Home » Archived » BIRT » Automate printing a BIRT report directly to a printer(Automate printing a BIRT report directly to a printer)
Automate printing a BIRT report directly to a printer [message #899369] Tue, 31 July 2012 11:12 Go to next message
Hi:
I am new to BIRT.
We are using Birt within a websphere application in a Windows environment. We have a need to automate a BIRT report and have it sent directly to a printer on the server side. So far we have been able to automate the generating of the report to a file. But are having problems automating the sending of a report directly to a printer.
Is there a suggested way of doing this?
Thank you.
Re: Automate printing a BIRT report directly to a printer [message #899399 is a reply to message #899369] Tue, 31 July 2012 12:46 Go to previous messageGo to next message
Have you tried the &__action=print on the url?
Jason
On 7/31/2012 11:12 AM, Brian McMahon wrote:
> Hi:
> I am new to BIRT.
> Thank you.
Re: Automate printing a BIRT report directly to a printer [message #899410 is a reply to message #899399] Tue, 31 July 2012 13:50 Go to previous messageGo to next message
Thank you for the quick reply.
I have not tried the &__action=print on the url, I will give that a try.
I will have to change the set up a little bit to do so.
Currently for testing, I am generating the report using the birt report engine api in a stand alone class.
Would there be an api, or a java based solution that would not involve the URL?
We would realy like to have the report to be generated and printed on the server side by a automated task running on the server.
Re: Automate printing a BIRT report directly to a printer [message #899413 is a reply to message #899410] Tue, 31 July 2012 13:53 Go to previous messageGo to next message
If that is the case why not just use the Java print services and output
the report in PS and send it to the printer directly?
Jason
> I will have to change the set up a little bit to do so. Currently for
> the URL?
> Thanks
Re: Automate printing a BIRT report directly to a printer [message #899420 is a reply to message #899413] Tue, 31 July 2012 14:29 Go to previous messageGo to next message
Yes, the PS option to the java print services seems to be exactly what I am looking for.
What would I use to generate a PS stream for sending to the java print stream?
I am currently playing with the PDFRenderOption class which produces a good looking PDF file, but just blank pages when sent to the java print services.
Re: Automate printing a BIRT report directly to a printer [message #899610 is a reply to message #899420] Wed, 01 August 2012 10:50 Go to previous messageGo to next message
BIRT has a postscript emitter. Have you tried setting up the render
options like:
HTMLRenderOption options = new HTMLRenderOption( );
options.setOutputFormat( "postscript" );
If you do not want to write the ps file to disk use the
options.setOutputStream method.
Jason
> am looking for.
> stream?
> services.
> Thanks
Re: Automate printing a BIRT report directly to a printer [message #899684 is a reply to message #899610] Wed, 01 August 2012 16:09 Go to previous messageGo to next message
Jason:
Thank you very much for your guidence and quick responses.
They were very helpfull.
The report is now being sent directly to the printer without user intervention.
It seems to also work with using the RenderOptions class.
IRunAndRenderTask task = engine.createRunAndRenderTask(design);
RenderOption options = new RenderOption();
options.setOutputFormat("postscript");
task.setRenderOption(options);
Thank you.
Re: Automate printing a BIRT report directly to a printer [message #1005900 is a reply to message #899684] Tue, 29 January 2013 04:11 Go to previous messageGo to next message
how could i generate a PS stream for sending to the java print stream?
Can yu give me the code example?
Re: Automate printing a BIRT report directly to a printer [message #1006274 is a reply to message #1005900] Wed, 30 January 2013 11:23 Go to previous messageGo to next message
Have you tried setting up the render options like above but adding something like:
ByteArrayOutputStream out = new ByteArrayOutputStream();
options.setOutputStream( out );
task.run();
task.close();
InputStream inputStream = new ByteArrayInputStream(( (ByteArrayOutputStream) out ).toByteArray( ) );
//setup your Printer
Printer printer = ....
PrintService service = printer.getService( );
synchronized ( service )
DocPrintJob job = service.createPrintJob( );
Doc doc = new SimpleDoc( inputStream,
DocFlavor.INPUT_STREAM.POSTSCRIPT, null );
job.print( doc, pas );
I have not tried this but hopefully it will help you. The above code used javax.print package.
Jason
Re: Automate printing a BIRT report directly to a printer [message #1095618 is a reply to message #1006274] Tue, 27 August 2013 05:48 Go to previous messageGo to next message
Will anybody provide me javascript(in afterRender) example, to send report to printer?
Rajani
Re: Automate printing a BIRT report directly to a printer [message #1181150 is a reply to message #1095618] Mon, 11 November 2013 07:05 Go to previous message
I have a requirement to generate a report which reports data from 2 different regions.. Results of regions printed in a different letter head,
So my question is :
Is it possible to have a master report call two subreports, and for each sub-report 1 automatically send the report for print to a printer 1
and sub-report 2 to printer 2
Any help pls...
Previous Topic:Dynamic HTML Links
Next Topic:Websphere - Unable to determine the default workspace location
Current Time: Mon Jul 21 00:42:19 EDT 2025
Powered by FUDForum. Page generated in 0.08002 seconds
