Home » Archived » BIRT » Page break for nested tables
Page break for nested tables [message #117601] Thu, 26 January 2006 11:54 Go to next message
Originally posted by: vladimir.simjanoski.netcetera.com.mk
Hi all,
I'm using BIRT2.0 and have problems with controlling page break.
In the PDF report, I'm using nested tables:
- outer table
- inner table1
- inner table2
and this can occur multiple times in the report.
I need to break at inner table1 if it's content (together with inner
table2) doesn't fit on the page. in BIRT1.0.1, we only set all page
break attributes for three tables to "auto", define page break
attributes for two rows in outer table and it worked.
In 2.0, I tried several different combinations but without success.
I saw the attribute pageBreakInterval, but I guess it's only taken into
account for HTML output.
Are there any documents/help for BIRT2.0 page break mechanism?
This is very urgent, please help.
Re: Page break for nested tables [message #117676 is a reply to message #117601] Thu, 26 January 2006 12:34 Go to previous messageGo to next message
Vladimir Simjanoski wrote:
> Hi all,
> - outer table
> - inner table1
> - inner table2
Can you log a Bugzilla bug with your report design attached? If you have
used your own database, can you create a different report that uses for
example, the sample DB so that we can quickly debug?
Stanley Wang
BIRT Engine
Re: Page break for nested tables [message #122706 is a reply to message #117676] Wed, 01 February 2006 09:52 Go to previous message
Hi Stanley,
We have submitted a bug (126010) for this problem and also attached the
example report for the problem.
>> Hi all,
>> - outer table
>> - inner table1
>> - inner table2
>> into account for HTML output.
> Stanley Wang
> BIRT Engine
Previous Topic:[org.eclipse.birt.report.model.reportItemModel] is not found. Error
Next Topic:group header
Current Time: Mon Nov 03 12:20:31 EST 2025
Powered by FUDForum. Page generated in 0.03439 seconds
