Home » Eclipse Projects » Remote Application Platform (RAP) » Client Error "a is undefined" on asynchronous UI update
Client Error "a is undefined" on asynchronous UI update [message #1176406] Fri, 08 November 2013 05:08 Go to next message
Hi all,
we faced a problem regarding asynchronous ui update calls using display.asyncExec in RAP 2.1.0
Here's a little Snippet, I hope this can demonstrate the problem:
public MyComposite() {
        super(...);
        this.label = new Label(...);
public void handleEvent() {
	getDisplay().asyncExec(new Runnable() {
		public void run() {
	      		updateUi();
private void updateUi() {
	this.label.setImage(this.image);
handleEvent is called from another thread, so it may be called almost concurrently to the creation of the Label.
When this happens a "Client Error" appears, because obviously the widget is still undefined in the JavaScript context, although the corresponding Java Object already exists.
Client Error
Details:
Error: Error: Operation "set" on target "w1750" of type "null" failed:
a is undefined
Properties:
image = rwt-resources/generated/47476ff0.png,15,15
  Script: {"head":{"requestCounter":79},"operations":[["set","w1750",{"image":["rwt-resources/generated/47476ff0.png",15,15]}], ....
May this be a Bug in the RAP framework or is there any known solution to this?
Thank you!
Christian
Re: Client Error "a is undefined" on asynchronous UI update [message #1176706 is a reply to message #1176406] Fri, 08 November 2013 08:55 Go to previous messageGo to next message
Hi Christian,
usually such kind of JavaScript errors are bugs in the framework. Please
open a bugzilla and attach a complete self-running snippet to
demonstrate the issue.
Ivan
On 11/8/2013 3:46 PM, Christian Brugger wrote:
> Hi all,
> super(...);
> this.label = new Label(...); }
> @Override
> public void run() {
> updateUi();
> Client Error
> Details:
> a is undefined
> Properties:
> Script:
> to this?
> Thank you!
> Christian
Ivan Furnadjiev
Twitter: @EclipseRAP
Re: Client Error "a is undefined" on asynchronous UI update [message #1176728 is a reply to message #1176706] Fri, 08 November 2013 09:12 Go to previous messageGo to next message
Hi Ivan,
thanks for your answer.
As the error happens only sporadic, there's no easy way to create a self-running example that can reproduce the error reliably. Seems like the problem is some kind of race condition.
I'll create a Bugzilla issue when I found a way to reprocude the error.
Anyway, do you know of any similar issues, respectively any solution or workaround to prevent this from happening?
Chrisitan
icon5.gif  Re: Client Error "a is undefined" on asynchronous UI update [message #1182627 is a reply to message #1176728] Tue, 12 November 2013 04:59 Go to previous messageGo to next message
Hi again,
I have another assumption, what maybe causes this error.
The system, where the problem occurred several times, is not very powerful, so maybe the performance of the RAP server is quite bad. Also the network connection may be slow from time to time.
Does anyone have some expierience with such kind of "Client errors" occurring on slow systems or with increased network latency?
... When I try to reproduce this error in my development environment (with RAP server on localhost) everything seems to work fine. Confused
Christian
Re: Client Error "a is undefined" on asynchronous UI update [message #1182654 is a reply to message #1182627] Tue, 12 November 2013 05:18 Go to previous messageGo to next message
Hi Christian,
is this error reproducible with all browsers - IE08-IE11, Firefox,
Chrome, Opera 17?
Best,
Ivan
On 11/12/2013 11:59 AM, Christian Brugger wrote:
> Hi again,
> Also the network connection may be slow from time to time. Does anyone
> (with RAP server on localhost) everything seems to work fine. :?
> Christian
Ivan Furnadjiev
Re: Client Error "a is undefined" on asynchronous UI update [message #1182739 is a reply to message #1182654] Tue, 12 November 2013 06:34 Go to previous messageGo to next message
Hi Ivan,
it happened with Firefox and Chrome.
And as I cannot reproduce it at all for now, i don't know for other browsers and IE.
I will try to reproduce the error for other browsers, if this information can help you...
Christian
Re: Client Error "a is undefined" on asynchronous UI update [message #1182800 is a reply to message #1182739] Tue, 12 November 2013 07:20 Go to previous message
Hi Christian,
my suspicion was that the "bad guy" is IE.... but as it happens in
Firefox and Chrome that was a wrong direction... Without a snippet to
reproduce it I can't help you much.
Best,
Ivan
On 11/12/2013 1:34 PM, Christian Brugger wrote:
> Hi Ivan,
> browsers and IE.
> Christian
Ivan Furnadjiev
Previous Topic:dropdown widget - autosuggest
Next Topic:WorkbenchAdvisor SHOW_SYSTEM_JOBS
Current Time: Thu Jul 24 20:34:33 EDT 2025
Powered by FUDForum. Page generated in 0.04768 seconds
