Home » Eclipse Projects » EGit / JGit » maven multi module error: Unable to ignore resources Attempted to beginRule: xxx does not match oute
maven multi module error: Unable to ignore resources Attempted to beginRule: xxx does not match oute [message #1072278] Mon, 22 July 2013 08:51 Go to next message
team,
i have seen the following error on both juno and kepler when trying to create a multi module maven project.
'Auto share git projects' has encountered a problem
Attempted to beginRule: F/automation-utils/modile1, does not match outer scope rule: MultiRule[P/module1]
i can get around it by disabling
<window><preferences><tesm><git><projects><auto share projects located in a git repository>
and
<window><preferences><tesm><git><projects><Automatically ignore derived resources by adding them to .gitignore>
but cannot seem to narrow down exactly what egit is unhappy about...anyone else seen this, and know what the issue is?
many thanks,
mike
Re: maven multi module error: Unable to ignore resources Attempted to beginRule: xxx does not match [message #1075839 is a reply to message #1072278] Tue, 30 July 2013 03:11 Go to previous messageGo to next message
same here. Thanks for the tip
Re: maven multi module error: Unable to ignore resources Attempted to beginRule: xxx does not match [message #1086748 is a reply to message #1072278] Wed, 14 August 2013 13:10 Go to previous messageGo to next message
Thanks for the tip, I don't have the notification every 15 seconds.
It's not a complete solution, I can't ignore some resources due to the same error. Anyone is working on the bug?
It's really annoying
Best
Re: maven multi module error: Unable to ignore resources Attempted to beginRule: xxx does not match [message #1086753 is a reply to message #1086748] Wed, 14 August 2013 13:15 Go to previous messageGo to next message
For information, I have also Aptana studio plugin, do you have it Ilya and Michael?
Re: maven multi module error: Unable to ignore resources Attempted to beginRule: xxx does not match [message #1087437 is a reply to message #1086753] Thu, 15 August 2013 12:31 Go to previous messageGo to next message
Same problem here. Anyone filed an issue yet?
Re: maven multi module error: Unable to ignore resources Attempted to beginRule: xxx does not match [message #1094996 is a reply to message #1072278] Mon, 26 August 2013 09:47 Go to previous messageGo to next message
The same happens here. Even disabling the git preferences, I'm still having the error every time I try to add a resource to .gitignore file
Re: maven multi module error: Unable to ignore resources Attempted to beginRule: xxx does not match [message #1094997 is a reply to message #1072278] Mon, 26 August 2013 09:48 Go to previous messageGo to next message
Re: maven multi module error: Unable to ignore resources Attempted to beginRule: xxx does not match [message #1102790 is a reply to message #1094997] Fri, 06 September 2013 00:30 Go to previous messageGo to next message
Looks to me like this has been fixed in 3.0.2 I hope?
d4e6dda - 2013-08-23, Robin Stocker : Fix scheduling rule error when ignoring resources in nested projects
Re: maven multi module error: Unable to ignore resources Attempted to beginRule: xxx does not match [message #1185739 is a reply to message #1072278] Thu, 14 November 2013 03:29 Go to previous messageGo to next message
Another workaround:
Error appeared in Maven project. I have added "target" folder in gitignore outside Eclipse (in TortoiseGit), and error disappeared.
Re: maven multi module error: Unable to ignore resources Attempted to beginRule: xxx does not match [message #1186391 is a reply to message #1102790] Thu, 14 November 2013 12:29 Go to previous message
This is fixed in 3.0.3
Previous Topic:checkout arbitrary commit with JGit
Next Topic:Feature request: menu option for "git status"
Current Time: Sun Jul 27 07:49:39 EDT 2025
Powered by FUDForum. Page generated in 0.19168 seconds
