Create EJB failed [message #117152] |
Thu, 07 July 2005 02:07 |
Originally posted by: tim.wuyts.ping.be
I installed WTP 0.7M5 on Eclipse 3.1 on a Linux machine. I tried to
create a simple EJB project, but when I try to add a EJB, I have two
problems:
1. the 'Source folder must be absolute' problem (mentionned elsewhere in
this newsgroup). I can get around that by putting in forward slashes.
2. When I click 'Finish' I get
'An error occured when Create EnterpriseJavaBean finished' (details below).
Any ideas?
Tim.
> ava.lang.reflect.InvocationTargetException
> at org.eclipse.jface.operation.ModalContext.runInCurrentThread( ModalContext.java:357)
> at org.eclipse.jface.operation.ModalContext.run(ModalContext.ja va:291)
> at org.eclipse.jface.wizard.WizardDialog.run(WizardDialog.java: 830)
> at org.eclipse.wst.common.frameworks.internal.ui.WTPWizard.perf ormFinish(WTPWizard.java:241)
> at org.eclipse.jface.wizard.WizardDialog.finishPressed(WizardDi alog.java:676)
> at org.eclipse.jface.wizard.WizardDialog.buttonPressed(WizardDi alog.java:349)
> at org.eclipse.jface.dialogs.Dialog$2.widgetSelected(Dialog.jav a:556)
> at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:90)
> at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :66)
> at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1021)
> at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:2867)
> at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2572)
> at org.eclipse.jface.window.Window.runEventLoop(Window.java:809 )
> at org.eclipse.jface.window.Window.open(Window.java:787)
> at org.eclipse.wst.common.navigator.internal.actions.WizardShor tcutAction.run(WizardShortcutAction.java:114)
> at org.eclipse.jface.action.Action.runWithEvent(Action.java:996 )
> at org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:538)
> at org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:488)
> at org.eclipse.jface.action.ActionContributionItem$5.handleEven t(ActionContributionItem.java:400)
> at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1699)
> at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1663)
> at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:367)
> at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:143)
> at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:103)
> at org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:226)
> at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:376)
> at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:163)
> at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:39)
> at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl.java:25)
> at java.lang.reflect.Method.invoke(Method.java:324)
> at org.eclipse.core.launcher.Main.invokeFramework(Main.java:334 )
> at org.eclipse.core.launcher.Main.basicRun(Main.java:278)
> at org.eclipse.core.launcher.Main.run(Main.java:973)
> at org.eclipse.core.launcher.Main.main(Main.java:948)
> Caused by: java.lang.NullPointerException
> at org.eclipse.jst.j2ee.ejb.annotations.internal.classgen.EjbBu ilder.createType(EjbBuilder.java:307)
> at org.eclipse.jst.j2ee.ejb.annotations.internal.xdoclet.provid er.XDocletAnnotationProvider.generateSession(XDocletAnnotati onProvider.java:112)
> at org.eclipse.jst.j2ee.ejb.annotation.internal.operations.AddS essionBeanOperation.execute(AddSessionBeanOperation.java:43)
> at org.eclipse.jst.j2ee.ejb.annotation.internal.operations.AddE jbOperation.createEjb(AddEjbOperation.java:42)
> at org.eclipse.jst.j2ee.ejb.annotation.internal.operations.AddE jbOperation.execute(AddEjbOperation.java:33)
> at org.eclipse.wst.common.frameworks.internal.operations.WTPOpe ration.doRun(WTPOperation.java:336)
> at org.eclipse.wst.common.frameworks.internal.operations.WTPOpe ration$1.run(WTPOperation.java:248)
> at org.eclipse.core.internal.resources.Workspace.run(Workspace. java:1719)
> at org.eclipse.core.internal.resources.Workspace.run(Workspace. java:1739)
> at org.eclipse.wst.common.frameworks.internal.operations.WTPOpe ration.run(WTPOperation.java:266)
> at org.eclipse.wst.common.frameworks.internal.ui.RunnableWithPr ogressWrapper.run(RunnableWithProgressWrapper.java:65)
> at org.eclipse.jface.operation.ModalContext.runInCurrentThread( ModalContext.java:346)
> ... 38 more
FUDForum. Page generated in 0.03542 seconds
