Home » Eclipse Projects » Remote Application Platform (RAP) » Intercept mnemonic
Intercept mnemonic [message #1173139] Wed, 06 November 2013 05:09 Go to next message
I have got another question regarding mnemonics in RAP: In general they work fine, e.g. if the label is next to the textfield. However, I have a special case to consider:
+  &Text     + +  *   + +                              +
    Label       MLabel           TextField
Between the Label and the TextField is another label (MLabel) that means that when I press "alt+t", TextField will not get the focus. In SWT I have solved this problem by adding a new TraverseListener and waiting for SWT.TRAVERSE_MNEMONIC. However, I have seen that my TraverseListener is never called and RAP does not support SWT.TRAVERSE_MNEMONIC.
Do you guys see any way I can intercept the mnemonic hit and implement my own custom logic?
Thank you very much,
Matthias
Re: Intercept mnemonic [message #1181247 is a reply to message #1173139] Mon, 11 November 2013 08:26 Go to previous messageGo to next message
Hi.
I'm not sure what widget your "MLabel" is, but the best way I can think
of to get this working (assuming to use RAP 2.2) is to attach a FocusIn
ClientListener to that widget and focus the next widget in that Listener.
This might help:
http://eclipse.org/rap/developers-guide/devguide.php?topic=scripting.html&version=2.2#js-api
Here is an example for something similar (changing focus by typing):
http://git.eclipse.org/c/rap/incubator/org.eclipse.rap.incubator.clientscripting.git/tree/bundles/org.eclipse.rap.clientscripting.demo/src/org/eclipse/rap/clientscripting/demo/FocusSwitch.js
Note that you only need to register a key to attach the "next" widget to
once per UI session (WidgetUtil.registerDataKeys) and create the
ClientListener once per UI session. After that you only need to attach
the listener and "next" widget to each of your "MLabel" widgets.
Greetings,
Tim
Am 06.11.2013 11:09, schrieb Matthias Nick:
> + &Text + + * + + +
> Matthias
Tim Buschtöns
Twitter: @EclipseRAP
Re: Intercept mnemonic [message #1181349 is a reply to message #1181247] Mon, 11 November 2013 09:46 Go to previous messageGo to next message
Hi Tim,
thanks for your answer.
MLabel is in fact a simple Label.
I tried the following in the Label's constructor:
  public Label( Composite parent, int style ) {
    super( parent, checkStyle( style ) );
    String js = "var handleEvent = function( event ) { window.alert(\"action\"); };";
    addListener(SWT.FocusIn, new ClientListener(js));
However it won't be called if I hit the mnemonic - alt+t. Is it possible that a label does not support SWT.FocusIn?
Did I forget anything? (I also tried the above code with a Text, and there it works. So I assume the snippet is correct)
Matthias
Re: Intercept mnemonic [message #1182603 is a reply to message #1181349] Tue, 12 November 2013 04:39 Go to previous message
Hi.
That is indeed possible. The Snippet looks good.
I guess the alternative would be to support SWT.TRAVERSE_MNEMONIC for
ClientListener, though that is a bit of work. I'm not sure yet that this
is manageable for the 2.2 release.
Greetings,
Tim
Tim Buschtöns
Previous Topic:Calling a client service from RAP
Next Topic:RCP to RAP Example - Error
Current Time: Sat Jul 26 22:14:06 EDT 2025
Powered by FUDForum. Page generated in 0.04537 seconds
