Home » Newcomers » Newcomers » ant builder problem(builder)
ant builder problem [message #1180627] Sun, 10 November 2013 23:06 Go to next message
try to use ant builder, I check all path and classpath out, but still get the warining,
[taskdef] Could not load definitions from resource anttasks.properties. It could not be found.
[taskdef] Could not load definitions from resource emma_ant.properties. It could not be found.
-set-mode-check:....
those two jar, anttaskes.jar and emmaant.jar are all in the folder.
what's matter?
how to resolve that?
Re: ant builder problem [message #1181395 is a reply to message #1180627] Mon, 11 November 2013 10:22 Go to previous messageGo to next message
> get the warining,
> what's matter?
You might not get an answer in this forum. This isn't an ant community
forum. You should look around for one of those or try stackoverflow.com
where, I'm betting, you'll get an answer within minutes or hours.
Re: ant builder problem [message #1184190 is a reply to message #1181395] Wed, 13 November 2013 04:27 Go to previous message
thank you.
but I can hardly access to that web site from our place.
forget it.
Previous Topic:Could not install plug-in : IAR compiler and Debugger support
Next Topic:HTML, CSS and JS context assist not working
Current Time: Tue Jul 22 20:38:46 EDT 2025
Powered by FUDForum. Page generated in 0.10304 seconds
