[Xbase] getting the result type of an expression during inferring [message #1130093] |
Wed, 09 October 2013 04:19  |
Hello!
I am writing a GUI-Description-Language and I am using Xbase. I need to find the result type of an xbase expression during inferring.
Excerpt from the Grammar:
WidgetProperty:
propertyDefinition=[tkdef::WidgetPropertyDefinition]
( '=' '{' (expressionValue = XExpression)? '}' )?
( 'renderWith' renderWith = [Widget|QualifiedName] )?
( '{' (nestedProperties += WidgetProperty ','?)* '}' )?
A complex usage example for this.
widget Table ResultTable {
Content = {Partners} {
Column { Title = {"Name"} Value = { Name } }
Column { Title = {"Vorname"} Value = { if (it instanceof NatPerson) "irgendwas" else "anderes" } }
Data-Model:
public class RootModel {
public List<Partner> getPartners () { ... }
public class Partner {
public String getName () { ... }
The nested properties should get a more specific data context from the parent properties if they define a data-binding expression (like "Partners" in this case). The result type of that expression is supposed to be the data-context for the nested properties.
Simplified Inferrer:
def dispatch void infer (GuiDescription element, IJvmDeclaredTypeAcceptor acceptor, boolean isPreIndexingPhase)
acceptor.accept (element.toClass (name))
.initializeLater[
element.eAllContents.filter (WidgetProperty).forEach [widgetProperty, counter|
val returnType = ...
members += element.toMethod ('''eval_XbaseExpression_«counter»''', returnType) [
parameters += element.toParameter ("it", widgetProperty.parameterType)
body = widgetProperty.expressionValue
def JvmTypeReference getParameterType (WidgetProperty property)
if (property.eContainer instanceof WidgetProperty) {
val parentProp = property.eContainer as WidgetProperty
if (parentProp.expressionValue != null) {
return parentProp.expressionValue.inferredType
} else {
return parentProp.parameterType
return property.widget.dataModel.newTypeRef
The problem is now that expressionValue.inferredType does not work (and the docu says: don't use it). But what else to use? Is it at all possible to get the resulting type of the expression?
The exception that raises if used:
Caused by: java.lang.UnsupportedOperationException: TODO: import a functional handle on the type resolution that delegates to the best available (current, but evolving) result
at org.eclipse.xtext.xbase.typesystem.internal.DefaultReentrantTypeResolver.reentrantResolve(DefaultReentrantTypeResolver.java:141)
at org.eclipse.xtext.xbase.typesystem.internal.DefaultBatchTypeResolver$1.reentrantResolve(DefaultBatchTypeResolver.java:122)
at org.eclipse.xtext.xbase.typesystem.internal.CachingBatchTypeResolver$LazyResolvedTypes.delegate(CachingBatchTypeResolver.java:114)
at org.eclipse.xtext.xbase.typesystem.internal.CachingBatchTypeResolver$2.process(CachingBatchTypeResolver.java:61)
at org.eclipse.xtext.xbase.typesystem.internal.CachingBatchTypeResolver$2.process(CachingBatchTypeResolver.java:1)
at org.eclipse.xtext.util.concurrent.IUnitOfWork$Void.exec(IUnitOfWork.java:36)
at org.eclipse.xtext.util.OnChangeEvictingCache.execWithoutCacheClear(OnChangeEvictingCache.java:127)
... 91 more
Nicolas Cabanis
Re: [Xbase] getting the result type of an expression during inferring [message #1178440 is a reply to message #1132609] |
Sat, 09 November 2013 12:07   |
Hi, I'm experiencing a similar issue.
I have a grammar for defining objects with it properties and messages (those are features), then it gets into java through the jvm model inferrer.
When the property type is declared explicitly everything seems right. When it should be inferred by the initialization value it breaks.
Grammar:
Feature:
Property | Message;
Property:
name=ValidID (':' type=JvmTypeReference)? ('startsWith' value=XExpression)?;
The Inferrer includes:
def dispatch void infer(HoopeObject element, IJvmDeclaredTypeAcceptor acceptor, boolean isPrelinkingPhase) {
acceptor.accept(jvmGenericType).initializeLater [
documentation = element.documentation
for (feature : element.features) {
switch feature {
Property: {
val type = feature.type?: feature.value.inferredType
members += feature.toField(feature.name, type) [
initializer = feature.value
members += feature.toGetter(feature.name, type)
members += feature.toSetter(feature.name, type)
This works perfectly...
val pepita = object {
energia : double startsWith 2.0
but when I try to let the inferrer infer the type of Property initial value:
energia startsWith 2.0
Bang!
WrappedException: java.lang.UnsupportedOperationException: TODO:
to the best available (current, but evolving) result (see logs
for details)
This gets to console:
!STACK 0
at org.eclipse.xtext.xbase.typesystem.internal.CompoundReentrantTypeResolver.getDelegate(CompoundReentrantTypeResolver.java:79)
at org.eclipse.xtext.xbase.typesystem.internal.CompoundReentrantTypeResolver.getDelegate(CompoundReentrantTypeResolver.java:114)
at org.eclipse.xtext.xbase.typesystem.internal.CompoundReentrantTypeResolver.getActualType(CompoundReentrantTypeResolver.java:106)
at org.eclipse.xtext.xbase.typesystem.internal.ForwardingResolvedTypes.getActualType(ForwardingResolvedTypes.java:39)
at org.eclipse.xtext.xbase.typesystem.InferredTypeIndicator.getTypeReference(InferredTypeIndicator.java:78)
at org.eclipse.xtext.xtype.impl.XComputedTypeReferenceImplCustom.getEquivalent(XComputedTypeReferenceImplCustom.java:46)
at org.eclipse.xtext.common.types.impl.JvmSpecializedTypeReferenceImplCustom.getType(JvmSpecializedTypeReferenceImplCustom.java:23)
at org.eclipse.xtext.xbase.scoping.batch.BucketedEObjectDescription.computeShadowingKey(BucketedEObjectDescription.java:79)
at org.eclipse.xtext.xbase.scoping.batch.BucketedEObjectDescription.getShadowingKey(BucketedEObjectDescription.java:62)
at org.eclipse.xtext.xbase.scoping.batch.AbstractSessionBasedScope.getShadowingKey(AbstractSessionBasedScope.java:169)
at org.eclipse.xtext.xbase.scoping.batch.AbstractSessionBasedScope.isShadowed(AbstractSessionBasedScope.java:179)
at org.eclipse.xtext.scoping.impl.AbstractScope$ParentIterable.apply(AbstractScope.java:67)
at org.eclipse.xtext.scoping.impl.AbstractScope$ParentIterable.apply(AbstractScope.java:1)
at com.google.common.collect.Iterators$7.computeNext(Iterators.java:645)
at com.google.common.collect.AbstractIterator.tryToComputeNext(AbstractIterator.java:141)
at com.google.common.collect.AbstractIterator.hasNext(AbstractIterator.java:136)
at com.google.common.collect.Iterators$5.hasNext(Iterators.java:539)
at org.eclipse.xtext.xbase.typesystem.internal.AbstractTypeComputationState.getLinkingCandidates(AbstractTypeComputationState.java:346)
at org.eclipse.xtext.xbase.typesystem.computation.XbaseTypeComputer._computeTypes(XbaseTypeComputer.java:848)
at org.uqbar.HoopeTypeComputer.computeTypes(HoopeTypeComputer.java:70)
at org.eclipse.xtext.xbase.typesystem.internal.AbstractTypeComputationState.doComputeTypes(AbstractTypeComputationState.java:119)
at org.eclipse.xtext.xbase.typesystem.internal.AbstractTypeComputationState.computeTypes(AbstractTypeComputationState.java:108)
at org.eclipse.xtext.xbase.typesystem.computation.XbaseTypeComputer._computeTypes(XbaseTypeComputer.java:292)
at org.uqbar.HoopeTypeComputer.computeTypes(HoopeTypeComputer.java:88)
at org.eclipse.xtext.xbase.typesystem.internal.AbstractRootTypeComputationState.computeTypes(AbstractRootTypeComputationState.java:36)
at org.eclipse.xtext.xbase.typesystem.internal.LogicalContainerAwareReentrantTypeResolver._computeTypes(LogicalContainerAwareReentrantTypeResolver.java:512)
at org.eclipse.xtext.xbase.typesystem.internal.LogicalContainerAwareReentrantTypeResolver.computeTypes(LogicalContainerAwareReentrantTypeResolver.java:422)
at org.eclipse.xtext.xbase.typesystem.internal.LogicalContainerAwareReentrantTypeResolver.computeMemberTypes(LogicalContainerAwareReentrantTypeResolver.java:583)
at org.eclipse.xtext.xbase.typesystem.internal.LogicalContainerAwareReentrantTypeResolver._computeTypes(LogicalContainerAwareReentrantTypeResolver.java:572)
at org.eclipse.xtext.xbase.typesystem.internal.LogicalContainerAwareReentrantTypeResolver.computeTypes(LogicalContainerAwareReentrantTypeResolver.java:416)
at org.eclipse.xtext.xbase.typesystem.internal.LogicalContainerAwareReentrantTypeResolver.computeTypes(LogicalContainerAwareReentrantTypeResolver.java:411)
at org.eclipse.xtext.xbase.typesystem.internal.DefaultReentrantTypeResolver.resolve(DefaultReentrantTypeResolver.java:160)
at org.eclipse.xtext.xbase.typesystem.internal.DefaultReentrantTypeResolver.reentrantResolve(DefaultReentrantTypeResolver.java:147)
at org.eclipse.xtext.xbase.compiler.ErrorSafeExtensions.serializeSafely(ErrorSafeExtensions.java:210)
at org.eclipse.xtext.xbase.compiler.JvmModelGenerator.generateParameter(JvmModelGenerator.java:1066)
at org.eclipse.xtext.xbase.compiler.JvmModelGenerator.generateParameters(JvmModelGenerator.java:1038)
at org.eclipse.xtext.xbase.compiler.JvmModelGenerator._generateMember(JvmModelGenerator.java:857)
at org.eclipse.xtext.xbase.compiler.JvmModelGenerator.generateMember(JvmModelGenerator.java:1880)
at org.eclipse.xtext.xbase.compiler.JvmModelGenerator$2.apply(JvmModelGenerator.java:288)
at org.eclipse.xtext.xbase.compiler.JvmModelGenerator$2.apply(JvmModelGenerator.java:1)
at org.eclipse.xtext.xbase.lib.ObjectExtensions.operator_doubleArrow(ObjectExtensions.java:139)
at org.eclipse.xtext.xbase.compiler.LoopExtensions$1.apply(LoopExtensions.java:39)
at org.eclipse.xtext.xbase.lib.IterableExtensions.forEach(IterableExtensions.java:399)
at org.eclipse.xtext.xbase.compiler.LoopExtensions.forEach(LoopExtensions.java:42)
at org.eclipse.xtext.xbase.compiler.JvmModelGenerator._generateBody(JvmModelGenerator.java:292)
at org.eclipse.xtext.xbase.compiler.JvmModelGenerator.generateBody(JvmModelGenerator.java:1852)
at org.eclipse.xtext.xbase.compiler.JvmModelGenerator.generateType(JvmModelGenerator.java:211)
at org.eclipse.xtext.xbase.compiler.JvmModelGenerator._internalDoGenerate(JvmModelGenerator.java:202)
at org.eclipse.xtext.xbase.compiler.JvmModelGenerator.internalDoGenerate(JvmModelGenerator.java:1835)
at org.eclipse.xtext.xbase.compiler.JvmModelGenerator.doGenerate(JvmModelGenerator.java:183)
at org.eclipse.xtext.builder.BuilderParticipant.handleChangedContents(BuilderParticipant.java:299)
at org.eclipse.xtext.builder.BuilderParticipant.build(BuilderParticipant.java:229)
at org.eclipse.xtext.builder.impl.RegistryBuilderParticipant.build(RegistryBuilderParticipant.java:60)
at org.eclipse.xtext.builder.impl.XtextBuilder.doBuild(XtextBuilder.java:186)
at org.eclipse.xtext.builder.impl.XtextBuilder.incrementalBuild(XtextBuilder.java:162)
at org.eclipse.xtext.builder.impl.XtextBuilder.build(XtextBuilder.java:95)
at org.eclipse.core.internal.events.BuildManager$2.run(BuildManager.java:726)
at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:199)
at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:239)
at org.eclipse.core.internal.events.BuildManager$1.run(BuildManager.java:292)
at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:295)
at org.eclipse.core.internal.events.BuildManager.basicBuildLoop(BuildManager.java:351)
at org.eclipse.core.internal.events.BuildManager.build(BuildManager.java:374)
at org.eclipse.core.internal.events.AutoBuildJob.doBuild(AutoBuildJob.java:143)
at org.eclipse.core.internal.events.AutoBuildJob.run(AutoBuildJob.java:241)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:53)
It's running on Eclipse 4.3 and Xtext 2.4.2.
Any clue? Sinc domain model examples using jvminferrer have mandatory type declaration, perhaps this feature is not available.
Thanks in advance and best regards!
Miguel
FUDForum. Page generated in 0.10592 seconds
