Home » Eclipse Projects » Eclipse Scout » ServerTestApplication, JUnitServerJob and scheduling...
ServerTestApplication, JUnitServerJob and scheduling... [message #1175001] Thu, 07 November 2013 08:04 Go to next message
I have a MyAppServerTestApplication with follwing code:
 public class MyServerTestApplication implements IApplication {
  public Object start(IApplicationContext context) throws Exception {
    //perform test and exist:
    new JUnitServerJob().schedule();
    return IApplication.EXIT_OK;
  public void stop() {
As recommended by the Javadoc of JUnitServerJob.
When I try to run my test application, I get a null pointer exception at:
JUnitTestClassBrowser:105 - Corresponding line:
for (Bundle bundle : Activator.getDefault().getBundle().getBundleContext().getBundles()) {
The complete stack trace is visible in the some INIT xml file in the test result folder.
It seems to me the thread that executes the tests comes too late. The main thread (where the application is started) does not wait enough, and one of the call (getBundleContext() or getBundles() returns null)...
Because I do not know the Eclipse Jobs very well, I have modified the code of the ServerTest application:
  JUnitServerJob job = new JUnitServerJob();
  job.schedule();
  job.join();
1/ is this a good idea to add a join() call?
2/ how can I debug (without influencing the execution with my breakpoints)?
Thanks in advance.
Re: ServerTestApplication, JUnitServerJob and scheduling... [message #1175190 is a reply to message #1175001] Thu, 07 November 2013 10:35 Go to previous messageGo to next message
Hi Jérémie,
1/ Using job.join() is the correct solution.
2/ You can also use sysout but this also has some impact. I prefer using the breakpoints and manually release thread by thread to ensure I reproduce the situation I want to.
regards,
m
Re: ServerTestApplication, JUnitServerJob and scheduling... [message #1175210 is a reply to message #1175190] Thu, 07 November 2013 10:48 Go to previous messageGo to next message
I just had a look at the JavaDoc of the IApplication#stop() method.
Maybe I should put the join() call there...
Re: ServerTestApplication, JUnitServerJob and scheduling... [message #1175222 is a reply to message #1175210] Thu, 07 November 2013 10:56 Go to previous message
Ok, IApplication#start(IApplicationContext) seems also to be better:
"this method must not exit until the application is finished and is ready to exit."
Previous Topic:Not sure if we've found an SDK bug
Next Topic:Force RadioButtonGroup to re-read its values from LookupCall
Current Time: Sun Jul 20 21:18:27 EDT 2025
Powered by FUDForum. Page generated in 0.09552 seconds
