Home » Eclipse Projects » GEF » connections leading to nowhere
connections leading to nowhere [message #119240] Tue, 24 February 2004 10:39 Go to next message
Originally posted by: nospam.gmx.net
Hello Group,
I have 2 nodes, connected with a wire.
One of these nodes is within a container.
When i downsize the container that way, that the the node within
gets out of the bounds of the container, the node disappears. - thats ok.
But the connection leads into nowhere, exactly there where the node is
supposed to be...
I know of the seperate connection layer and that this topic is sure
problematic,
but is there a way or are there plans to avoid this - i mean, that the
connection leads "into" the container and ends at the containers bounds?
I
  • Attachment: example.gif
    (Size: 3.29KB, Downloaded 118 times)
Re: connections leading to nowhere [message #119320 is a reply to message #119240] Tue, 24 February 2004 13:49 Go to previous messageGo to next message
This is what the logic example does, and we borrowed this "laziness" from
VA-Java's composition editor.
If your application really has connections which go across or are within
containers, there are ways of handling this for your specific editor.
"Ingo Koch" <nospam@gmx.net> wrote in message
news:c1fr1l$gk4$1@eclipse.org...
> Hello Group,
> supposed to be...
> problematic,
> I
Re: connections leading to nowhere [message #119574 is a reply to message #119320] Thu, 26 February 2004 09:28 Go to previous messageGo to next message
Well, the screenshot was from the logic editor and my application
behaves the same way.
What would you suggest to do to handle this problem?
Regards, Ingo
> > Hello Group,
ok.
> > supposed to be...
> > problematic,
> > I
Re: connections leading to nowhere [message #119598 is a reply to message #119574] Thu, 26 February 2004 09:45 Go to previous message
I have no idea what the user would expect in this situation. Some clients
are clipping the anchor to the node's parent.
news:c1kvjh$26v$1@eclipse.org...
> Regards, Ingo
> > > Hello Group,
> ok.
> > > supposed to be...
> > > problematic,
bounds?
> > > I
Previous Topic:Is it ok for command to show dialogs?
Next Topic:Installing with Update Manager?
Current Time: Fri Oct 31 03:05:21 EDT 2025
Powered by FUDForum. Page generated in 0.03240 seconds
