Home » Archived » Hudson » Lunch build from another job list
Lunch build from another job list [message #1169987] Mon, 04 November 2013 05:24 Go to next message
I want to lunch a build from another possible job list.
I have an integration job and two or more feature branches and a pre prod job.
What I want is in the pre prod job I can lunch build from the integration job or from the feature branches jobs.
Thanks for your help
Re: Lunch build from another job list [message #1181525 is a reply to message #1169987] Mon, 11 November 2013 12:03 Go to previous message
If you want to start another job (downstream job) after the current job finishes (upstream job), then you need to use the "Build Other Jobs" option in the Post build actions section of the build configuration.
It is also possible start the current job (downstream job) after another job finishes (upstream job). For this you need to use the "Build after other job" option in the Build Triggers section of the build configuration.
Previous Topic:Hudson plugin update for subversion 1.8 compatibility
Next Topic:After update to Hudson 3.1 groovy post build script doesn't work
Current Time: Wed Jul 23 12:16:23 EDT 2025
Powered by FUDForum. Page generated in 0.29628 seconds
