a model that is persisted in the DB [Teneo/Hibernate] [message #120108 is a reply to message #119690] Fri, 25 April 2008 10:38 Go to previous messageGo to next message
hi martin,
thx for your quick help!
but how can i use querys with the automaticaly created session from the
hibernate resource? can i somehow retrieve the active session from my
resource?
Martin Taal wrote:
> Hi Felix,
know that it was
> gr. Martin
> Felix wrote:
>> hi again,
>> so far i use:
>> exceptions:
>> resource 1
>> [...#4]
>> thx for your help
Re: Failing to update a model that is persisted in the DB [Teneo/Hibernate] [message #120178 is a reply to message #120108] Fri, 25 April 2008 14:15 Go to previous messageGo to next message
Hi Felix,
The hibernateresource has a getSession method and a getSessionWrapper method. The source code shows
how you can use the sessionwrapper (just a wrapper to make the hibernateresource also work with the
jpa entitymanager).
It is probably easiest to extend the HibernateResource and add the required behavior in the subclass.
gr. Martin
Felix wrote:
> hi martin,
> resource?
> Martin Taal wrote:
>> Hi Felix,
>> query in
>> then you
> know that it was
>> of the
>> add the
>> then it
>> gr. Martin
>> Felix wrote:
>>> hi again,
>>> aproach and its working fine... until i need locking mechanism :-/
>>> so far i use:
>>> some exceptions:
>>> by another transaction (or unsaved-value mapping was incorrect): [...#4]
>>> saving resource 1
>>> or deleted by another transaction (or unsaved-value mapping was
>>> incorrect): [...#4]
>>> conflicts.
>>> if one changes the model the others should get a warning and have to
>>> save with a different name.
>>> thx for your help
The Netherlands
Re: Failing to update a model that is persisted in the DB [Teneo/Hibernate] [message #121855 is a reply to message #120178] Mon, 05 May 2008 12:52 Go to previous messageGo to next message
hi again,
still digging up more questions after solving a problem ;)
is there a easy way to delete a whole model from the DB? when i use the
delete method from the session, it just deletes the "root table" and
leaving the rest of the model as data corpses in the database.
sc.getSessionWrapper().delete(tempRes.getContents().get(0));
thats the code i yet tried.
thx a lot
felix
Re: Failing to update a model that is persisted in the DB [Teneo/Hibernate] [message #121880 is a reply to message #121855] Mon, 05 May 2008 13:23 Go to previous message
Hi Felix,
Normally if you delete the root which contains all other data then it should also delete all its
children (and their children). So I am not sure if you have everything contained in the root and/or
that the containment relations are mapped with delete cascade and orphan-delete. You can check the
hibernate mapping for that.
gr. Martin
Felix wrote:
> hi again,
> thx a lot
> felix
The Netherlands
Re: Failing to update a model that is persisted in the DB [Teneo/Hibernate] [message #617811 is a reply to message #118778] Thu, 17 April 2008 08:22 Go to previous message
Hi Felix,
gr. Martin
> and:
>   try   {
>   return true; }
>            model = (Modell)
>   return model; }
The Netherlands
Re: Failing to update a model that is persisted in the DB [Teneo/Hibernate] [message #617821 is a reply to message #118791] Thu, 17 April 2008 08:50 Go to previous message
thx for your help!
tx.begin();
try
session.flush();
tx.commit();
session.clear();
session.close();
return true;
hbds)
tx.begin();
try
try
try
; i++)
model = (Modell)
session.flush();
tx.commit();
try
session.clear();
session.close();
return model;
try
"ECUall");
try
hbds.initialize();
return hbds;
Martin Taal wrote:
> Hi Felix,
with me (using
> gr. Martin
>> and:
>>   try   {
>>   return true; }
>>            model = (Modell)
>>   return model; }
Re: Failing to update a model that is persisted in the DB [Teneo/Hibernate] [message #617823 is a reply to message #118778] Thu, 17 April 2008 09:15 Go to previous message
Hi Felix,
gr. Martin
> and:
>   try   {
>   return true; }
>            model = (Modell)
>   return model; }
The Netherlands
Re: Failing to update a model that is persisted in the DB [Teneo/Hibernate] [message #617825 is a reply to message #118857] Thu, 17 April 2008 09:41 Go to previous message
Re: Failing to update a model that is persisted in the DB [Teneo/Hibernate] [message #617885 is a reply to message #118857] Wed, 23 April 2008 04:28 Go to previous message
hi again,
so far i use:
exceptions:
resource 1
[...#4]
thx for your help
Re: Failing to update a model that is persisted in the DB [Teneo/Hibernate] [message #617887 is a reply to message #119664] Wed, 23 April 2008 07:30 Go to previous message
Hi Felix,
gr. Martin
Felix wrote:
> hi again,
> so far i use:
> exceptions:
> resource 1
> [...#4]
> thx for your help
The Netherlands
Re: Failing to update a model that is persisted in the DB [Teneo/Hibernate] [message #617915 is a reply to message #119690] Fri, 25 April 2008 10:38 Go to previous message
hi martin,
resource?
Martin Taal wrote:
> Hi Felix,
know that it was
> gr. Martin
> Felix wrote:
>> hi again,
>> so far i use:
>> exceptions:
>> resource 1
>> [...#4]
>> thx for your help
Re: Failing to update a model that is persisted in the DB [Teneo/Hibernate] [message #617920 is a reply to message #120108] Fri, 25 April 2008 14:15 Go to previous message
Hi Felix,
jpa entitymanager).
gr. Martin
Felix wrote:
> hi martin,
> resource?
> Martin Taal wrote:
>> Hi Felix,
>> query in
>> then you
> know that it was
>> of the
>> add the
>> then it
>> gr. Martin
>> Felix wrote:
>>> hi again,
>>> so far i use:
>>> some exceptions:
>>> saving resource 1
>>> incorrect): [...#4]
>>> conflicts.
>>> thx for your help
The Netherlands
Re: Failing to update a model that is persisted in the DB [Teneo/Hibernate] [message #617992 is a reply to message #120178] Mon, 05 May 2008 12:52 Go to previous message
hi again,
thx a lot
felix
Re: Failing to update a model that is persisted in the DB [Teneo/Hibernate] [message #617994 is a reply to message #121855] Mon, 05 May 2008 13:23 Go to previous message
Hi Felix,
gr. Martin
Felix wrote:
> hi again,
> thx a lot
> felix
The Netherlands
Previous Topic:Implementation Package Location
Next Topic:[Teneo] hibernate3.jar dependencies
Current Time: Tue Oct 07 09:54:57 EDT 2025
Powered by FUDForum. Page generated in 0.46487 seconds
