Home » Archived » Visual Editor (VE) » how to change the name of a generated constraint bean
how to change the name of a generated constraint bean [message #117525] Mon, 13 February 2006 11:17 Go to next message
Originally posted by: markus.wawra.shark-soft.com
Hi again!
I'm adding a new layout to VE. My problem is the following:
I want to let VE create a constraint bean for each object in the getJPanel
method (quite similar to what the GridBagLayout does).
First this constraint object was a common java.awt.Rectangle, which worked
pretty fine.
This code was created:
private JPanel getJPanel() {
if (jPanel == null) {
Rectangle rectangle = new Rectangle();
rectangle.height = 33;
rectangle.x = 101;
rectangle.y = 203;
rectangle.width = 73;
jPanel = new JPanel();
jPanel.setLayout(new MyLayout());
jPanel.add(getJButton(), rectangle);
return thirdPanel;
The next step was to write a new constraint class, let's call it
MyConstraints.
This ended in this code:
MyConstraints MyConstraints = new MyConstraints();
MyConstraints.setLeftEdge(101);
MyConstraints.setOtherThings;
jPanel.add(getJButton4(), MyConstraints);
return jPanel;
As you can see the created constraint bean is called MyConstraints,
starting with an upper-case character.
How can I change the (default) name of such constraints?
It would be sufficient to call it myConstraints, starting with a small
letter.
In the first case with the java.awt.Rectangle, the rectangle was created
automatically with a lower-case character. Also the GridBagLayout creates
gridBagConstraints, starting with a small letter.
Markus
Re: how to change the name of a generated constraint bean [message #117576 is a reply to message #117525] Mon, 13 February 2006 12:10 Go to previous messageGo to next message
Did you create the MyConstraints instance itself, or did you let it just
do it by default? If you created it yourself, did you add an Annotation
containing the name? It shouldn't of done that.
Rich Kulp
Re: how to change the name of a generated constraint bean [message #117809 is a reply to message #117576] Tue, 14 February 2006 08:47 Go to previous messageGo to next message
No I didn't add an Annotation.
How can I do that?
I searched for anything like that, but the only thing I found was
something in the RootPaneCreationPolicy. If I add that to my PolicyHelper
a dialogbox is opened where I can change the name of the constraint. That
ensures that it is named as I want, but I don't want a dialogbox like
that. It should be created directly.
Here are my methods of the MyLayoutPolicyHelper that create the
constraints (without the part of the RootPaneCreationPolicy). They are
built like the ones of GridBagLayout (and work perfectly if MyConstraints
is a java.awt.Rectangle):
public Command getChangeConstraintCommand(List children, List constraints)
RuledCommandBuilder cb = new RuledCommandBuilder(policy.getEditDomain());
Iterator childs = children.iterator();
Iterator consts = constraints.iterator();
while (childs.hasNext()) {
EObject child = (EObject) childs.next();
EObject constraintComponent =
InverseMaintenanceAdapter.getIntermediateReference((EObject)
policy.getContainer(), sfComponents, sfConstraintComponent, child);
Object oconstraint = consts.next();
if (oconstraint != NO_CONSTRAINT_VALUE) {
IJavaObjectInstance constraint = (oconstraint != null ?
convertConstraint(oconstraint) : null);
cb.applyAttributeSetting(constraintComponent, sfConstraintConstraint,
constraint);
} else
cb.cancelAttributeSetting(constraintComponent, sfConstraintConstraint);
return cb.getCommand();
protected IJavaObjectInstance convertConstraint(Object constraint) {
stConstraint = (MyConstraints) constraint;
MyConstraints defaultConstraint = new MyConstraints();
IJavaObjectInstance javaMyConstraint = (IJavaObjectInstance)
BeanUtilities.createJavaObject("new.layout.MyConstraints", rset,
(String)null);
if (stConstraint.getLeftEdgeAttachment() !=
defaultConstraint.getLeftEdgeAttachment()) {
Object left = BeanUtilities.createJavaObject(primInt, rset,
String.valueOf(stConstraint.getLeftEdge()));
javaMyConstraint.eSet(stleft, left);
//set other things in the same way
return javaMyConstraint;
Re: how to change the name of a generated constraint bean [message #117833 is a reply to message #117809] Tue, 14 February 2006 10:40 Go to previous messageGo to next message
I don't know why. If you can get into debug mode, try debugging into
org.eclipse.ve.internal.java.codegen.java.rules.InstanceVari ableCreationRule.getInstanceVariableName(EObject
obj, IType currentType, IVEModelInstance cm, IBeanDeclModel bdm)
There is a call to CDEUtilities.lowCaseFirstCharacter(name) within that
method. That is where it should of lower-cased it for you.
Maybe you can see why it didn't call this or why it returned it unchanged.
Rich Kulp
Re: how to change the name of a generated constraint bean [message #117845 is a reply to message #117833] Tue, 14 February 2006 11:09 Go to previous messageGo to next message
Is there also a way to add an Annotation as you mentioned in the earlier
posting?
A solution where I can set the default name in the PolicyHelper myself
would be better than just making a lower-case first character.
Markus
Re: how to change the name of a generated constraint bean [message #117855 is a reply to message #117845] Tue, 14 February 2006 11:55 Go to previous messageGo to next message
If you are at VE 1.2M1 there is a way, but at VE 1.1.0.1 there really
isn't a good way. But to be VE 1.2M1, you will need to step up to
Eclipse 3.2M4, GEF 3.2M4, and EMF 2.2M4 also.
This is how you would do it at VE1.2M1:
IJavaInstance javaInst = BeanUtilities.createJavaObject(...);
AnnotationLinkagePolicy policy = editDomain.getAnnotationLinkagePolicy();
Annotation annotation = AnnotationPolicy.createAnnotation(javaInst);
EStringToStringMapEntryImpl nameEntry = (EStringToStringMapEntryImpl)
EcoreFactory.eINSTANCE.create(EcorePackage.eINSTANCE.getEStr ingToStringMapEntry());
nameEntry.setKey(NameInCompositionPropertyDescriptor.NAME_IN _COMPOSITION_KEY);
nameEntry.setValue(NameInMemberPropertyDescriptor.FORCE_NAME _IN_COMPOSITION_PREFIX+ "nameIwant");
//$NON-NLS-1$
annotation.getKeyedValues().add(nameEntry);
policy.setModelOnAnnotation(javaInst, annotation);
> posting?
> Regards,
> Markus
Rich Kulp
Re: how to change the name of a generated constraint bean [message #117949 is a reply to message #117855] Wed, 15 February 2006 09:34 Go to previous messageGo to next message
Since I'm using VE 1.1.0.1 I had to keep searching for the problem why no
lower-case character was created. And I found it.
The hint to look in
was very good.
The name of a bean class you want to use in the VE must not start with 3
or more upper-case characters!
Thanks for your help,
Markus
Re: how to change the name of a generated constraint bean [message #117998 is a reply to message #117949] Wed, 15 February 2006 10:52 Go to previous messageGo to next message
I'm confused. Your example didn't have three upper-cases (MyConstraint).
That is only one uppercase.
> no lower-case character was created. And I found it.
> The hint to look in
> was very good.
> Markus
Rich Kulp
Re: how to change the name of a generated constraint bean [message #118104 is a reply to message #117998] Thu, 16 February 2006 07:56 Go to previous messageGo to next message
Sure!
I tried different things. First I had constraints called
TestNullConstraints, which was a simple subclass of java.awt.Rectangle. It
didn't work for other reasons, which I do not search anymore since I don't
need them. It was just a first test.
For the layout I actually need, I had a class called STFramingSpec which
starts with 3 upper-cases. Now it's just called FramingSpec and that works.
In my posting I wrote MyConstraints to keep it simple and easier to read.
Bad mistake obviously, which I will not make once more. I didn't expect
that it's the name that makes the problems, but hoped that I can set the
created name somewhere. I'm very sorry for that!
Markus
Re: how to change the name of a generated constraint bean [message #118124 is a reply to message #118104] Thu, 16 February 2006 09:37 Go to previous message
No problem. I'm just glad it is working ok now.
Rich Kulp
Re: how to change the name of a generated constraint bean [message #612097 is a reply to message #117525] Mon, 13 February 2006 12:10 Go to previous message
Rich Kulp
Re: how to change the name of a generated constraint bean [message #612102 is a reply to message #117576] Tue, 14 February 2006 08:47 Go to previous message
How can I do that?
constraint);
} else
(String)null);
Re: how to change the name of a generated constraint bean [message #612104 is a reply to message #117809] Tue, 14 February 2006 10:40 Go to previous message
Rich Kulp
Re: how to change the name of a generated constraint bean [message #612105 is a reply to message #117833] Tue, 14 February 2006 11:09 Go to previous message
posting?
Markus
Re: how to change the name of a generated constraint bean [message #612106 is a reply to message #117845] Tue, 14 February 2006 11:55 Go to previous message
//$NON-NLS-1$
> posting?
> Regards,
> Markus
Rich Kulp
Re: how to change the name of a generated constraint bean [message #612113 is a reply to message #117855] Wed, 15 February 2006 09:34 Go to previous message
The hint to look in
was very good.
Markus
Re: how to change the name of a generated constraint bean [message #612117 is a reply to message #117949] Wed, 15 February 2006 10:52 Go to previous message
> The hint to look in
> was very good.
> Markus
Rich Kulp
Re: how to change the name of a generated constraint bean [message #612126 is a reply to message #117998] Thu, 16 February 2006 07:56 Go to previous message
Sure!
Markus
Re: how to change the name of a generated constraint bean [message #612128 is a reply to message #118104] Thu, 16 February 2006 09:37 Go to previous message
Rich Kulp
Previous Topic:Parse Error and partial solution
Next Topic:replacing or extending overrides
Current Time: Mon Nov 10 10:50:41 EST 2025
Powered by FUDForum. Page generated in 0.36969 seconds
