Home » Eclipse Projects » WindowBuilder » Using Automatic Data Binding wizard(Tip)
Using Automatic Data Binding wizard [message #1173284] Wed, 06 November 2013 07:14 Go to next message
I wanted to share one thing I have learned about the Automatic Data Binding wizard
(Help: WindowBuilder Pro User Guide > Wizards > SWT/JFace/RCP > Data Binding > Automatic Data Binding Wizard).
I created my project using SWT/JFace Java Project wizard.
When I chose extending the Composite class in the Automatic Data Binding wizard (i.e., I chose my SuperClass to be Composite rather than Shell) and did everything as directed, my program did not run; it threw a null pointer exception. When I chose a Shell class, the code ran fine. (I did not try extending Dialog; if it misses the code below, it needs to be added manually.)
The reason was that I was missing the realm code in my main(..) method.
My solution was to copy the code created by the wizard for the Shell case. Another source for this is the code of the tutorial
help: WindowBuilder Pro User Guide > Tutorials > SWT/JFace Data Binding Example.
The code can be found in
http://help.eclipse.org/kepler/topic/org.eclipse.wb.rcp.doc.user/html/features/swt/data_binding/DataBindingTest.zip
What I did, was replacing the code
                try {
                   MyClassName window = new MyClassName();
                    window.open();
                } catch (Exception e) {
                    e.printStackTrace();
by the code
        Display display = new Display();
        Realm.runWithDefault(SWTObservables.getRealm(display), new Runnable(){
            public void run(){
                try {
                    window.open();
in
main(..)
After that, everything worked fine.
[Updated on: Wed, 06 November 2013 07:16] by Moderator
Re: Using Automatic Data Binding wizard [message #1173386 is a reply to message #1173284] Wed, 06 November 2013 08:37 Go to previous messageGo to next message
The behavior you are seeing is quite intentional. Since Composites aren't intended to be main windows, WB does not generate any realm code for them. If you create a main window that uses data binding, WB will generate the realm code for you. If you create a main window without data binding or create a main() somewhere else, you need to create the data binding realm on your own. That would be a case where understanding the data binding framework itself is important.
Re: Using Automatic Data Binding wizard [message #1173478 is a reply to message #1173386] Wed, 06 November 2013 09:51 Go to previous message
Eric, Thanks!
I understand that the automatic data binding wizard did not know in which shell I would eventually embed my composite and thus could not insert the realm code in it.
I hope that my post may be helpful to beginning users like me.
Previous Topic:Unexpected internal error
Next Topic:Eclipse WindowBuilder
Current Time: Sun Jul 27 09:25:14 EDT 2025
Powered by FUDForum. Page generated in 0.07072 seconds
