Home » Eclipse Projects » EclipseLink » javax.naming.NoInitialContextException with DatabaseSession
javax.naming.NoInitialContextException with DatabaseSession [message #1191914] Sun, 17 November 2013 04:12 Go to next message
I have an app based rcp Indigo, using Eclipselink 2.5.0 standalone (without ejb server). When I start my app there is a javax.naming.NonInitialContextException thrown, thought my app starts sucessfully. Just because I want to understand what's the problem I ask here. I do not know about ejb. What can I do not to get this exception anymore? It comes since I have changed from EL 2.3.2 to 2.5.0.
<code>
[EL Finest]: jpa: 2013-11-17 10:00:32.58--ServerSession(7052492)--Thread(Thread[Start Level Event Dispatcher,5,main])--javax.naming.NoInitialContextException: Need to specify class name in environment or system property, or as an applet parameter, or in an application resource file: java.naming.factory.initial
at javax.naming.spi.NamingManager.getInitialContext(Unknown Source)
at javax.naming.InitialContext.getDefaultInitCtx(Unknown Source)
at javax.naming.InitialContext.getURLOrDefaultInitCtx(Unknown Source)
at javax.naming.InitialContext.lookup(Unknown Source)
at org.eclipse.persistence.internal.sessions.cdi.EntityListenerInjectionManagerImpl.<init>(EntityListenerInjectionManagerImpl.java:45)
at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method)
at sun.reflect.NativeConstructorAccessorImpl.newInstance(Unknown Source)
at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(Unknown Source)
at java.lang.reflect.Constructor.newInstance(Unknown Source)
at java.lang.Class.newInstance(Unknown Source)
at org.eclipse.persistence.internal.sessions.AbstractSession.createEntityListenerInjectionManager(AbstractSession.java:1143)
at org.eclipse.persistence.internal.sessions.AbstractSession.getEntityListenerInjectionManager(AbstractSession.java:2232)
at org.eclipse.persistence.internal.jpa.metadata.listeners.EntityListener.createEntityListenerAndInjectDependancies(EntityListener.java:137)
at org.eclipse.persistence.internal.jpa.metadata.listeners.EntityListener.constructListenerInstance(EntityListener.java:151)
at org.eclipse.persistence.internal.jpa.metadata.listeners.EntityListener.getListener(EntityListener.java:234)
at org.eclipse.persistence.internal.jpa.metadata.listeners.EntityListener.invokeMethod(EntityListener.java:350)
at org.eclipse.persistence.internal.jpa.metadata.listeners.EntityListener.postClone(EntityListener.java:414)
at org.eclipse.persistence.descriptors.DescriptorEventManager.notifyListener(DescriptorEventManager.java:730)
at org.eclipse.persistence.descriptors.DescriptorEventManager.notifyEJB30Listeners(DescriptorEventManager.java:674)
at org.eclipse.persistence.descriptors.DescriptorEventManager.executeEvent(DescriptorEventManager.java:229)
at org.eclipse.persistence.internal.sessions.AbstractSession.executeDeferredEvents(AbstractSession.java:1447)
at org.eclipse.persistence.internal.sessions.UnitOfWorkImpl.cloneAndRegisterObject(UnitOfWorkImpl.java:1046)
at org.eclipse.persistence.internal.descriptors.ObjectBuilder.buildWorkingCopyCloneNormally(ObjectBuilder.java:793)
at org.eclipse.persistence.internal.descriptors.ObjectBuilder.buildObjectInUnitOfWork(ObjectBuilder.java:730)
at org.eclipse.persistence.internal.descriptors.ObjectBuilder.buildObject(ObjectBuilder.java:629)
at org.eclipse.persistence.internal.descriptors.ObjectBuilder.buildObject(ObjectBuilder.java:587)
at org.eclipse.persistence.internal.descriptors.ObjectBuilder.buildObject(ObjectBuilder.java:571)
at org.eclipse.persistence.queries.ObjectLevelReadQuery.buildObject(ObjectLevelReadQuery.java:782)
at org.eclipse.persistence.queries.ReadObjectQuery.registerResultInUnitOfWork(ReadObjectQuery.java:861)
at org.eclipse.persistence.queries.ReadObjectQuery.executeObjectLevelReadQuery(ReadObjectQuery.java:532)
at org.eclipse.persistence.queries.ObjectLevelReadQuery.executeDatabaseQuery(ObjectLevelReadQuery.java:1155)
at org.eclipse.persistence.queries.DatabaseQuery.execute(DatabaseQuery.java:899)
at org.eclipse.persistence.queries.ObjectLevelReadQuery.execute(ObjectLevelReadQuery.java:1114)
at org.eclipse.persistence.queries.ReadObjectQuery.execute(ReadObjectQuery.java:429)
at org.eclipse.persistence.queries.ObjectLevelReadQuery.executeInUnitOfWork(ObjectLevelReadQuery.java:1202)
at org.eclipse.persistence.internal.sessions.UnitOfWorkImpl.internalExecuteQuery(UnitOfWorkImpl.java:2894)
at org.eclipse.persistence.internal.sessions.AbstractSession.executeQuery(AbstractSession.java:1797)
at org.eclipse.persistence.internal.sessions.AbstractSession.executeQuery(AbstractSession.java:1779)
at org.eclipse.persistence.internal.sessions.AbstractSession.executeQuery(AbstractSession.java:1730)
at org.eclipse.persistence.internal.jpa.EntityManagerImpl.executeQuery(EntityManagerImpl.java:883)
at org.eclipse.persistence.internal.jpa.EntityManagerImpl.findInternal(EntityManagerImpl.java:826)
at org.eclipse.persistence.internal.jpa.EntityManagerImpl.find(EntityManagerImpl.java:719)
at org.eclipse.persistence.internal.jpa.EntityManagerImpl.find(EntityManagerImpl.java:588)
at ch.eugster.colibri.persistence.queries.AbstractQuery.find(AbstractQuery.java:61)
at ch.eugster.colibri.persistence.queries.CommonSettingsQuery.findDefault(CommonSettingsQuery.java:13)
at ch.eugster.colibri.persistence.connection.service.AbstractConnectionService.connect(AbstractConnectionService.java:389)
at ch.eugster.colibri.persistence.connection.service.AbstractConnectionService.createEntityManager(AbstractConnectionService.java:372)
at ch.eugster.colibri.persistence.connection.service.AbstractConnectionService.getEntityManager(AbstractConnectionService.java:714)
at ch.eugster.colibri.persistence.queries.AbstractQuery.select(AbstractQuery.java:253)
at ch.eugster.colibri.persistence.queries.AbstractQuery.select(AbstractQuery.java:243)
at ch.eugster.colibri.persistence.queries.AbstractQuery.select(AbstractQuery.java:219)
at ch.eugster.colibri.persistence.queries.ProviderPropertyQuery.selectByProviderAndSalespoint(ProviderPropertyQuery.java:36)
at ch.eugster.colibri.persistence.queries.ProviderPropertyQuery.selectByProvider(ProviderPropertyQuery.java:17)
at ch.eugster.colibri.scheduler.UpdateSchedulerComponent.activate(UpdateSchedulerComponent.java:112)
at org.eclipse.equinox.internal.ds.model.ServiceComponent.activate(ServiceComponent.java:227)
at org.eclipse.equinox.internal.ds.model.ServiceComponentProp.activate(ServiceComponentProp.java:146)
at org.eclipse.equinox.internal.ds.model.ServiceComponentProp.build(ServiceComponentProp.java:346)
at org.eclipse.equinox.internal.ds.InstanceProcess.buildComponent(InstanceProcess.java:588)
at org.eclipse.equinox.internal.ds.InstanceProcess.buildComponents(InstanceProcess.java:196)
at org.eclipse.equinox.internal.ds.Resolver.getEligible(Resolver.java:328)
at org.eclipse.equinox.internal.ds.SCRManager.serviceChanged(SCRManager.java:221)
at org.eclipse.osgi.internal.serviceregistry.FilteredServiceListener.serviceChanged(FilteredServiceListener.java:104)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.dispatchEvent(BundleContextImpl.java:861)
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)
at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148)
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEventPrivileged(ServiceRegistry.java:819)
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEvent(ServiceRegistry.java:771)
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistrationImpl.register(ServiceRegistrationImpl.java:130)
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.registerService(ServiceRegistry.java:214)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.registerService(BundleContextImpl.java:433)
at org.eclipse.equinox.internal.ds.InstanceProcess.registerService(InstanceProcess.java:504)
at org.eclipse.equinox.internal.ds.InstanceProcess.buildComponents(InstanceProcess.java:212)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.registerService(BundleContextImpl.java:451)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.registerService(BundleContextImpl.java:950)
at ch.eugster.colibri.persistence.connection.Activator.startPersistenceService(Activator.java:332)
at ch.eugster.colibri.persistence.connection.Activator.start(Activator.java:298)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl$1.run(BundleContextImpl.java:711)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.startActivator(BundleContextImpl.java:702)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.start(BundleContextImpl.java:683)
at org.eclipse.osgi.framework.internal.core.BundleHost.startWorker(BundleHost.java:381)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.resume(AbstractBundle.java:389)
at org.eclipse.osgi.framework.internal.core.Framework.resumeBundle(Framework.java:1131)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.resumeBundles(StartLevelManager.java:559)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.resumeBundles(StartLevelManager.java:544)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.incFWSL(StartLevelManager.java:457)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.doSetStartLevel(StartLevelManager.java:243)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.dispatchEvent(StartLevelManager.java:438)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.dispatchEvent(StartLevelManager.java:1)
at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:340)
</code>
Re: javax.naming.NoInitialContextException with DatabaseSession [message #1194345 is a reply to message #1191914] Mon, 18 November 2013 08:14 Go to previous message
Injection for Entity listeners was added between 2.3->2.5. This is logged at finest to indicate that CDI for entity listeners cannot occur due to the exception (you are not in a container where it could be used anyway), and can be ignored.
Previous Topic:TableGenerator - Sequence/ID Generation
Next Topic:EclipseLink 2.5 JPA + MONGODB and ORDER BY
Current Time: Sat Jul 26 18:56:15 EDT 2025
Powered by FUDForum. Page generated in 0.05061 seconds
