Axis-NullPoint problem [message #118601] |
Fri, 08 July 2005 14:23  |
Originally posted by: luc_jn.yahoo.com
I have 1.0M5 installed, when I try to create webService I get the
following error.
IWAB0489E Error when deploying Web service to Axis runtime
As far as I understand this is because of Axis version, has anybody solved
it ?
or how can I write to axis forum I have tried but I am keeping getting my
mail back.
thanks I am getting desperated.
Re: Axis-NullPoint problem [message #120597 is a reply to message #118613] |
Wed, 13 July 2005 19:29  |
How does one install the plug-in described in this bug report?
Here is what I did:
1. Download and extract the zip
2. Rename "Copy of org.apache.axis12" to "org.apache.axis12"
3. Move the directory to the plugins directory in eclipse.
This is where I am unsure what to do next. One clue in the bug report says,
The dependency of following plugins need to change:
org.apache.wsil4j
org.eclipse.jst.ws.axis.consumption.core
org.eclipse.jst.ws.axis.consumption.ui
org.eclipse.wst.ws.explorer
org.eclipse.wst.ws.parser
org.eclipse.wst.wsi
org.uddi4j
But I'm not quite sure what that means. I went and changed "axis11" to
"axis12" in the various xml files in these directories, but not all of them
even mention the term axis. I went back, and eclipse still was using Axis
1.1 and still gave the same issue. Does anybody know what do here?
Is there any step else to follow?
It's quite unfortunate this bug is not targeted until 1.0M6. It seems like
being able to create a web service e in Java 5.0 is a pretty standard thing
to do. However, in eclipse, it can't be done.
-Chao.
Dave
"Luis Montes" <monteslu@rockfordcorp.com> wrote in message
news:pan.2005.07.08.18.45.15.160294@rockfordcorp.com...
> This may be relevant:
> https://bugs.eclipse.org/bugs/show_bug.cgi?id=98340
> Not sure when axis 1.2.1 will used.
>> following error.
>> java.lang.NullPointerException
>> solved
>> it ?
>> mail back.
FUDForum. Page generated in 0.04047 seconds
