Home » Archived » Test and Performance Tools Platform (TPTP) » Create a Deployment programmatically
Create a Deployment programmatically [message #117740] Fri, 09 November 2007 12:29 Go to next message
Originally posted by: ddesseignet.axway.com
I'am trying to create a Deployment programmatically in the
org.eclipse.hyades.automation.client.adapters.shell.Automati onClientAdapter
class. Indeed, I would like to run a test with the automation module but I
haven't created a deployment with Eclipse before. So I need to create it
programmatically before running my tests through a shell (in the
AutomationClientAdapter class). The problem is I can't recover the
Workspace (because I launch my Test through the command line) when I try
to do that:
IProject project =
ResourcesPlugin.getWorkspace().getRoot().getProject(projectN ame);
URI uri = URI.createPlatformResourceURI(absoluteDeployPath);
org.eclipse.emf.ecore.resource.Resource.Factory factory =
EMFUtil.getResourceFactory(ICommonConstants.DEPLOYMENT_FILE_ EXTENSION);
Resource resource = null;
TPFDeployment deployment = null;
resource = factory.createResource(uri);
deployment = Common_TestprofileFactory.eINSTANCE.createTPFDeployment();
resource.getContents().add(deployment);
deployment.setName("test");
deployment.setDescription("");
Do you have any idea to help me ?
Thanks.
Regards.
Damien
Re: Create a Deployment programmatically [message #118006 is a reply to message #117740] Mon, 12 November 2007 07:04 Go to previous message
Hi Damien,
Unless your artifact and/or location changes, you can manually create
one in the TPTP workbench.
Paul
"Damien" <ddesseignet@axway.com> wrote in message
news:06e4bd7d04fcbb2478ef87efdc8c56db$1@www.eclipse.org...
> Hello,
> to do that:
> IProject project =
> Resource resource = null; TPFDeployment deployment = null; resource =
> resource.getContents().add(deployment); deployment.setName("test");
> Thanks.
> Regards.
> Damien
Previous Topic:Substitution of Datapool contents with Deployment?
Next Topic:Problems when profiling a standalone tomcat
Current Time: Sun Jul 27 23:02:41 EDT 2025
Powered by FUDForum. Page generated in 0.33784 seconds
