Home » Eclipse Projects » Remote Application Platform (RAP) » Running an application using workspace RWT plugins
Running an application using workspace RWT plugins [message #117976] |
Fri, 09 January 2009 10:21  |
I was wondering if anyone could tell me if/how it is possible to run a RAP
application in eclipse using the RAP plugins checked out from CVS head
into your workspace. I have it working using all of the plugins except
rwt and the q07 fragment. I want my run target to use all of the RAP
plugins that I have in the workspace. But right now the only way I can do
that is to export the rwt and fragment to my target platform and rebuild.
When I run with all the workspace RAP plugins included in my run target, I
get this error:
javax.servlet.ServletException: Failed to load Browser Survey HTML Page
(Reason: Failed to load Browser Survey HTML Page. Resource
org/eclipse/rwt/internal/service/rwt-index.html could not be found.)
at
org.eclipse.rwt.internal.service.BrowserSurvey.sendBrowserSu rvey(BrowserSurvey.java:56)
at
org.eclipse.rwt.internal.service.LifeCycleServiceHandler.int ernalService(LifeCycleServiceHandler.java:197)
at
org.eclipse.rwt.internal.service.LifeCycleServiceHandler.acc ess$1(LifeCycleServiceHandler.java:185)
at
org.eclipse.rwt.internal.service.LifeCycleServiceHandler$Lif eCycleServiceHandlerSync.doService(LifeCycleServiceHandler.j ava:150)
at
org.eclipse.rwt.internal.lifecycle.RWTLifeCycleServiceHandle rSync.serviceInternal(RWTLifeCycleServiceHandlerSync.java:46 )
at
org.eclipse.rwt.internal.lifecycle.RWTLifeCycleServiceHandle rSync.service(RWTLifeCycleServiceHandlerSync.java:34)
at
org.eclipse.rwt.internal.service.LifeCycleServiceHandler.ser vice(LifeCycleServiceHandler.java:157)
at
org.eclipse.rwt.internal.service.ServiceManager$HandlerDispa tcher.service(ServiceManager.java:101)
at org.eclipse.rwt.internal.engine.RWTDelegate.doPost(RWTDelega te.java:63)
at
org.eclipse.ui.internal.servlet.RequestHandler.service(Reque stHandler.java:51)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:689)
at
org.eclipse.equinox.http.servlet.internal.ServletRegistratio n.handleRequest(ServletRegistration.java:90)
at
org.eclipse.equinox.http.servlet.internal.ProxyServlet.proce ssAlias(ProxyServlet.java:111)
at
org.eclipse.equinox.http.servlet.internal.ProxyServlet.servi ce(ProxyServlet.java:59)
at
org.eclipse.equinox.http.jetty.internal.HttpServerManager$In ternalHttpServiceServlet.service(HttpServerManager.java:269)
at org.mortbay.jetty.servlet.ServletHolder.handle(ServletHolder .java:428)
at
org.mortbay.jetty.servlet.ServletHandler.dispatch(ServletHan dler.java:677)
at
org.mortbay.jetty.servlet.ServletHandler.handle(ServletHandl er.java:568)
at org.mortbay.http.HttpContext.handle(HttpContext.java:1530)
at org.mortbay.http.HttpContext.handle(HttpContext.java:1482)
at org.mortbay.http.HttpServer.service(HttpServer.java:909)
at org.mortbay.http.HttpConnection.service(HttpConnection.java: 820)
at org.mortbay.http.HttpConnection.handleNext(HttpConnection.ja va:986)
at org.mortbay.http.HttpConnection.handle(HttpConnection.java:8 37)
at
org.mortbay.http.SocketListener.handleConnection(SocketListe ner.java:245)
at org.mortbay.util.ThreadedServer.handle(ThreadedServer.java:3 57)
at org.mortbay.util.ThreadPool$PoolThread.run(ThreadPool.java:5 34)
Any thoughts?
Thanks.
Re: Running an application using workspace RWT plugins [message #118083 is a reply to message #118073] |
Fri, 09 January 2009 15:21   |
Target_bundles:
org.eclipse.core.contenttype@default:default,
org.eclipse.equinox.http.jetty@default:default,
org.eclipse.rap.demo.databinding@default:default,
org.eclipse.equinox.http.servlet@default:default,
org.eclipse.equinox.common@default:default,
org.eclipse.equinox.app@default:default,
org.eclipse.equinox.preferences@default:default,
org.eclipse.core.jobs@default:default,
org.eclipse.core.databinding.beans@default:default,
org.eclipse.core.databinding@default:default,
org.eclipse.equinox.http.registry@default:default,
org.eclipse.equinox.registry@default:default,
com.ibm.icu@default:default,
org.eclipse.rap.source@default:default,
org.eclipse.core.commands@default:default,
org.eclipse.osgi.services@default:default,
org.apache.commons.logging@default:default,
javax.servlet@default:default,
org.mortbay.jetty@default:default,
org.eclipse.osgi@default:default,
org.eclipse.core.runtime@default:default,
org.eclipse.core.expressions@default:default
Workspace_bundles:
Bug_Demo@default:default,
org.eclipse.rap.rwt@default:default,
org.eclipse.rap.jface.databinding@default:default,
org.eclipse.rap.jface@default:default,
org.eclipse.rap.ui.views@default:default,
org.eclipse.rap.rwt.q07@default:false,
org.eclipse.rap.ui@default:default,
org.eclipse.rap.ui.forms@default:default,
org.eclipse.rap.ui.workbench@default:default
Re: Running an application using workspace RWT plugins [message #118094 is a reply to message #118083] |
Fri, 09 January 2009 15:41   |
There are 2 bundles that you don't need in target section:
If you get an error message again after deselecting them, please type
the command "ss" in the osgi console and post the result here.
Best,
Ivan
Austin Riddle wrote:
> Target_bundles:
> Workspace_bundles:
Current Time: Wed Sep 17 19:57:42 EDT 2025
Powered by FUDForum. Page generated in 0.07346 seconds
