Home » Eclipse Projects » Eclipse 4 » Part on top of a PartSashContainer
Part on top of a PartSashContainer [message #1181871] Mon, 11 November 2013 17:21 Go to next message
Hi all,
I've the following configuration in my Application.e4xmi:
+-------- Trimmed Window
  +------ Controls
    +---- Perspective Stack
      +-- Controls
        + Part
        + PartSashContainer
The Part gets rendered always left besides PartSash Container (I think it's of org.eclipse.e4.ui.workbench.renderers.swt.ContributedPartRenderer#createWidget, where the composite is created with new FillLayout(SWT.VERTICAL)). How can I achieve that the Part is rendered on top of PartSashContainer?
Thanks in advance,
Ralf.
Re: Part on top of a PartSashContainer [message #1182537 is a reply to message #1181871] Tue, 12 November 2013 03:52 Go to previous messageGo to next message
On 11.11.13 23:21, Ralf Heydenreich wrote:
> Hi all,
> +------ Controls
> +-- Controls
> + Part
> + PartSashContainer
> it's of
> Thanks in advance,
> Ralf.
Make it look like:
Controls
+ PartSashContainer (vertical)
+ Part
+ PartSashContainer
Tom
Re: Part on top of a PartSashContainer [message #1182781 is a reply to message #1182537] Tue, 12 November 2013 07:08 Go to previous messageGo to next message
This works, but I want to fix the divider. Like this:
|C|O|O|L|B|A|R  |
+---------------+  <-- this divider shouldn't be moveable!
| Application   |
| area          |
I can't use the trimmed toolbar, because I didn't found a possibility to put larger icons on it with text beneath.
How can I get this?
Ralf.
Re: Part on top of a PartSashContainer [message #1182806 is a reply to message #1182781] Tue, 12 November 2013 07:26 Go to previous messageGo to next message
This is not supported by the e4 SWT implementation. You'd have to create
a custom PartSashRenderer.
The JavaFX renderer support this but well they are for FX ;-)
Tom
> |C|O|O|L|B|A|R |
> | Application | | area |
> put larger icons on it with text beneath. How can I get this?
> Ralf.
Re: Part on top of a PartSashContainer [message #1182812 is a reply to message #1181871] Tue, 12 November 2013 07:33 Go to previous messageGo to next message
Just add ToolControl instead of ToolBar as contents of your window's Top TrimBar.
You create contents of ToolControl like you do for MPart - with @PostConstruct annotated method in class contribution. That's where you can create yout custom CoolBar widget.
Re: Part on top of a PartSashContainer [message #1182835 is a reply to message #1182812] Tue, 12 November 2013 07:51 Go to previous messageGo to next message
.... but then he has no Toolbar ;-)
Tom
> TrimBar.
Re: Part on top of a PartSashContainer [message #1182855 is a reply to message #1182835] Tue, 12 November 2013 08:10 Go to previous messageGo to next message
Sure, but I thought he gave up on toolbar already anyway. With items being of wrong size or something.
Re: Part on top of a PartSashContainer [message #1183419 is a reply to message #1182812] Tue, 12 November 2013 16:22 Go to previous message
Am 12.11.2013 13:33, schrieb Andrzej Szczepanski:
> TrimBar.
Hi Andrzej,
this was exactly what I'd looked for. Works perfectly. Thanks!
Ralf.
Previous Topic:DI Injection for Handlers
Next Topic:perspective bar
Current Time: Mon Jul 21 07:51:36 EDT 2025
Powered by FUDForum. Page generated in 0.06204 seconds
