Home » Eclipse Projects » Remote Application Platform (RAP) » Calling a client service from RAP
Calling a client service from RAP [message #1172098] |
Tue, 05 November 2013 12:55  |
Hi all,
we would like to call a local service running on the client machine from RAP.
This could be any kind of Java service; we are open to many options (REST, JSON, MQTT, ...).
In the end the goal is to be able to interact with a local scanner managed by a local Java application, but the same could apply for, let's say, a 'dir' command on the local 'C:' disk.
What could be the best and direct way to accompish this task with RAP?
Thank you very much.
Vincenzo
Re: Calling a client service from RAP [message #1176697 is a reply to message #1172098] |
Fri, 08 November 2013 08:51   |
Hi Vincenzo,
one possible solution will be a signed Java applet running in the same
page with your RAP application. Every modern browser support
Java-to-JavaScript bridge. With signed Java applet you will overcome to
browser sandbox.
HTH,
Ivan
On 11/5/2013 7:55 PM, Vincenzo Caselli wrote:
> Hi all,
> from RAP.
> Vincenzo
Ivan Furnadjiev
Twitter: @EclipseRAP
Re: Calling a client service from RAP [message #1177343 is a reply to message #1172098] |
Fri, 08 November 2013 18:17   |
Ralf, Ivan,
thank you!
@Ralf
we have to do a RAP porting of a quite complex RCP application that uses not only different kind of scanners, but also other local devices, so a direct communication between the browser and the local JVM is strongly needed. I agree on the fact that the javascript sandbox (it would be the same for an applet) is there for a reason, but a security mechanism can be always set up, considered that it would be an intranet webapp.
@Ivan
the signed applet solution was our first thought, but there are a number of reason against this (sounds like an old way, applets has gained a bad name in years, Oracle latest updates seems to be more restrictive about them, ...)
Anyway in the meantime we had some success with a local REST+JSONP service called by a standard (not RAP) webapp using jQuery.
I've read that RAP has jQuery integration, so this may be a good solution.
Can you point me out of some simple example of how to use jQuery in RAP?
I was looking at org.eclipse.rap.demo.carousel and org.eclipse.rap.widget.carousel example, but if there is a simpler "how-to" on this, please let me know.
Thank you again
Vincenzo
Re: Calling a client service from RAP [message #1182635 is a reply to message #1181982] |
Tue, 12 November 2013 05:03   |
Hi.
> We just wonder if this is the simplest solution. Would it be possible to
> do without the Browser and have a sort of callback from
> JavaScriptExecutor ?
That is possible, though it's a some work and requires some advanced
JavaScript and RAP knowledge. I wouldn't call it "simpler", only more
elegant.
I thought a few times before about implementing something like a
"ServerFunction", basically a BrowserFunction without the Browser
widget, but never got around to it. This could be implemented using the
Client/Server Remote APIs, like a custom widget, but with no widget.
It's not a polished idea, but here is the rough outline:
- Implement an abstract Java class ServerFunction that has a single
abstract callback method "execute" (like a runnable).
- In the constructor of the class create a RemoteObject[1] of the type
"ServerFunction" and add an OperationHandler[2] that calls the "execute"
method for call operations "execute"[3]. The properties map could be
passed on as-is or converted in some manner to suit your needs.
- On the client you need to register an TypeHandler[4] for
"ServerFunction" that in the factory returns a function that gets it's
own client-side remoteObject[5]. (To do so the function body needs to
reference itself, which may be tricky but possible, e.g. using named
functions or the arguments object.)
- On the remoteObject the function calls "call"[6] and passes on it's
parameter(s) in a remote-API compliant format.
- Lastly, to be able to call the ServerFunction on the client you need
to be able to reference it. I'm not yet sure what the best solution for
that would be. You could either expose the remoteObjects id on the
server-side ServerFunction[7][8], or you could give the function a name
in the constructor and add the function to the global namespace using
that name in the typeHandler, much like the BrowserFunction in the
Browsers loaded document.
I can't really go into much more detail without trying it out for
myself. If your method works for you that is fine too I guess.
Greetings,
Tim
[1]
http://download.eclipse.org/rt/rap/doc/2.2/guide/reference/api/org/eclipse/rap/rwt/remote/Connection.html#createRemoteObject%28java.lang.String%29
[2]
http://download.eclipse.org/rt/rap/doc/2.2/guide/reference/api/org/eclipse/rap/rwt/remote/RemoteObject.html#setHandler%28org.eclipse.rap.rwt.remote.OperationHandler%29
[3]
http://download.eclipse.org/rt/rap/doc/2.2/guide/reference/api/org/eclipse/rap/rwt/remote/OperationHandler.html#handleCall%28java.lang.String,%20org.eclipse.rap.json.JsonObject%29
[4]
http://download.eclipse.org/rt/rap/doc/2.2/guide/reference/jsdoc/symbols/rap.html#.registerTypeHandler
[5]
http://download.eclipse.org/rt/rap/doc/2.2/guide/reference/jsdoc/symbols/rap.html#.getRemoteObject
[6]
http://download.eclipse.org/rt/rap/doc/2.2/guide/reference/jsdoc/symbols/RemoteObject.html#call
[7]
http://download.eclipse.org/rt/rap/doc/2.2/guide/reference/api/org/eclipse/rap/rwt/remote/RemoteObject.html#getId%28%29
[8]
http://download.eclipse.org/rt/rap/doc/2.2/guide/reference/jsdoc/symbols/rap.html#.getObject
Tim Buschtöns
Current Time: Wed Jul 23 19:36:33 EDT 2025
Powered by FUDForum. Page generated in 0.06033 seconds
