Home » Archived » Visual Editor (VE) » VE doesn't like: new Display() - new Shell(Display)
VE doesn't like: new Display() - new Shell(Display) [message #118996] Mon, 27 February 2006 07:02 Go to next message
Originally posted by: ras_nas.yahoo.com
Hello Everyone,
My most important question is: how do I package a bean into a jar to
run as a stand-alone program when the Visual Class generated doesn't
have a main() and adding one manually seems to make it unable to be run
on Eclipse? Is the createSShell() method generated recognized as a main()
entry point equivalent somehow?
I'm no seasoned developer in the GUI world, so please bear with me
here because I couldn't find much about this in the FAQ.
When in Eclipse I clicked my way through from New->Visual Class,
the skeleton class generated with a createSShell() didn't include the
following:
Display display = new Display();
Shell sShell = new Shell(display);
sShell.open();
while (!sShell.isDisposed())
if (!display.readAndDispatch())
display.sleep();
display.dispose();
If I add the new Shell(display);
Visual Editor announces NullPointerException on trying to display
the window; and if I use the loop block, upon closing the window VE
has this to say:
IWAV0056I Java Bean com.socius.invensys.EmailSenderUI started with the
createSShell method
Exception in thread "main" org.eclipse.swt.SWTException: Widget is disposed
at org.eclipse.swt.SWT.error(SWT.java:2942)
at org.eclipse.swt.widgets.Widget.error(Widget.java:395)
at org.eclipse.swt.widgets.Widget.getDisplay(Widget.java:505)
at
org.eclipse.ve.internal.java.vce.launcher.remotevm.SWTLaunch er.runEventLoop(
SWTLauncher.java:486)
at
org.eclipse.ve.internal.java.vce.launcher.remotevm.SWTLaunch er.runShell(SWTL
auncher.java:469)
at
org.eclipse.ve.internal.java.vce.launcher.remotevm.SWTLaunch er.launch(SWTLau
ncher.java:181)
at
org.eclipse.ve.internal.java.vce.launcher.remotevm.JavaBeans Launcher.main(Ja
vaBeansLauncher.java:77)
I thought the above construct was a strength of SWT for not hiding the event
loop from me?
Why do such errors occur on VE? What about the skeleton generated using only
"new Shell()"
instead of "new Shell(Display)", in the latter case throwing NPE w/o a stack
trace?
Rico.
Re: VE doesn't like: new Display() - new Shell(Display) [message #119034 is a reply to message #118996] Mon, 27 February 2006 10:03 Go to previous messageGo to next message
Please attach the entire file. That way we can see what the interactions
are.
Rich Kulp
Re: VE doesn't like: new Display() - new Shell(Display) [message #119071 is a reply to message #118996] Mon, 27 February 2006 12:00 Go to previous messageGo to next message
If you check the create public static void main() option in the New
Visual Class wizard, you'll get a main method generated that supports
running your new visual class.
- Jeff
Re: VE doesn't like: new Display() - new Shell(Display) [message #119179 is a reply to message #119071] Tue, 28 February 2006 02:28 Go to previous messageGo to next message
"Jeff Myers" <jeff.myers@eclipse.org> wrote in message
news:dtvb9j$sp1$1@utils.eclipse.org...
> - Jeff
All right. That's cool. Thanks Jeff.
Now.. Things seem to be working fine within Eclipse.
But I need to deploy the application..
So far I've used David Weiss's convenient Invoker.jar to
take care of whatever classpath and jars required.
For SWT.. is it just a matter of dropping the
org.eclipse.swt.win32.win32.x86_3.1.1.jar in the same folder as
the jar for my application?
Doesn't look like it.. What's this thing about -Djava.library.path=C:\SWT ?
Is that referring to some time when the swt dll's were not part
of the jar that seems to be all Eclipse needs to include for things to
work: org.eclipse.swt.win32.win32.x86_3.1.1.jar ?
Or do I need to do something more than placing the latter jar on
the classpath for SWT to work?
Thanks.
Rico.
Re: VE doesn't like: new Display() - new Shell(Display) [message #119191 is a reply to message #119071] Tue, 28 February 2006 02:42 Go to previous messageGo to next message
> - Jeff
Doesn't look like it.. What's this thing about -Djava.library.path=<some
path to dlls> ?
I've tried copying org.eclipse.swt_3.1.0.jar in as well.. no good.
Thanks.
Rico.
Re: VE doesn't like: new Display() - new Shell(Display) [message #119265 is a reply to message #119191] Tue, 28 February 2006 10:34 Go to previous messageGo to next message
Yes, Eclipse has changed how SWT is deployed since then. See the
download page for the Eclipse 3.2M5 download and scroll down to the SWT
Binary and Source section. It has a paragraph there on how to deploy an
SWT app.
>> - Jeff
> path to dlls> ?
> Thanks.
> Rico.
Rich Kulp
Re: VE doesn't like: new Display() - new Shell(Display) [message #119456 is a reply to message #119265] Tue, 28 February 2006 22:22 Go to previous message
"Rich Kulp" <richkulp@us.NO_SPAM.ibm.com> wrote in message
news:du1qhe$vmj$3@utils.eclipse.org...
> SWT app.
Okay. I've used the method described there and finally it's working.
There was a comment in the auto-generated main() of the visual class:
* Before this is run, be sure to set up the launch configuration
* (Arguments->VM Arguments) for the correct SWT library path in order
* to run with the SWT dlls. The dlls are located in the SWT plugin jar.
* For example, on Windows the Eclipse SWT 3.1 plugin jar is:
* installation_directory\plugins\org.eclipse.swt.win32_3.1.0.j ar
To run from Eclipse, I didn't really need the above.. but.. Eclipse seems
to be able to access the dll's from the SWT plugin jar. How does it do this
if having that jar on the classpath is not all it takes?
where do I get to know more about things like java.library.path and how to
identify cases where I am supposed to call onto them?
Rico.
> > path to dlls> ?
> > Thanks.
> > Rico.
> Rich Kulp
Re: VE doesn't like: new Display() - new Shell(Display) [message #612189 is a reply to message #118996] Mon, 27 February 2006 10:03 Go to previous message
are.
Rich Kulp
Re: VE doesn't like: new Display() - new Shell(Display) [message #612192 is a reply to message #118996] Mon, 27 February 2006 12:00 Go to previous message
- Jeff
Re: VE doesn't like: new Display() - new Shell(Display) [message #612201 is a reply to message #119071] Tue, 28 February 2006 02:28 Go to previous message
> - Jeff
Thanks.
Rico.
Re: VE doesn't like: new Display() - new Shell(Display) [message #612202 is a reply to message #119071] Tue, 28 February 2006 02:42 Go to previous message
> - Jeff
path to dlls> ?
Thanks.
Rico.
Re: VE doesn't like: new Display() - new Shell(Display) [message #612208 is a reply to message #119191] Tue, 28 February 2006 10:34 Go to previous message
SWT app.
>> - Jeff
> path to dlls> ?
> Thanks.
> Rico.
Rich Kulp
Re: VE doesn't like: new Display() - new Shell(Display) [message #612223 is a reply to message #119265] Tue, 28 February 2006 22:22 Go to previous message
> SWT app.
Rico.
> > path to dlls> ?
> > Thanks.
> > Rico.
> Rich Kulp
Previous Topic:VE performace
Next Topic:Does the VE have any relations to the NAB (eWideStudio) ?
Current Time: Fri Jul 18 21:03:57 EDT 2025
Powered by FUDForum. Page generated in 0.08333 seconds
