Home » Modeling » TMF (Xtext) » Validation in xtext(Clarifications on Validation in xtext)
icon5.gif  Validation in xtext [message #1174947] Thu, 07 November 2013 07:16 Go to next message
Hi all,
For my language created from xtext grammar I have written some validation checks/methods. This is fine, it works perfectly for me. But I want something more,
1. When I launch my product(as Eclipse Application ) the validations checks are NOT CALLED. I want all the validation checks to be called when I launch my tool. But it happens only when I edit or do some stuff in my editor.
Problem with this: Last state of the editor is saved when I close my product, and if I write/update the validation checks, these things will not be called when I launch my tool next time and only will be called when I do something in the editor.
2. As soon as I start typing value for a field in the editor, the validation checks are called which results in errors. I don't want it to happen. I want to call the validation when typing is completed.
For e.g. say that I have a enum in my editor (enum_Sample=10) and I will be referring this at some other place. No doubt if I press (Ctrl + Space), I will get the content assist. But if I start typing "enum_Sample", untill its typed completely, for each character it will give me an error.
Thanks in advance for your help !! Smile Smile
Re: Validation in xtext [message #1174965 is a reply to message #1174947] Thu, 07 November 2013 07:32 Go to previous messageGo to next message
simply calling a project clean ? or do not persit the state?
icon5.gif  Re: Validation in xtext [message #1176005 is a reply to message #1174965] Thu, 07 November 2013 23:20 Go to previous messageGo to next message
Hi Christian,
But Can I call the validation checks when my tool is launched?
And can you help me with Point No. 2 that I have mentioned above.
Thanks in advance Smile
Re: Validation in xtext [message #1176200 is a reply to message #1176005] Fri, 08 November 2013 02:23 Go to previous messageGo to next message
Have no idea on that.
Need training, onsite consulting or any other kind of help for Xtext?
Go visit http://xtext.itemis.com or send a mail to xtext at itemis dot de
Re: Validation in xtext [message #1176224 is a reply to message #1176200] Fri, 08 November 2013 02:41 Go to previous messageGo to next message
P.S:
you can change the execution time of checks via
@Check(CheckType.YOUR_CHOICE)
icon5.gif  Re: Validation in xtext [message #1182381 is a reply to message #1176224] Tue, 12 November 2013 01:31 Go to previous messageGo to next message
Hi Chistian,
Thanks for your reply. It helped me. So I can use one among FAST, NORMAL and EXPENSIVE.
FAST and NORMAL are pretty clear to me. Could you please explain me a little about EXPENSIVE. It says "an action, which can be optionally generated for you DSL, explicitely evaluates EXPENSIVE constraints ". But I did not understand properly.
Re: Validation in xtext [message #1182415 is a reply to message #1182381] Tue, 12 November 2013 02:05 Go to previous messageGo to next message
Rightclick on the Open Editor with the file to validate -> then choose validate (note there a 2 validates - in my case it is the upper one)
Re: Validation in xtext [message #1182509 is a reply to message #1182381] Tue, 12 November 2013 03:29 Go to previous message
AFAIK, on uses the EXPENSIVE if the validation of some issues takes too long (who wants to wait 20 mins per save?).
So these need a manual invocation, as Dietrich explained.
Previous Topic:How to make the default value of "Literals Interface" to be "true"
Next Topic:Restrict Index (EObjectDescriptions)
Current Time: Sun Jul 27 03:53:57 EDT 2025
Powered by FUDForum. Page generated in 0.05677 seconds
