Deploying sample.http.war.feature [message #118229] |
Mon, 29 September 2008 09:53  |
I'm running through the instructions on "Equinox in a Servlet Container"
found at http://www.eclipse.org/equinox/server/http_in_container.php and I'm
trying to deploy the sample-http example referenced on that page. I have
been able to build and deploy the bridge.war example successfully, but I
seem to be missing some pieces on how to use that example to apply it to
sample-http. I've noticed a few other posts in the past that indicate
similar problems, but I didn't find any that clearly described a sample-http
war's relationship to the servlet bridge. Does anyone have a modified
sample-http project and war.feature that successfully deploys it? I've been
trying to use these instructions along with those found at
http://rapblog.innoopract.com/2007/12/rap-deployment-part-2- deploying-your.html
to no avail.
Any help would be much appreciated,
Scott
Re: Deploying sample.http.war.feature [message #118786 is a reply to message #118607] |
Wed, 01 October 2008 11:46  |
With some help from a co-worker I've been able to fix the two projects
sample.http and sample.http.war.feature so I can generate a WAR file. To
try it out, import these projects, right-click on
sample.http/scripts/webappBuilder.xml and select "Run As > Ant Build" from
the context menu.
Scott
> This is what I have done so far. Maybe someone could point out a flaw in
> how I'm approaching the problem. I've got the attached ant script in
> sample.http/scripts/webappBuilder.xml and the attached feature.xml in a
> separate sample.http.war.feature.
>> I'm
>> sample-http
>> been
>> to no avail.
>> Scott
[Updated on: Thu, 15 January 2015 13:50] by Moderator
FUDForum. Page generated in 0.07866 seconds
