Home » Eclipse Projects » Remote Application Platform (RAP) » Not Well-Formed HttpServletResponse with custom widget
Not Well-Formed HttpServletResponse with custom widget [message #117276] Tue, 30 December 2008 05:47 Go to next message
We wrote a custom widget.
( http://help.eclipse.org/ganymede/topic/org.eclipse.rap.help/ help/html/advanced/custom-widget.html)
But if the widget is active the web developer plugin for Firefox show the
following JavaScript error. I don't thing that this is an error of the
custom widget.
Error: not well-formed
Source File:
http://localhost:8080/myprojekt/start?nocache=1230626390820& amp;custom_service_handler=org.eclipse.rwt.internal.lifecycl e.UICallBackServiceHandler
Line: 1, Column: 36
Source Code:
org.eclipse.swt.Request.getInstance().send();org.eclipse.swt .Request.getInstance().enableUICallBack(
"start","custom_service_handler","org.eclipse.rwt.internal.lifecycle.UICallBackServiceHandler "
org.eclipse.rap.rwt_1.1.1.20080917-1625.jar
The servletresponse is build in
UICallBackServiceHandler.jsUICallBack()
Thanks for your help.
Regards, Marcus
Re: Not Well-Formed HttpServletResponse with custom widget [message #117415 is a reply to message #117276] Mon, 05 January 2009 07:06 Go to previous messageGo to next message
marcus wrote:
> Hi
> the following JavaScript error. I don't thing that this is an error of
> the custom widget.
You activate it - it fails? My guess is that it's the custom widget.
Did you try without the web developer plugin? Or with another browser?
> Source File:
> Line: 1, Column: 36
> Source Code:
> Regards, Marcus
Re: Not Well-Formed HttpServletResponse with custom widget [message #117566 is a reply to message #117415] Tue, 06 January 2009 03:07 Go to previous messageGo to next message
Rüdiger Herrmann wrote:
> marcus wrote:
>> Hi
>> the custom widget.
I have noticed that the error console is part of Firefox (Tools -> Error
Console). Nevertheless, I turned off all the plugins in Firefox.
The Error appears only in the error console of Firefox .
I tried it with IE 7 and Opera 9.6. The error console (Tools -> Advanced
-> Error Console) of Opera does not show this error and IE has no
javascript console.
Maybe it is a Firefox bug.
>> Source File:
http://localhost:8080/myproject/start?nocache=1230626390820& amp;custom_service_handler=org.eclipse.rwt.internal.lifecycl e.UICallBackServiceHandler
>> Line: 1, Column: 36
>> Source Code:
>> Regards, Marcus
Re: Not Well-Formed HttpServletResponse with custom widget [message #117695 is a reply to message #117566] Tue, 06 January 2009 16:07 Go to previous messageGo to next message
I've seen the same error in Firefox 3.x on Mac OS X - it occurs when any
control is using UICallBack, and it's only on the response from
Having a snoop at the HTTP traffic, there's no Content-Type set on the
response from UICallBackServiceHandler, which could be the cause of the
error message.
There's also no Content-Length either, as there is in the standard event
loop responses, so it looks like it's using a different code path to serve
the JS.
A fix is probably as simple as adding in a Content-Type header (the lack of
Content-Length isn't a big issue, as Tomcat etc. will just chunk encode the
response).
cheers
tim
On 6/01/09 9:07 PM, in article
9ca13e2fc7edb1c6ffdc4897d7cf0241$1@www.eclipse.org, "marcus"
>> marcus wrote:
>>> Hi
>>> the custom widget.
> javascript console.
>>> Source File:
> dler=org.eclipse.rwt.internal.lifecycle.UICallBackServiceHan dler
>>> Line: 1, Column: 36
>>> Source Code:
> kServiceHandler"
>>> Regards, Marcus
Re: Not Well-Formed HttpServletResponse with custom widget [message #117719 is a reply to message #117695] Tue, 06 January 2009 16:43 Go to previous messageGo to next message
Tim,
thanks for the hint. A quick glance at the code seems to affirm your
assumption about the different code paths. You could file a bugzilla
to keep track of it.
Rüdiger
> error message.
> the JS.
> response).
> cheers
> tim
>>> marcus wrote:
>>>> Hi
>>>> the custom widget.
>> javascript console.
>>>> Source File:
>>>> Line: 1, Column: 36
>>>> Source Code:
>> kServiceHandler"
>>>> Regards, Marcus
Re: Not Well-Formed HttpServletResponse with custom widget [message #117731 is a reply to message #117719] Tue, 06 January 2009 17:43 Go to previous message
On 7/01/09 10:43 AM, in article gk0ja5$q8o$1@build.eclipse.org, "Rüdiger
Herrmann" <rherrmann@eclipsesource.com> wrote:
> Tim,
> Cheers,
> Rüdiger
https://bugs.eclipse.org/bugs/show_bug.cgi?id=260116
(and https://bugs.eclipse.org/bugs/show_bug.cgi?id=260117 for good measure).
tim
Previous Topic:Undefined key: 'text.SINGLE.padding' in theme 'RAP Default Theme'
Next Topic:Typo in ActivityMessages class
Current Time: Sat Jul 26 12:05:25 EDT 2025
Powered by FUDForum. Page generated in 0.05138 seconds
