Home » Eclipse Projects » EGit / JGit » JGit HTTPS cloning is not working(JGit HTTPS cloning is not working)
JGit HTTPS cloning is not working [message #1176232] Fri, 08 November 2013 02:50 Go to next message
I am having the Geritt GitHub Url : HTTPS -> ://mycompany.com/gerrit/p/my-services.git
I cloned via terminal it is working fine : git clone HTTPS -> ://mycompany.com/gerrit/p/my-services.git.
When I use the java code to clone using JGit , It is throwing error like "UnknownHostException",
I am wondering when I clone in terminal it is working fine, But When I try it with JGit , it is throwing error ? Why it is not recognizing that domain on JGit ?
Error log is,
org.eclipse.jgit.api.errors.TransportException: https -> ://mycompany.com/gerrit/p/my-services.git: cannot open git-upload-pack
        at org.eclipse.jgit.api.FetchCommand.call(FetchCommand.java:137)
        at org.eclipse.jgit.api.CloneCommand.fetch(CloneCommand.java:178)
        at org.eclipse.jgit.api.CloneCommand.call(CloneCommand.java:125)
        at com.test.AppTest.importGit(AppTest.java:128)
        at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
        at org.junit.runners.model.FrameworkMethod$1.runReflectiveCall(FrameworkMethod.java:44)
        at org.junit.internal.runners.model.ReflectiveCallable.run(ReflectiveCallable.java:15)
        at org.junit.runners.model.FrameworkMethod.invokeExplosively(FrameworkMethod.java:41)
        at org.junit.internal.runners.statements.InvokeMethod.evaluate(InvokeMethod.java:20)
        at org.junit.internal.runners.statements.RunBefores.evaluate(RunBefores.java:28)
        at org.junit.internal.runners.statements.RunAfters.evaluate(RunAfters.java:31)
        at org.junit.runners.ParentRunner.runLeaf(ParentRunner.java:263)
        at org.junit.runners.BlockJUnit4ClassRunner.runChild(BlockJUnit4ClassRunner.java:69)
        at org.junit.runners.BlockJUnit4ClassRunner.runChild(BlockJUnit4ClassRunner.java:48)
        at org.junit.runners.ParentRunner$3.run(ParentRunner.java:231)
        at org.junit.runners.ParentRunner$1.schedule(ParentRunner.java:60)
        at org.junit.runners.ParentRunner.runChildren(ParentRunner.java:229)
        at org.junit.runners.ParentRunner.access$000(ParentRunner.java:50)
        at org.junit.runners.ParentRunner$2.evaluate(ParentRunner.java:222)
        at org.junit.runners.ParentRunner.run(ParentRunner.java:292)
        at org.apache.maven.surefire.junit4.JUnit4TestSet.execute(JUnit4TestSet.java:35)
        at org.apache.maven.surefire.junit4.JUnit4Provider.executeTestSet(JUnit4Provider.java:115)
        at org.apache.maven.surefire.junit4.JUnit4Provider.invoke(JUnit4Provider.java:97)
        at org.apache.maven.surefire.booter.ProviderFactory$ClassLoaderProxy.invoke(ProviderFactory.java:103)
        at $Proxy0.invoke(Unknown Source)
        at org.apache.maven.surefire.booter.SurefireStarter.invokeProvider(SurefireStarter.java:150)
        at org.apache.maven.surefire.booter.SurefireStarter.runSuitesInProcess(SurefireStarter.java:91)
        at org.apache.maven.surefire.booter.ForkedBooter.main(ForkedBooter.java:69)
Caused by: org.eclipse.jgit.errors.TransportException: https -> ://mycompany.com/gerrit/p/my-services.git: cannot open git-upload-pack
        at org.eclipse.jgit.transport.TransportHttp.connect(TransportHttp.java:499)
        at org.eclipse.jgit.transport.TransportHttp.openFetch(TransportHttp.java:308)
        at org.eclipse.jgit.transport.FetchProcess.executeImp(FetchProcess.java:136)
        at org.eclipse.jgit.transport.FetchProcess.execute(FetchProcess.java:122)
        at org.eclipse.jgit.transport.Transport.fetch(Transport.java:1105)
        at org.eclipse.jgit.api.FetchCommand.call(FetchCommand.java:128)
        ... 34 more
Caused by: java.net.UnknownHostException: mycompany.com
at java.net.PlainSocketImpl.connect(PlainSocketImpl.java:195)
        at java.net.SocksSocketImpl.connect(SocksSocketImpl.java:366)
        at java.net.Socket.connect(Socket.java:529)
        at com.sun.net.ssl.internal.ssl.SSLSocketImpl.connect(SSLSocketImpl.java:570)
        at sun.net.NetworkClient.doConnect(NetworkClient.java:158)
        at sun.net.www.http.HttpClient.openServer(HttpClient.java:411)
        at sun.net.www.http.HttpClient.openServer(HttpClient.java:525)
        at sun.net.www.protocol.https.HttpsClient.<init>(HttpsClient.java:272)
        at sun.net.www.protocol.https.HttpsClient.New(HttpsClient.java:329)
        at sun.net.www.protocol.https.AbstractDelegateHttpsURLConnection.getNewHttpClient(AbstractDelegateHttpsURLConnection.java:172)
        at sun.net.www.protocol.http.HttpURLConnection.plainConnect(HttpURLConnection.java:966)
        at sun.net.www.protocol.https.AbstractDelegateHttpsURLConnection.connect(AbstractDelegateHttpsURLConnection.java:158)
        at sun.net.www.protocol.http.HttpURLConnection.getInputStream(HttpURLConnection.java:1195)
        at java.net.HttpURLConnection.getResponseCode(HttpURLConnection.java:379)
        at sun.net.www.protocol.https.HttpsURLConnectionImpl.getResponseCode(HttpsURLConnectionImpl.java:318)
        at org.eclipse.jgit.util.HttpSupport.response(HttpSupport.java:167)
        at org.eclipse.jgit.transport.TransportHttp.connect(TransportHttp.java:462)
        ... 39 more
My code is,
// I am using the below code to trust all the https urls,
// Create a trust manager that does not validate certificate chains
TrustManager[] trustAllCerts = new TrustManager[] {
    new X509TrustManager() {
        public java.security.cert.X509Certificate[] getAcceptedIssuers() {
            return null;
        public void checkClientTrusted(
            java.security.cert.X509Certificate[] certs, String authType) {
        public void checkServerTrusted(
// Install the all-trusting trust manager
try {
    SSLContext sc = SSLContext.getInstance("SSL");
    sc.init(null, trustAllCerts, new java.security.SecureRandom());
    HttpsURLConnection.setDefaultSSLSocketFactory(sc.getSocketFactory());
} catch (GeneralSecurityException e) {
String url = "https -> ://mycompany.com/gerrit/p/my-services.git";
String username = "username";
String password = "password";
String checkoutLocation = "/Users/testing";
String branch = "my-services-sample-test";
UsernamePasswordCredentialsProvider userCredential = new UsernamePasswordCredentialsProvider(username, password);
Git r = Git.cloneRepository().setDirectory(new File(checkoutLocation + "/clonned"))
.setCredentialsProvider(userCredential)
.setURI(url)
.setProgressMonitor(new TextProgressMonitor())
.setBranch(branch)
.call();
System.out.println("Clonning @ " + checkoutLocation);
r.getRepository().close();
I am usign the dependency
<dependency>
<groupId>org.eclipse.jgit</groupId>
<artifactId>org.eclipse.jgit</artifactId>
<version>3.0.0.201306101825-r</version>
<scope>compile</scope>
</dependency>
Re: JGit HTTPS cloning is not working [message #1176644 is a reply to message #1176232] Fri, 08 November 2013 08:15 Go to previous messageGo to next message
- maybe you need some proxy configuration ?
- instead of using your own TrustManager you could configure http.sslVerify = false in order to instruct jgit to trust all certs
- you are not using the latest jgit release, though 3.0 should work
Re: JGit HTTPS cloning is not working [message #1176680 is a reply to message #1176644] Fri, 08 November 2013 08:38 Go to previous messageGo to next message
Hi Matthias Sohn,
I specified the http.sslVerify = false in Bash profile. May I know the what kind of configuration that I have to specify ? . Code level idea is highly appreciated.
Re: JGit HTTPS cloning is not working [message #1176786 is a reply to message #1176680] Fri, 08 November 2013 09:58 Go to previous messageGo to next message
Hi Matthias Sohn,
Your suggestion guided me to find the solution. I need to set the proxy configuration in Jgit,
ProxySelector.setDefault(new ProxySelector() {
final ProxySelector delegate = ProxySelector.getDefault();
public List<Proxy> select(URI uri) {
// Filter the URIs to be proxied
if (uri.toString().contains("github")
&& uri.toString().contains("https")) {
return Arrays.asList(new Proxy(Type.HTTP, InetSocketAddress
.createUnresolved("localhost", 3128)));
&& uri.toString().contains("http")) {
.createUnresolved("localhost", 3129)));
// revert to the default behaviour
return delegate == null ? Arrays.asList(Proxy.NO_PROXY)
: delegate.select(uri);
public void connectFailed(URI uri, SocketAddress sa, IOException ioe) {
if (uri == null || sa == null || ioe == null) {
throw new IllegalArgumentException(
"Arguments can't be null.");
Ref: http://stackoverflow.com/questions/16921374/jgit-proxy-configuration-in-code
Re: JGit HTTPS cloning is not working [message #1176865 is a reply to message #1176786] Fri, 08 November 2013 11:02 Go to previous messageGo to next message
JGit doesn't look into the bash profile, it loads the git configuration from the usual git config files [1]:
* system level located at <native git installation path>/etc/gitconfig
* user level located at ~/.gitconfig
* repository level located at /path/to/repo/.git/config
In addition you can tweak the configuration programmatically using class FileBasedConfig.
[1] http://git-scm.com/book/en/Customizing-Git-Git-Configuration
Re: JGit HTTPS cloning is not working [message #1457639 is a reply to message #1176232] Fri, 31 October 2014 10:45 Go to previous messageGo to next message
Hello, I come to ask for help in a research project I am working. My algorithm makes analysis of refactoring between versions of projects
software written in java language. For that I need to test the tool with several projects. My choice was between test versions of projects
exposed on github. For this, we developed an algorithm communicates with the api git. Use the egit and JGit, but currently the algorithm
captures only link by .git download link. How could I do to download several projects going .git? Example of my code:
String urlGit="github.com/centic9/jgit-cookbook.git";
File localPath = File.createTempFile("GitRepository", "", new File("C:/GitHub"));
downloadgit.specificDownload(localPath, urlGit);
protected void specificDownload(File path, String url) throws Exception {
.setDirectory(path)
.setURI(url)
.setBare(false)
.setCloneAllBranches(true)
.call();
Re: JGit HTTPS cloning is not working [message #1461306 is a reply to message #1457639] Tue, 04 November 2014 07:26 Go to previous message
don't highjack another thread for an unrelated question
Previous Topic:Use git repository directly from remote server
Next Topic:Amazon S3 Object Interaction
Current Time: Fri Jul 25 19:44:42 EDT 2025
Powered by FUDForum. Page generated in 0.04559 seconds
