Requirements with "no pure text" as Description [message #1174790] |
Thu, 07 November 2013 05:09  |
as my specification is not limited to pure textual requirements, I need to have the "description" more variable.
Assume one requirement to be, that a digital out should reflect a digital input. This is easy to define as a pure textual requirement. This would "give" a requirement as
"The level of Output Pin xyz shall reflect the level at Input Pin abc" - no problem to define this requirement (just typing work).
Another requirement might be, that a digital counter shall increment in a non-linear relation to a timescale, most easy and most precise defined by a diagram. Can I include this diagram as a picture (jpg, bmp,..) into the specification in same colum like the plain text in the first assumption? Do I need a separate column for non textual requirements and what kind of datatype do I have to use (it is neither one of the selectable ones of string, boolean, integer, real, date, enummeration or XHTML)...
Thanks a lot and best regards
Carlhermann
Re: Requirements with "no pure text" as Description [message #1176461 is a reply to message #1174790] |
Fri, 08 November 2013 05:49  |
Hello Carlhermann,
No, you don't. But you need two SpecObjectTypes. This is how I would realize this: For each of the two scenarios (plain text and picture), create a dedicated SpecType. Both have an Attribute with the same name (e.g. Description). But these can have different types, e.g. plain text in the first case and XHTML in the second case. As the two attributes have the same name, they will be shown in the same column (in this example in the column named "Description").
If I understand correctly, you want a "new" datatype that renders your model element, realized as a custom presentation, right? But you would still use a standard datatype (typically plain text) to store the reference to the element you want to show. You would then activate the presentation, so that something else is rendered (typically the content of the referenced element).
This idea is elaborated here: http://formalmind.com/en/blog/using-rmf-integrate-your-models
Hope this helps!
- Michael
FUDForum. Page generated in 0.32323 seconds
