Home » Eclipse Projects » GEF » position/size of rectangle
position/size of rectangle [message #117558] Fri, 13 February 2004 06:09 Go to next message
Originally posted by: nospam.gmx.net
Hello Guys!
Simple question:
i have little problem with a feedback rectangle, shown on add request.
the rectangle paints, but when i have a zoom level != 1.00
the rectangle paints in the position and in the size as if zoom level was
1.00.
feedback = new RectangleFigure();
Rectangle r = getHostFigure().getBounds().getCopy().getExpanded(5,5);
feedback.setBounds(r);
addFeedback(feedback);
So how do i use translateToAbsolute / translateToRelative to fix this?
Regards, Ingo
Re: position/size of rectangle [message #117578 is a reply to message #117558] Fri, 13 February 2004 10:40 Go to previous messageGo to next message
Take a look at NonResizableEditPolicy -> showChangeBoundsFeedback.
"Ingo Koch" <nospam@gmx.net> wrote in message
news:c0ib38$anb$1@eclipse.org...
> Hello Guys!
> Simple question:
> 1.00.
> Regards, Ingo
Re: position/size of rectangle [message #118007 is a reply to message #117578] Tue, 17 February 2004 09:22 Go to previous messageGo to next message
"Whitney Sorenson" <none@us.ibm.com> wrote in message
news:c0iqt5$vih$1@eclipse.org...
I had a look a look at it.
what i want is rectangle with the same size (or a little bigger) of the
target figure resting over the target figure.
what i have:
feedback = getFeedbackRectangle();
Rectangle r = getHostFigure().getBounds().getCopy();
getHostFigure().translateToAbsolute(r);
The size is ok now.
But not the position, when the editor is scrolled to the right.
And another (i admit, stupid, but simple) question :
why can
Re: position/size of rectangle [message #118057 is a reply to message #118007] Tue, 17 February 2004 10:41 Go to previous messageGo to next message
news:c0t7uf$khf$1@eclipse.org...
> what i have:
need to call:
feedback.translateToRelative(r);
> why can
Re: position/size of rectangle [message #118236 is a reply to message #118057] Wed, 18 February 2004 04:08 Go to previous messageGo to next message
Works fine now but only, when the feedback is added first,
then the rectangle gets transleted and the bounds are set.
The problem was, that at the time before the feedback is added,
it has no parent and the rectangle can
Re: position/size of rectangle [message #118372 is a reply to message #118236] Wed, 18 February 2004 14:47 Go to previous message
Yes, if the feedback is not on the feedback layer, then it will not work.
What happens is both the primary and feedback layer are shifted upwards.
So, when you translate from the original figure, you are shifting the point
one way. When yo utranslate back to the feedback, it un-shifts the point.
Previous Topic:pop up dialog
Next Topic:Actions & multi page editor
Current Time: Sat Jul 26 10:18:13 EDT 2025
Powered by FUDForum. Page generated in 0.28471 seconds
