Home » Modeling » EMF » Custom Edatatype with ecore model editor
Custom Edatatype with ecore model editor [message #1176658] Fri, 08 November 2013 08:25 Go to next message
Simpel question, but hard to find an answer.
How do I create a Custom EDatatype with the ecore editor?
Should I select an EType => EJavaObject?
Thank you,
Christophe
Re: Custom Edatatype with ecore model editor [message #1176714 is a reply to message #1176658] Fri, 08 November 2013 09:04 Go to previous messageGo to next message
Hi, Chrisophe,
In the New Child menu of the EPackage, choose EDataType to create a new
EDataType. This can then be used as the type of any EAttribute. Don't
forget to set the instance class name of your data type.
HTH,
Christian
On 2013-11-08 13:25:12 +0000, Christophe Bouhier said:
> Thank you,
> Christophe
Re: Custom Edatatype with ecore model editor [message #1176780 is a reply to message #1176714] Fri, 08 November 2013 09:52 Go to previous message
Thanks Christian!
On 08-11-13 15:04, Christian W. Damus wrote:
> Hi, Chrisophe,
> HTH,
> Christian
>> Hi,
>> Thank you,
>> Christophe
Previous Topic:Extending EMF Compare
Next Topic:Generic adapter generation toolchain
Current Time: Sat Jul 26 12:51:40 EDT 2025
Powered by FUDForum. Page generated in 0.05255 seconds
