Home » Newcomers » Newcomers » PyDev Install to Eclipse on Mac(Correctly installed but nit shown in Preferences)
icon5.gif  PyDev Install to Eclipse on Mac [message #1176482] Fri, 08 November 2013 06:05 Go to next message
Hi there,
I'm new to the Eclipse IDE as well as Python development and encountered a problem while trying to install the PyDev IDE to Eclipse.
I did exactly as shown and explained in the Guides on the PyDev website, but after eclipse restarted I do not hab the PyDev entry in the list of Preferences.
I then checked again into "Install New Software ...", where PyDev was shown as already installed.
Afterwards I uninstalled PyDev via the "Installation Details" in the "About" Dialog and reinstalled it now using the "Eclipse Marketplace". After that I checked it there and it said that it was installed (I could only uninstall or update it). But in the Preferences I still have no entry with PyDev. Even if I use the search-Bar above the Preferences list it cannot find PyDev.
I hope you have any Ideas.
Here are some information about the software I use:
Eclispe 4.3.1 vor Mac 64Bit
PyDev for Eclipse 3.0.0.201311051910
iMac 27'' Late 2012 Intel i7 3,4 GHz running OS X 10.9 (13A603)
Re: PyDev Install to Eclipse on Mac [message #1178500 is a reply to message #1176482] Sat, 09 November 2013 13:02 Go to previous messageGo to next message
I have the same problem that Daniel has, but in my case the platform is Debian/Linux 7.2 (wheezy) amd64, and the Eclipse version is 3.8.0.
Do you have any suggestion? Sad
Thanks.
Re: PyDev Install to Eclipse on Mac [message #1195180 is a reply to message #1176482] Mon, 18 November 2013 17:08 Go to previous messageGo to next message
Make sure you have Java 7 installed , see post below
http://pydev.blogspot.com/2013/11/pydev-30.html
[Updated on: Wed, 08 January 2014 13:07] by Moderator
Re: PyDev Install to Eclipse on Mac [message #1227819 is a reply to message #1195180] Sun, 05 January 2014 13:06 Go to previous messageGo to next message
I installed Java 7. still no pydev in preferences...
Re: PyDev Install to Eclipse on Mac [message #1229081 is a reply to message #1227819] Wed, 08 January 2014 12:17 Go to previous message
Hi all,
I stalled java 7 and it fixed. I executed:
apt-get install openjdk-7-jre
But that not was enough, because java 6 is still installed. You must to check if your system is runing java 6 or 7. For then execute:
java -version
My output was:
java version "1.6.0_27"
Then you must to update your alternates. How? Using update-alternates. Just run that:
 update-alternatives --config java
When I executed, the output was:
* 0            /usr/lib/jvm/java-6-openjdk-amd64/jre/bin/java   1061      modo automático
  1            /usr/lib/jvm/java-6-openjdk-amd64/jre/bin/java   1061      modo manual
  2            /usr/lib/jvm/java-7-openjdk-amd64/jre/bin/java   1051      modo manual
Just select the number of java-7-openjdk-amd64, in my case was 2.
Try that buddy.
Previous Topic:Eclipse crashes after few minutes
Next Topic:Issue starting Tomcat on Eclipse
Current Time: Mon Jul 21 00:12:24 EDT 2025
Powered by FUDForum. Page generated in 0.09314 seconds
