Home » Eclipse Projects » Virgo » Help about Install Virgo Snaps
Help about Install Virgo Snaps [message #1190750] Sat, 16 November 2013 14:35 Go to next message
Here is my problem:when i tried to start the virgo server 3.6.2.RELEASE it bumps out
[2013-11-17 03:03:57.763] startup-tracker <KE0001I> Kernel starting.
[2013-11-17 03:03:59.464] startup-tracker <KE0002I> Kernel started.
[2013-11-17 03:03:59.470] system-artifacts <DE0700E> Cannot find plan 'org.eclipse.virgo.kernel.userregion.springdm' version range '[0.0.0, oo)' in repository 'stage-ext-usr'.
[2013-11-17 03:03:59.472] system-artifacts <UR0002E> User region failed while deploying initial artifacts. Shutting down.
[2013-11-17 03:03:59.474] System Bundle Shutdown <KE0010I> Shutdown initiated.
I refer http://www.eclipse.org/virgo/documentation/virgo-documentation-3.6.2.RELEASE/docs/snaps-guide/htmlsingle/virgo-snaps-guide.html
my envirnment is jdk "1.6.0_31" 64bit, win7 64bit. Does anyone have ever encountered this ?Please help.Thanks very much~~
Re: Help about Install Virgo Snaps [message #1200583 is a reply to message #1190750] Thu, 21 November 2013 05:02 Go to previous message
which deliverable of Virgo are you using? Virgo Server for Apache Tomcat?
florian
Previous Topic:emf.ecore.resource.ResourceSet.getResource takes more time in VIRGO
Next Topic:Update Server config (VM Arguments)
Current Time: Fri Jul 25 22:10:52 EDT 2025
Powered by FUDForum. Page generated in 0.03595 seconds
