Home » Modeling » TMF (Xtext) » Scoping and inferring inner classes
Scoping and inferring inner classes [message #1184685] Wed, 13 November 2013 11:19 Go to next message
I have a grammar that is based on XBase.
An if-statment like
if(condition) {
  println(1)
else {
  println(2)
(with println just being an example for arbitrary expressions) should be inferred to something like:
MyIf.run(condition,
  new Runnable() {
    public void run() {
      println(1);
  new Runnable() {
    public void run() {
      println(2);
I have achieved this by customizing XBaseCompiler._toJavaStatement(XIfExpression, ...)
This of-course only works as long as no fields are used inside one of the then- or else-branch.
E.g.
if(...) {
  println(this.a)
else {
  this.a = 1
How could I make this working?
What would be the best way to generate the inner classes correctly?
I suspect, I would have to customize the scopeprovider for the branches. Any other ideas?
Many thanks,
Matthias
Re: Scoping and inferring inner classes [message #1184914 is a reply to message #1184685] Wed, 13 November 2013 14:42 Go to previous messageGo to next message
just a 5 mins try
grammar org.xtext.example.mydsl3.MyDsl with org.eclipse.xtext.xbase.Xbase
generate myDsl "http://www.xtext.org/example/mydsl3/MyDsl"
import "http://www.eclipse.org/xtext/xbase/Xbase" as xbase
Model:
	body=MyXBlockExpression;
MyXBlockExpression returns xbase::XExpression:
	{xbase::XBlockExpression}
		(expressions+=MyXIfExpression ';'?)
MyXIfExpression returns xbase::XExpression:
	{xbase::XIfExpression}
	'if' '(' if=XExpression ')'
	then=XClosureX
	(=>'else' else=XClosureX)?;
XClosureX returns xbase::XExpression:
	{xbase::XClosure}
	explicitSyntax?="{"expression=XExpressionInClosure"}";
class MyDslJvmModelInferrer extends AbstractModelInferrer {
	@Inject extension JvmTypesBuilder
   	def dispatch void infer(Model element, IJvmDeclaredTypeAcceptor acceptor, boolean isPreIndexingPhase) {
   		acceptor.accept(element.toClass("my.company.greeting.MyGreetings"))
   			.initializeLater([
   					members += element.toMethod("doSomething", element.newTypeRef(Runnable)) [
   						body = element.body
Re: Scoping and inferring inner classes [message #1186292 is a reply to message #1184685] Thu, 14 November 2013 11:04 Go to previous message
Thanks a lot.
That was pointing me to the right direction.
I have basically adopted your proposed grammar.
I have modified the TypeComputer so that the expected type for the closures that are children of the if-expression is Runnable.
In the XbaseCompiler, I first call _toJavaStatement for the two closures and generate the appropriate code that passes them to the call to MyIf.run(...).
Thanks again!
Matthias
Previous Topic:Thanks for the help!!!!
Next Topic:Compiling Xassignment to FeatureCall
Current Time: Mon Jul 21 12:17:03 EDT 2025
Powered by FUDForum. Page generated in 0.12971 seconds
