Home » Eclipse Projects » Eclipse 4 » Invalid Thread Access in MenuManagerRenderer.contextDisposed
Invalid Thread Access in MenuManagerRenderer.contextDisposed [message #1182436] Tue, 12 November 2013 02:25 Go to next message
Hi, when I close my RCP application I get an invalid thread access:
org.eclipse.e4.core.di.InjectionException: org.eclipse.swt.SWTException: Invalid thread access
	at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:63)
	at org.eclipse.e4.core.internal.di.InjectorImpl.processAnnotated(InjectorImpl.java:877)
	at org.eclipse.e4.core.internal.di.InjectorImpl.disposed(InjectorImpl.java:386)
	at org.eclipse.e4.core.internal.di.Requestor.disposed(Requestor.java:132)
	at org.eclipse.e4.core.internal.contexts.ContextObjectSupplier$ContextInjectionListener.update(ContextObjectSupplier.java:76)
	at org.eclipse.e4.core.internal.contexts.TrackableComputationExt.update(TrackableComputationExt.java:107)
	at org.eclipse.e4.core.internal.contexts.TrackableComputationExt.handleInvalid(TrackableComputationExt.java:70)
	at org.eclipse.e4.core.internal.contexts.EclipseContext.dispose(EclipseContext.java:171)
	at org.eclipse.e4.core.internal.contexts.EclipseContext.dispose(EclipseContext.java:160)
	at org.eclipse.e4.core.internal.contexts.osgi.EclipseContextOSGi.dispose(EclipseContextOSGi.java:100)
	at org.eclipse.e4.core.internal.contexts.osgi.EclipseContextOSGi.bundleChanged(EclipseContextOSGi.java:131)
	at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:892)
	at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)
	at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148)
	at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEventPrivileged(EquinoxEventPublisher.java:165)
	at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:75)
	at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:67)
	at org.eclipse.osgi.internal.framework.EquinoxContainerAdaptor.publishModuleEvent(EquinoxContainerAdaptor.java:87)
	at org.eclipse.osgi.container.Module.publishEvent(Module.java:454)
	at org.eclipse.osgi.container.Module.doStop(Module.java:609)
	at org.eclipse.osgi.container.Module.stop(Module.java:476)
	at org.eclipse.osgi.container.SystemModule.stop(SystemModule.java:165)
	at org.eclipse.osgi.internal.framework.EquinoxBundle$EquinoxSystemModule$1.run(EquinoxBundle.java:216)
	at java.lang.Thread.run(Thread.java:722)
Caused by: org.eclipse.swt.SWTException: Invalid thread access
org.eclipse.swt.SWT.error(SWT.java:4419)
org.eclipse.swt.SWT.error(SWT.java:4334)
org.eclipse.swt.SWT.error(SWT.java:4305)
org.eclipse.swt.widgets.Display.error(Display.java:1257)
org.eclipse.swt.widgets.Display.checkDevice(Display.java:763)
org.eclipse.swt.widgets.Display.removeFilter(Display.java:4062)
org.eclipse.e4.ui.workbench.renderers.swt.MenuManagerRenderer.contextDisposed(MenuManagerRenderer.java:254)
sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
java.lang.reflect.Method.invoke(Method.java:601)
org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:56)
org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:902)
org.eclipse.osgi.internal.framework.EquinoxContainerAdaptor.publishModuleEvent(EquinoxContainerAdaptor.java:89)
org.eclipse.osgi.container.Module.publishEvent(Module.java:456)
org.eclipse.osgi.container.Module.doStop(Module.java:611)
org.eclipse.osgi.container.Module.stop(Module.java:478)
org.eclipse.osgi.container.SystemModule.stop(SystemModule.java:169)
org.eclipse.osgi.internal.framework.EquinoxBundle$SystemBundle$EquinoxSystemModule$1.run(EquinoxBundle.java:158)
I looked at org.eclipse.e4.ui.workbench.renderers.swt.MenuManagerRenderer.contextDisposed():
	@PreDestroy
	public void contextDisposed() {
		eventBroker.unsubscribe(itemUpdater);
		eventBroker.unsubscribe(selectionUpdater);
		eventBroker.unsubscribe(enabledUpdater);
		eventBroker.unsubscribe(toBeRenderedUpdater);
		ContextInjectionFactory.uninject(MenuManagerEventHelper.showHelper,
				context);
		MenuManagerEventHelper.showHelper = null;
		ContextInjectionFactory.uninject(MenuManagerEventHelper.hideHelper,
				context);
		MenuManagerEventHelper.hideHelper = null;
		context.remove(MenuManagerRendererFilter.class);
		Display display = context.get(Display.class);
		if (display != null && !display.isDisposed() && rendererFilter != null) {
			display.removeFilter(SWT.Show, rendererFilter);
			display.removeFilter(SWT.Hide, rendererFilter);
			display.removeFilter(SWT.Dispose, rendererFilter);
		if (rendererFilter != null) {
			ContextInjectionFactory.uninject(rendererFilter, context);
			rendererFilter = null;
		context.remove(MenuManagerRenderer.class);
and the problem occurs in the line
Can you guys help me find a solution?
Thank you very much,
Matthias
Re: Invalid Thread Access in MenuManagerRenderer.contextDisposed [message #1182543 is a reply to message #1182436] Tue, 12 November 2013 03:58 Go to previous messageGo to next message
So when does it happen? It looks like the framework is going down and
then it disposes context on a none-ui thread.
To me this looks like a bug in EclipseContextOSGi.bundleChanged which
should make sure the disposal done on the UI-Thread - problem might be
at this level we don't have such an information because we are in the core.
Tom
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> I looked at
> @PreDestroy
> context);
> context);
> != null) {
> Matthias
Re: Invalid Thread Access in MenuManagerRenderer.contextDisposed [message #1182555 is a reply to message #1182543] Tue, 12 November 2013 04:06 Go to previous messageGo to next message
Hi Tom,
thanks for your answer. It happens when I close my RCP application.
Matthias
Re: Invalid Thread Access in MenuManagerRenderer.contextDisposed [message #1182556 is a reply to message #1182555] Tue, 12 November 2013 04:08 Go to previous messageGo to next message
Is there anything special about the closing? When the Bundle is brought
down the context should have been disposed already :-(
Tom
On 12.11.13 10:06, Matthias Nick wrote:
> Hi Tom,
> Matthias
Re: Invalid Thread Access in MenuManagerRenderer.contextDisposed [message #1183921 is a reply to message #1182556] Wed, 13 November 2013 00:28 Go to previous messageGo to next message
Execute your UI related code in :
 Display.getDefault().syncExec(
   new Runnable(){
       public void run(){
        // your UI code
Re: Invalid Thread Access in MenuManagerRenderer.contextDisposed [message #1194025 is a reply to message #1183921] Mon, 18 November 2013 04:46 Go to previous messageGo to next message
Hi sumit, I aggree. I know that the code is running in the wrong thread, however how can I find the position where the code should be applied? The stacktrace does not help me very much...
Can you give me some hints?
Re: Invalid Thread Access in MenuManagerRenderer.contextDisposed [message #1196050 is a reply to message #1194025] Tue, 19 November 2013 03:11 Go to previous messageGo to next message
I was able to solve my problem. I disposed the display so that MenuManagerRenderer.contextDisposed() can't run into the if-block. However I think this is still an Eclipse Bug.
Thanks for your help though.
Re: Invalid Thread Access in MenuManagerRenderer.contextDisposed [message #1196083 is a reply to message #1194025] Tue, 19 November 2013 03:32 Go to previous messageGo to next message
Created bugzilla entry: https://bugs.eclipse.org/bugs/show_bug.cgi?id=422027
Re: Invalid Thread Access in MenuManagerRenderer.contextDisposed [message #1196381 is a reply to message #1196083] Tue, 19 November 2013 06:41 Go to previous message
Rather than Display.getDefault().etc... have the UISynchronize injected and use it's sync, async method.
Previous Topic:Contributing to any e4 Application
Next Topic:Project specific preferences
Current Time: Sat Jul 26 00:38:14 EDT 2025
Powered by FUDForum. Page generated in 0.06228 seconds
