| Home » Language IDEs » ServerTools (WTP) » The server may already be running in another process, or a system process may be using the port.
 Goto Forum:|
| The server may already be running in another process, or a system process may be using the port. [message #116932] | Wed, 06 July 2005 14:46  |  |
| Eclipse User  |  |  |  |  | Originally posted by: dkantala.modulant.com
 I use to be able to start a tomcat server without any issues.  Now I am
 consistently running into this problem.   If I get this message when
 starting the server, I am always given that message when I keep trying.
 I have to restart eclipse so that the server will start.  Now even after
 I restart eclipse I constantly get that message.  I have run netstat to
 determine if any other application is using that port and none are.  Any
 help on this would be appricieated.  I would rather start/stop server
 from within eclipse than to do it externally.
| Re: The server may already be running in another process, or a system process may be using the port. [message #117443 is a reply to message #117410] | Thu, 07 July 2005 09:55   |  |
 --------------040305030408060409010505
 I meant to attach my configuration details with the last message
 Dmytro Kantala wrote:
 > Operating System is Windows XP Service Pack 2
 > Here is my configuration Details:
 > Eclipse SDK 3.1.0 Build id: I20050627-1435
 > EMF SDK 2.1.0.I200506230200
 > GEF SDK 3.1.0
 > J2EE Standard Tools Feature and Web Standard Tools Feature SDK 0.7.0
 > Java EMF Model SDK 1.1.0
 > Visual Editor SDK 1.0.2.1
 > Additional plugins that may or may not effect the server:
 > QuantumDB 3.0.0
 > Eclipse-Games 3.1.0
 > VSS Plugin 1.6.1
 > SYSDEO 3.1.0.beta (this does launch Tomcat fine)
 > I am using Tomcat 5.5 on JRE 1.5
 > I did not setup a generic server, I used the one located under Apache.
 > Tomcat is installed in default location:  C:\Program Files\Apache
 > Software Foundation\Tomcat 5.5
 > Eclipse is installed at C:\eclipse
 > Workspace I am using is within eclipse folder
 > Larry Isaacs wrote:
 >> What are the details of WTP and the system you are running?
 >> Larry
 >>> am consistently running into this problem.   If I get this message
 >>> when starting the server, I am always given that message when I keep
 >>> trying. I have to restart eclipse so that the server will start.  Now
 >>> even after I restart eclipse I constantly get that message.  I have
 >>> run netstat to determine if any other application is using that port
 >>> and none are.  Any help on this would be appricieated.  I would
 >>> rather start/stop server from within eclipse than to do it externally.
 >>> Thanks
 name="details.txt"
 Content-Transfer-Encoding: quoted-printable
 Content-Disposition: inline;
 filename="details.txt"
 *** Date: Thu Jul 07 09:50:38 EDT 2005
 *** Platform Details:
 *** System properties:
 awt.toolkit=3Dsun.awt.windows.WToolkit
 eclipse.application=3Dorg.eclipse.ui.ide.workbench
 eclipse.buildId=3DI20050627-1435
 eclipse.commands=3D-os
 win32
 -ws
 win32
 -arch
 x86
 -launcher
 C:\eclipse\eclipse.exe
 -name
 Eclipse
 -showsplash
 600
 -exitdata
 3f0_60
 -data
 C:\eclipse\workspace
 -vm
 C:\WINDOWS\system32\javaw.exe
 eclipse.product=3Dorg.eclipse.sdk.ide
 eclipse.startTime=3D1120740896931
 eclipse.vm=3DC:\WINDOWS\system32\javaw.exe
 eclipse.vmargs=3D-Xms40m
 -Xmx256m
 -jar
 C:\eclipse\startup.jar
 eof=3Deof
 file.encoding=3DCp1252
 file.encoding.pkg=3Dsun.io
 file.separator=3D\
 java.awt.graphicsenv=3Dsun.awt.Win32GraphicsEnvironment
 java.awt.printerjob=3Dsun.awt.windows.WPrinterJob
 java.class.path=3DC:\eclipse\startup.jar
 java.class.version=3D49.0
 java.endorsed.dirs=3DC:\Program Files\Java\jre1.5.0_02\lib\endorsed
 java.ext.dirs=3DC:\Program Files\Java\jre1.5.0_02\lib\ext
 java.home=3DC:\Program Files\Java\jre1.5.0_02
 java.io.tmpdir=3DC:\DOCUME~1\dkantala\LOCALS~1\Temp\
 java.library.path=3DC:\WINDOWS\system32;.;C:\WINDOWS\system3 2;C:\WINDOWS;=
 C:\oracle\ora81\bin;C:\oracle\ora81\Apache\Perl\5.00503\bin\ mswin32-x86;C=
 :\Program  Files\Oracle\jre\1.1.7\bin;C:\WINDOWS\system32;C:\WINDOWS;C: \WI=
 NDOWS\System32\Wbem;C:\Program Files\Microsoft SQL Server\80\Tools\BINN;C=
 :\Program Files\JProbe Profiler 5.2.1\bin
 java.runtime.name=3DJava(TM) 2 Runtime Environment, Standard Edition
 java.runtime.version=3D1.5.0_02-b09
 java.specification.name=3DJava Platform API Specification
 java.specification.vendor=3DSun Microsystems Inc.
 java.specification.version=3D1.5
 java.vendor=3DSun Microsystems Inc.
 java.vendor.url=3Dhttp://java.sun.com/
 java.vendor.url.bug=3Dhttp://java.sun.com/cgi-bin/bugreport.cgi
 java.version=3D1.5.0_02
 java.vm.info=3Dmixed mode, sharing
 java.vm.name=3DJava HotSpot(TM) Client VM
 java.vm.specification.name=3DJava Virtual Machine Specification
 java.vm.specification.vendor=3DSun Microsystems Inc.
 java.vm.specification.version=3D1.0
 java.vm.vendor=3DSun Microsystems Inc.
 java.vm.version=3D1.5.0_02-b09
 line.separator=3D
 org.eclipse.jdt.debug.ui.debuggerActive=3Dfalse
 org.eclipse.jdt.debug.ui.instanceof.IJavaStackFrame=3Dfalse
 org.eclipse.jdt.debug.ui.scrapbookActive=3Dfalse
 org.osgi.framework.bootdelegation=3D*
 org.osgi.framework.executionenvironment=3DJ2SE-1.5
 org.osgi.framework.language=3Den
 org.osgi.framework.os.name=3DWindowsXP
 org.osgi.framework.os.version=3D5.1
 org.osgi.framework.processor=3Dx86
 org.osgi.framework.system.packages=3Djavax.accessibility,jav ax.activity,j=
 avax.crypto,javax.crypto.interfaces,javax.crypto.spec,javax. imageio,javax=
 =2Eimageio.event,javax.imageio.metadata,javax.imageio.plugin s.bmp,javax.i=
 mageio.plugins.jpeg,javax.imageio.spi,javax.imageio.stream,j avax.manageme=
 nt,javax.management.loading,javax.management.modelmbean,java x.management.=
 monitor,javax.management.openmbean,javax.management.relation ,javax.manage=
 ment.remote,javax.management.remote.rmi,javax.management.tim er,javax.nami=
 ng,javax.naming.directory,javax.naming.event,javax.naming.ld ap,javax.nami=
 ng.spi,javax.net,javax.net.ssl,javax.print,javax.print.attri bute,javax.pr=
 int.attribute.standard,javax.print.event,javax.rmi,javax.rmi .CORBA,javax.=
 rmi.ssl,javax.security.auth,javax.security.auth.callback,jav ax.security.a=
 uth.kerberos,javax.security.auth.login,javax.security.auth.s pi,javax.secu=
 rity.auth.x500,javax.security.cert,javax.security.sasl,javax .sound.midi,j=
 avax.sound.midi.spi,javax.sound.sampled,javax.sound.sampled. spi,javax.sql=
 ,javax.sql.rowset,javax.sql.rowset.serial,javax.sql.rowset.s pi,javax.swin=
 g,javax.swing.border,javax.swing.colorchooser,javax.swing.ev ent,javax.swi=
 ng.filechooser,javax.swing.plaf,javax.swing.plaf.basic,javax .swing.plaf.m=
 etal,javax.swing.plaf.multi,javax.swing.plaf.synth,javax.swi ng.table,java=
 x.swing.text,javax.swing.text.html,javax.swing.text.html.par ser,javax.swi=
 ng.text.rtf,javax.swing.tree,javax.swing.undo,javax.transact ion,javax.tra=
 nsaction.xa,javax.xml,javax.xml.datatype,javax.xml.namespace ,javax.xml.pa=
 rsers,javax.xml.transform,javax.xml.transform.dom,javax.xml. transform.sax=
 ,javax.xml.transform.stream,javax.xml.validation,javax.xml.x path,org.ietf=
 =2Ejgss,org.omg.CORBA,org.omg.CORBA_2_3,org.omg.CORBA_2_3.po rtable,org.om=
 g.CORBA.DynAnyPackage,org.omg.CORBA.ORBPackage,org.omg.CORBA .portable,org=
 =2Eomg.CORBA.TypeCodePackage,org.omg.CosNaming,org.omg.CosNa ming.NamingCo=
 ntextExtPackage,org.omg.CosNaming.NamingContextPackage,org.o mg.Dynamic,or=
 g.omg.DynamicAny,org.omg.DynamicAny.DynAnyFactoryPackage,org .omg.DynamicA=
 ny.DynAnyPackage,org.omg.IOP,org.omg.IOP.CodecFactoryPackage ,org.omg.IOP.=
 CodecPackage,org.omg.Messaging,org.omg.PortableInterceptor,o rg.omg.Portab=
 leInterceptor.ORBInitInfoPackage,org.omg.PortableServer,org. omg.PortableS=
 erver.CurrentPackage,org.omg.PortableServer.POAManagerPackag e,org.omg.Por=
 tableServer.POAPackage,org.omg.PortableServer.portable,org.o mg.PortableSe=
 rver.ServantLocatorPackage,org.omg.SendingContext,org.omg.st ub.java.rmi,o=
 rg.w3c.dom,org.w3c.dom.bootstrap,org.w3c.dom.events,org.w3c. dom.ls,org.xm=
 l.sax,org.xml.sax.ext,org.xml.sax.helpers
 org.osgi.framework.vendor=3DEclipse
 org.osgi.framework.version=3D1.3.0
 org.osgi.supports.framework.extension=3Dtrue
 os.arch=3Dx86
 os.name=3DWindows XP
 os.version=3D5.1
 osgi.arch=3Dx86
 osgi.bundles=3Dorg.eclipse.core.runtime@2:start, org.eclipse.update.confi=
 gurator@3:start
 osgi.bundlestore=3Dc:\eclipse\configuration\org.eclipse.osgi \bundles
 osgi.configuration.area=3Dfile:/c:/eclipse/configuration/
 osgi.framework=3Dfile:/c:/eclipse/plugins/org.eclipse.osgi_3 .1.0.jar
 osgi.framework.beginningstartlevel=3D1
 osgi.framework.shape=3Djar
 osgi.framework.version=3D3.0.0
 osgi.install.area=3Dfile:/c:/eclipse/
 osgi.instance.area=3Dfile:/C:/eclipse/workspace/
 osgi.instance.area.default=3Dfile:/C:/Documents and Settings/dkantala/wor=
 kspace/
 osgi.logfile=3DC:\eclipse\workspace\.metadata\.log
 osgi.manifest.cache=3Dc:\eclipse\configuration\org.eclipse.o sgi\manifests=
 osgi.nl=3Den_US
 osgi.os=3Dwin32
 osgi.splashLocation=3Dc:\eclipse\plugins\org.eclipse.platfor m_3.1.0\splas=
 osgi.splashPath=3Dplatform:/base/plugins/org.eclipse.platfor m
 osgi.syspath=3Dc:\eclipse\plugins
 osgi.ws=3Dwin32
 path.separator=3D;
 sun.arch.data.model=3D32
 sun.boot.class.path=3DC:\Program Files\Java\jre1.5.0_02\lib\rt.jar;C:\Pro=
 gram Files\Java\jre1.5.0_02\lib\i18n.jar;C:\Program Files\Java\jre1.5.0_0=
 2\lib\sunrsasign.jar;C:\Program Files\Java\jre1.5.0_02\lib\jsse.jar;C:\Pr=
 ogram Files\Java\jre1.5.0_02\lib\jce.jar;C:\Program Files\Java\jre1.5.0_0=
 2\lib\charsets.jar;C:\Program Files\Java\jre1.5.0_02\classes
 sun.boot.library.path=3DC:\Program Files\Java\jre1.5.0_02\bin
 sun.cpu.endian=3Dlittle
 sun.cpu.isalist=3D
 sun.desktop=3Dwindows
 sun.io.unicode.encoding=3DUnicodeLittle
 sun.jnu.encoding=3DCp1252
 sun.management.compiler=3DHotSpot Client Compiler
 sun.os.patch.level=3DService Pack 2
 user.country=3DUS
 user.dir=3DC:\eclipse
 user.home=3DC:\Documents and Settings\dkantala
 user.language=3Den
 user.name=3Ddkantala
 user.timezone=3DAmerica/New_York
 user.variant=3D
 *** Features:
 es.org.chemi.games (3.1.0) "Eclipse-Games"
 org.eclipse.emf (2.1.0.I200506230200) "Eclipse Modeling Framework (EMF)"
 org.eclipse.emf.doc (2.1.0.I200506230200) "Eclipse Modeling Framework (EM=
 F) Programmers Guide"
 org.eclipse.emf.ecore.sdo (2.1.0.I200506230200) "EMF Service Data Objects=
 (SDO)"
 org.eclipse.emf.ecore.sdo.doc (2.1.0.I200506230200) "EMF Service Data Obj=
 ects (SDO) Programmers Guide"
 org.eclipse.emf.ecore.sdo.source (2.1.0.I200506230200) "EMF Service Data =
 Objects (SDO) Source"
 org.eclipse.emf.examples (2.0.1) "Examples for Eclipse Modeling Framework=
 (EMF)"
 org.eclipse.emf.source (2.1.0.I200506230200) "Eclipse Modeling Framework =
 (EMF) Source"
 org.eclipse.gef (3.1.0) "Graphical Editing Framework"
 org.eclipse.gef.examples (3.0.1) "GEF Examples"
 org.eclipse.gef.sdk (3.1.0) "Graphical Editing Framework Developer Resour=
 ces"
 org.eclipse.gef.source (3.1.0) "Graphical Editing Framework Developer Res=
 ources"
 org.eclipse.jdt (3.1.0) "Eclipse Java Development Tools"
 org.eclipse.jdt.source (3.1.0) "Eclipse Java Development Tools SDK"
 org.eclipse.jem (1.1.0) "Java EMF Model"
 org.eclipse.jem.sdk (1.1.0) "Java EMF Model SDK"
 org.eclipse.jem.source (1.1.0) "Java EMF Model Source"
 org.eclipse.pde (3.1.0) "Eclipse Plug-in Development Environment"
 org.eclipse.pde.source (3.1.0) "Eclipse Plug-in Development Environment D=
 eveloper Resources"
 org.eclipse.platform (3.1.0) "Eclipse Platform"
 org.eclipse.platform.source (3.1.0) "Eclipse Platform Plug-in Developer R=
 esources"
 org.eclipse.rcp (3.1.0) "Eclipse RCP"
 org.eclipse.rcp.source (3.1.0) "Eclipse RCP Plug-in Developer Resources"
 org.eclipse.sdk (3.1.0) "Eclipse Project SDK"
 org.eclipse.ve (1.0.2.1) "Visual Editor"
 org.eclipse.ve.sdk (1.0.2.1) "Visual Editor SDK"
 org.eclipse.ve.source (1.0.2.1) "Visual Editor Source"
 org.eclipse.xsd (2.1.0.I200506230200) "XML Schema Infoset Model (XSD)"
 org.eclipse.xsd.doc (2.1.0.I200506230200) "XML Schema Infoset Model (XSD)=
 Programmers Guide"
 org.eclipse.xsd.source (2.1.0.I200506230200) "XML Schema Infoset Model (X=
 SD) Source"
 *** Plug-in Registry:
 com.ibm.etools.emf.event (3.0.0.1) "Event Model" [Resolved]
 com.ibm.wtp.common.util (1.0.1) "Logging Plug-in" [Resolved]
 com.ibm.wtp.emf.workbench (1.0.1.2) "EMF Workbench" [Resolved]
 com.quantum.dbunit (3.0.0) "QuantumDB DbUnit Plug-in" [Resolved]
 com.quantum.flatfiles (3.0.0) "QuantumDB Data Export-Import Plug-in" [Res=
 olved]
 com.quantum.help (3.0.0) "Help Plug-in" [Resolved]
 com.quantum.Quantum (3.0.0) "Quantum DB Utility" [Resolved]
 com.sysdeo.eclipse.tomcat (3.1.0.beta) "Tomcat Plugin" [Active]
 es.org.chemi.games (3.1.0) "Eclipse-Games" [Active]
 es.org.chemi.games.minesweeper (3.1.0) "Eclipse-Games Minesweeper Plugin"=
 [Resolved]
 es.org.chemi.games.minesweeper.help (3.1.0) "Eclipse-Games Minesweeper He=
 lp Plugin" [Resolved]
 es.org.chemi.games.minesweeper2 (3.1.0) "Eclipse-Games Minesweeper II Plu=
 gin" [Resolved]
 es.org.chemi.games.minesweeper2.help (3.1.0) "Eclipse-Games Minesweeper I=
 I Help Plugin" [Resolved]
 es.org.chemi.games.snake (3.1.0) "Eclipse-Games Snake Plugin" [Resolved]
 es.org.chemi.games.snake.help (3.1.0) "Eclipse-Games Snake Help Plugin" [=
 Resolved]
 es.org.chemi.games.sokoban (3.1.0) "Eclipse-Games Sokoban Plugin" [Active=
 es.org.chemi.games.sokoban.help (3.1.0) "Eclipse-Games Sokoban Help Plugi=
 n" [Resolved]
 org.apache.ant (1.6.5) "Apache Ant" [Resolved]
 org.apache.axis11 (1.1.0) "Apache Axis 1.1 Plug-in" [Resolved]
 org.apache.axis11 (0.7.0) "Apache Axis 1.1 Plug-in" [Resolved]
 org.apache.lucene (1.4.3) "Apache Lucene" [Resolved]
 org.apache.wsil4j (1.0.0) "Apache WSIL4J 1.0" [Resolved]
 org.apache.wsil4j (0.7.0) "Apache WSIL4J 1.0" [Resolved]
 org.apache.xerces (2.6.2) "Apache Xerces Content" [Resolved]
 org.eclipse.ant.core (3.1.0) "Ant Build Tool Core" [Resolved]
 org.eclipse.ant.ui (3.1.0) "Ant UI" [Resolved]
 org.eclipse.compare (3.1.0) "Compare Support" [Active]
 org.eclipse.core.boot (3.1.0) "Core Boot" [Resolved]
 org.eclipse.core.commands (3.1.0) "Commands" [Active]
 org.eclipse.core.expressions (3.1.0) "Expression Language" [Active]
 org.eclipse.core.filebuffers (3.1.0) "File Buffers" [Active]
 org.eclipse.core.resources (3.1.0) "Core Resource Management" [Active]
 org.eclipse.core.resources.compatibility (3.1.0) "Core Resource Managemen=
 t Compatibility Fragment" [Resolved]
 org.eclipse.core.resources.win32 (3.1.0) "Core Resource Management Win32 =
 org.eclipse.core.runtime (3.1.0) "Core Runtime" [Active]
 org.eclipse.core.runtime.compatibility (3.1.0) "Core Runtime Plug-in Comp=
 atibility" [Active]
 org.eclipse.core.variables (3.1.0) "Core Variables" [Resolved]
 org.eclipse.debug.core (3.1.0) "Debug Core" [Active]
 org.eclipse.debug.ui (3.1.0) "Debug UI" [Active]
 org.eclipse.draw2d (3.1.0) "Draw2d" [Resolved]
 org.eclipse.draw2d.doc.isv (3.1.0) "Draw2D Documentation" [Resolved]
 org.eclipse.emf (2.1.0) "Eclipse Modeling Framework (EMF)" [Resolved]
 org.eclipse.emf.activities (2.0.0) "EMF Activities" [Resolved]
 org.eclipse.emf.ant (2.1.0) "EMF Ant Tasks" [Resolved]
 org.eclipse.emf.codegen (2.1.0) "EMF Template Code Generator" [Resolved]
 org.eclipse.emf.codegen.ecore (2.1.0) "EMF Ecore Code Generation" [Resolv=
 ed]
 org.eclipse.emf.codegen.ecore.ui (2.1.0) "EMF Ecore Code Generation UI" [=
 Resolved]
 org.eclipse.emf.codegen.ui (2.1.0) "EMF Template Code Generator UI" [Reso=
 lved]
 org.eclipse.emf.common (2.1.0) "EMF Common" [Active]
 org.eclipse.emf.common.ui (2.1.0) "EMF Common UI" [Resolved]
 org.eclipse.emf.commonj.sdo (2.1.0) "CommonJ SDO" [Resolved]
 F) Programmers Guide" [Resolved]
 org.eclipse.emf.ecore (2.1.0) "EMF Ecore" [Active]
 org.eclipse.emf.ecore.change (2.1.0) "EMF Ecore Change Model" [Resolved]
 org.eclipse.emf.ecore.change.edit (2.1.0) "EMF Ecore Change Edit Support"=
 [Resolved]
 org.eclipse.emf.ecore.edit (2.1.0) "EMF Ecore Edit Support" [Resolved]
 org.eclipse.emf.ecore.editor (2.1.0) "Sample Ecore Editor" [Resolved]
 org.eclipse.emf.ecore.sdo (2.1.0) "EMF Service Data Objects (SDO)" [Resol=
 ved]
 ects (SDO) Programmers Guide" [Resolved]
 org.eclipse.emf.ecore.sdo.edit (2.1.0) "EMF Service Data Objects (SDO) Ed=
 org.eclipse.emf.ecore.sdo.editor (2.1.0) "EMF Service Data Objects (SDO) =
 Editor" [Resolved]
 Objects (SDO) Source" [Resolved]
 org.eclipse.emf.ecore.xmi (2.1.0) "EMF XMI" [Active]
 org.eclipse.emf.edit (2.1.0) "EMF Edit" [Active]
 org.eclipse.emf.edit.ui (2.1.0) "EMF Edit UI" [Active]
 (EMF)" [Resolved]
 org.eclipse.emf.importer (2.1.0) "EMF Model Import Support" [Resolved]
 org.eclipse.emf.importer.ecore (2.1.0) "EMF Ecore Importer" [Resolved]
 org.eclipse.emf.importer.java (2.1.0) "EMF Annotated Java Importer" [Reso=
 lved]
 org.eclipse.emf.importer.rose (2.1.0) "EMF Rose Importer" [Resolved]
 org.eclipse.emf.java (2.0.1) "EMF Java" [Resolved]
 org.eclipse.emf.java.edit (2.0.0) "EMF Java Edit" [Resolved]
 org.eclipse.emf.java.editor (2.0.1) "EMF Java Editor" [Resolved]
 org.eclipse.emf.mapping (2.1.0) "EMF Mapping" [Resolved]
 org.eclipse.emf.mapping.ecore2ecore (2.1.0) "Ecore to Ecore Mapping" [Res=
 olved]
 org.eclipse.emf.mapping.ecore2ecore.editor (2.1.0) "Ecore to Ecore Mappin=
 g Editor" [Resolved]
 org.eclipse.emf.mapping.ecore2xml (2.1.0) "Ecore to XML Mapping" [Resolve=
 d]
 org.eclipse.emf.mapping.ecore2xml.ui (2.1.0) "Ecore to XML Mapping UI" [R=
 esolved]
 org.eclipse.emf.mapping.ui (2.1.0) "EMF Mapping UI" [Resolved]
 org.eclipse.emf.mapping.xsd2ecore (2.1.0) "XSD to Ecore Mapping" [Resolve=
 d]
 org.eclipse.emf.mapping.xsd2ecore.editor (2.1.0) "XSD to Ecore Mapping Ed=
 itor" [Resolved]
 (EMF) Source" [Resolved]
 org.eclipse.gef (3.1.0) "Graphical Editing Framework" [Resolved]
 org.eclipse.gef.doc.isv (3.1.0) "Graphical Editing Framework Documentatio=
 n" [Resolved]
 org.eclipse.gef.examples.flow (3.0.1) "GEF Flow Editor Example" [Resolved=
 org.eclipse.gef.examples.logic (3.0.0) "GEF Logic Editor Example" [Resolv=
 ed]
 org.eclipse.gef.examples.source (3.0.1) "GEF Examples" [Resolved]
 ources" [Resolved]
 org.eclipse.help (3.1.0) "Help System Core" [Active]
 org.eclipse.help.appserver (3.1.0) "Help Application Server" [Resolved]
 org.eclipse.help.base (3.1.0) "Help System Base" [Resolved]
 org.eclipse.help.ui (3.1.0) "Help System UI" [Resolved]
 org.eclipse.help.webapp (3.1.0) "Help System Webapp" [Resolved]
 org.eclipse.jdt (3.1.0) "Eclipse Java Development Tools" [Resolved]
 org.eclipse.jdt.core (3.1.0) "Java Development Tools Core" [Active]
 org.eclipse.jdt.debug (3.1.0) "JDI Debug Model" [Active]
 org.eclipse.jdt.debug.ui (3.1.0) "JDI Debug UI" [Active]
 org.eclipse.jdt.doc.isv (3.1.0) "Eclipse JDT Plug-in Developer Guide" [Re=
 solved]
 org.eclipse.jdt.doc.user (3.1.0) "Eclipse Java Development User Guide" [R=
 esolved]
 org.eclipse.jdt.junit (3.1.0) "Java Development Tools JUnit support" [Act=
 ive]
 org.eclipse.jdt.junit.runtime (3.1.0) "Java Development Tools JUnit runti=
 me support" [Resolved]
 org.eclipse.jdt.launching (3.1.0) "Java Development Tools Launching Suppo=
 rt" [Active]
 org.eclipse.jdt.source (3.1.0) "Eclipse Java Development Tools SDK" [Reso=
 lved]
 org.eclipse.jdt.ui (3.1.0) "Java Development Tools UI" [Active]
 org.eclipse.jem (1.1.0) "Java EMF Model" [Active]
 org.eclipse.jem (1.0.2) "Java EMF Model" [Installed]
 org.eclipse.jem.beaninfo (1.1.0) "Java EMF Model BeanInfo (Introspection)=
 Support" [Resolved]
 org.eclipse.jem.beaninfo (1.0.2) "Java EMF Model BeanInfo (Introspection)=
 Support" [Installed]
 org.eclipse.jem.proxy (1.1.0) "Java EMF Model Proxy Support" [Resolved]
 org.eclipse.jem.proxy (1.0.2) "Java EMF Model Proxy Support" [Installed]
 org.eclipse.jem.sdk (1.1.0) "Java EMF Model SDK" [Resolved]
 org.eclipse.jem.sdk (1.0.1) "Java EMF Model SDK" [Resolved]
 org.eclipse.jem.source (1.1.0) "Java EMF Model Source" [Resolved]
 org.eclipse.jem.source (1.0.2.1) "Java EMF Model Source" [Installed]
 org.eclipse.jem.ui (1.1.0) "Java EMF Model UI" [Resolved]
 org.eclipse.jem.ui (1.0.1) "Java EMF Model UI" [Installed]
 org.eclipse.jem.util (1.1.0) "Java EMF Model Utilities" [Active]
 org.eclipse.jem.workbench (1.1.0) "Java EMF Model Workbench Support" [Act=
 ive]
 org.eclipse.jem.workbench (1.0.2) "Java EMF Model Workbench Support" [Ins=
 talled]
 org.eclipse.jface (3.1.0) "JFace" [Active]
 org.eclipse.jface.text (3.1.0) "JFace Text" [Active]
 org.eclipse.jst.common.annotations.controller (0.7.0) "Annotation Control=
 ler Plug-in" [Resolved]
 org.eclipse.jst.common.annotations.core (0.7.0) "Annotation Core Plug-in"=
 [Resolved]
 org.eclipse.jst.common.annotations.ui (0.7.0) "Ui Plug-in" [Resolved]
 org.eclipse.jst.common.frameworks (0.7.0) "Integration Plug-in" [Resolved=
 org.eclipse.jst.common.navigator.java (0.7.0) "Navigator Plug-in" [Active=
 org.eclipse.jst.doc.isv (0.7.0) "JST ISV Documentation" [Resolved]
 org.eclipse.jst.doc.user (0.7.0) "JST User Doc Plug-in" [Resolved]
 org.eclipse.jst.ejb.ui (0.7.0) "WTP EJB UI Plug-in" [Resolved]
 org.eclipse.jst.j2ee (0.7.0) "J2EE Component" [Active]
 org.eclipse.jst.j2ee.core (0.7.0) "J2EE Core Component" [Active]
 org.eclipse.jst.j2ee.ejb (0.7.0) "EJB component Plug-in" [Active]
 org.eclipse.jst.j2ee.ejb.annotation.model (0.7.0) "EJB Annotation Model P=
 lug-in" [Resolved]
 org.eclipse.jst.j2ee.ejb.annotations.emitter (0.7.0) "EJB Emitter Plug-in=
 " [Resolved]
 org.eclipse.jst.j2ee.ejb.annotations.ui (0.7.0) "EJB Annotations Ui Plug-=
 in" [Resolved]
 org.eclipse.jst.j2ee.ejb.annotations.xdoclet (0.7.0) "Xdoclet Annotations=
 Plug-in" [Resolved]
 org.eclipse.jst.j2ee.jca (0.7.0) "JCA Plug-in" [Active]
 org.eclipse.jst.j2ee.jca.ui (0.7.0) "WTP JCA UI Plug-in" [Resolved]
 org.eclipse.jst.j2ee.navigator.ui (0.7.0) "J2EE Extensions to Common Navi=
 gator" [Active]
 org.eclipse.jst.j2ee.ui (0.7.0) "WTP J2EE UI Plug-in" [Active]
 org.eclipse.jst.j2ee.web (0.7.0) "Web Plug-in" [Active]
 org.eclipse.jst.j2ee.webservice (0.7.0) "Web Service Plug-in" [Active]
 org.eclipse.jst.j2ee.webservices.ui (0.7.0) "WTP Webservice UI Plug-in" [=
 Active]
 org.eclipse.jst.jsp.core (0.7.0) "Structured Source JSP Model" [Active]
 org.eclipse.jst.jsp.ui (0.7.0) "SSE JSP Source Editor" [Active]
 org.eclipse.jst.server.core (0.7.0) "Java Server Support" [Active]
 org.eclipse.jst.server.generic.core (0.7.0) "Generic Server Plugin" [Acti=
 ve]
 org.eclipse.jst.server.generic.serverdefinitions (0.7.0) "Generic server =
 example definitions" [Resolved]
 org.eclipse.jst.server.generic.ui (0.7.0) "Generic Server Plugin UI" [Act=
 ive]
 org.eclipse.jst.server.geronimo.core (0.7.0) "Geronimo server support" [R=
 esolved]
 org.eclipse.jst.server.geronimo.ui (0.7.0) "Geronimo server UI support" [=
 Resolved]
 org.eclipse.jst.server.tomcat.core (0.7.0) "Apache Tomcat Support" [Activ=
 e]
 org.eclipse.jst.server.tomcat.ui (0.7.0) "Apache Tomcat UI Support" [Reso=
 lved]
 org.eclipse.jst.server.ui (0.7.0) "Java Server UI Support" [Resolved]
 org.eclipse.jst.server.websphere.core (0.7.0) "WebSphere Generic Server D=
 efinition Core Plug-in" [Resolved]
 org.eclipse.jst.servlet.ui (0.7.0) "WTP Servlet UI Plug-in" [Resolved]
 org.eclipse.jst.source (0.7.0) "Webtools Platform J2EE Standard Tools Sou=
 rce (JST) Plug-in Developer Resources" [Resolved]
 org.eclipse.jst.ws (0.7.0) "Web Services" [Resolved]
 org.eclipse.jst.ws.axis.consumption.core (0.7.0) "Web service Axis Consum=
 ption Core" [Resolved]
 org.eclipse.jst.ws.axis.consumption.ui (0.7.0) "Webservice Axis Consumpti=
 on UI" [Resolved]
 org.eclipse.jst.ws.axis.creation.ui (0.7.0) "Webservice Axis Creation UI"=
 [Resolved]
 org.eclipse.jst.ws.consumption (0.7.0) "Web Services Consumption" [Resolv=
 ed]
 org.eclipse.jst.ws.consumption.ui (0.7.0) "Web Services Consumption Graph=
 ical User Interface" [Resolved]
 org.eclipse.jst.ws.creation.ejb.ui (0.7.0) "Web Services Creation EJB Gra=
 phical User Interface" [Resolved]
 org.eclipse.jst.ws.creation.ui (0.7.0) "Web Services Creation Graphical U=
 org.eclipse.jst.ws.uddiregistry (0.7.0) "Web Services Universal Descripti=
 on Discovery and Integration Registry" [Resolved]
 org.eclipse.jst.ws.ui (0.7.0) "Web Services Graphical User Interface" [Re=
 solved]
 org.eclipse.ltk.core.refactoring (3.1.0) "Refactoring Core" [Active]
 org.eclipse.ltk.ui.refactoring (3.1.0) "Refactoring UI" [Active]
 org.eclipse.osgi.services (3.1.0) "OSGi Release 3 Services" [Resolved]
 org.eclipse.osgi.util (3.1.0) "OSGi R3 Utility Classes" [Resolved]
 org.eclipse.pde (3.1.0) "Eclipse Plug-in Development Environment" [Resolv=
 ed]
 org.eclipse.pde.build (3.1.0) "Plug-in Development Environment Build Supp=
 ort" [Resolved]
 org.eclipse.pde.core (3.1.0) "Plug-in Development Core" [Active]
 org.eclipse.pde.doc.user (3.1.0) "Eclipse Plug-in Development User Guide"=
 [Resolved]
 org.eclipse.pde.junit.runtime (3.1.0) "PDE JUnit Plug-in Test" [Resolved]=
 org.eclipse.pde.runtime (3.1.0) "Plug-in Development Environment Runtime"=
 [Resolved]
 org.eclipse.pde.ui (3.1.0) "Plug-in Development UI" [Active]
 org.eclipse.platform (3.1.0) "Eclipse Platform" [Resolved]
 org.eclipse.platform.doc.isv (3.1.0) "Eclipse Platform Plug-in Developer =
 Guide" [Resolved]
 org.eclipse.platform.doc.user (3.1.0) "Eclipse Workbench User Guide" [Res=
 olved]
 org.eclipse.platform.source.win32.win32.x86 (3.1.0) "Eclipse Platform Plu=
 org.eclipse.rcp (3.1.0) "Eclipse RCP" [Resolved]
 org.eclipse.rcp.source (3.1.0) "Eclipse RCP Plug-in Developer Resources" =
 [Resolved]
 org.eclipse.rcp.source.win32.win32.x86 (3.1.0) "Eclipse RCP Plug-in Devel=
 org.eclipse.sdk (3.1.0) "Eclipse Project SDK" [Resolved]
 org.eclipse.search (3.1.0) "Search Support" [Active]
 org.eclipse.swt (3.1.0) "Standard Widget Toolkit" [Resolved]
 org.eclipse.swt.win32.win32.x86 (3.1.0) "Standard Widget Toolkit for Wind=
 ows" [Resolved]
 org.eclipse.team.core (3.1.0) "Team Support Core" [Active]
 org.eclipse.team.cvs.core (3.1.0) "CVS Team Provider Core" [Active]
 org.eclipse.team.cvs.ssh (3.1.0) "CVS SSH Core" [Resolved]
 org.eclipse.team.cvs.ssh2 (3.1.0) "CVS SSH2" [Resolved]
 org.eclipse.team.cvs.ui (3.1.0) "CVS Team Provider UI" [Active]
 org.eclipse.team.ui (3.1.0) "Team Support UI" [Active]
 org.eclipse.text (3.1.0) "Text" [Active]
 org.eclipse.tomcat (4.1.30.1) "Tomcat Wrapper" [Resolved]
 org.eclipse.ui (3.1.0) "Eclipse UI" [Active]
 org.eclipse.ui.browser (3.1.0) "Browser Support" [Active]
 org.eclipse.ui.cheatsheets (3.1.0) "Cheat Sheets" [Resolved]
 org.eclipse.ui.console (3.1.0) "Console" [Active]
 org.eclipse.ui.editors (3.1.0) "Default Text Editor" [Active]
 org.eclipse.ui.externaltools (3.1.0) "External Tools" [Active]
 org.eclipse.ui.forms (3.1.0) "Eclipse Forms" [Active]
 org.eclipse.ui.ide (3.1.0) "Eclipse IDE UI" [Active]
 org.eclipse.ui.intro (3.1.0) "Welcome Framework" [Resolved]
 org.eclipse.ui.presentations.r21 (3.1.0) "R21 Presentation Plug-in" [Reso=
 lved]
 org.eclipse.ui.views (3.1.0) "Views" [Active]
 org.eclipse.ui.win32 (3.1.0) "Eclipse UI Win32 Enhancements" [Resolved]
 org.eclipse.ui.workbench (3.1.0) "Workbench" [Active]
 org.eclipse.ui.workbench.compatibility (3.1.0) "Workbench Compatibility" =
 [Resolved]
 org.eclipse.ui.workbench.texteditor (3.1.0) "Text Editor Framework" [Acti=
 ve]
 org.eclipse.update.configurator (3.1.0) "Install/Update Configurator" [Ac=
 tive]
 org.eclipse.update.core (3.1.0) "Install/Update Core" [Active]
 org.eclipse.update.core.win32 (3.1.0) "Install/Update Core for Windows" [=
 Resolved]
 org.eclipse.update.scheduler (3.1.0) "Automatic Updates Scheduler" [Activ=
 e]
 org.eclipse.update.ui (3.1.0) "Install/Update UI" [Active]
 org.eclipse.ve (1.0.1) "Visual Editor" [Resolved]
 org.eclipse.ve.cde (1.0.2) "Visual Editor Common Data Editor" [Resolved]
 org.eclipse.ve.doc (1.0.1) "Visual Editor User Guide" [Resolved]
 org.eclipse.ve.java.core (1.0.2.1) "Visual Editor Java Core" [Resolved]
 org.eclipse.ve.jfc (1.0.2) "Visual Editor for Java Foundation Classes" [R=
 esolved]
 org.eclipse.ve.propertysheet (1.0.1) "Visual Editor PropertySheet" [Resol=
 ved]
 org.eclipse.ve.sdk (1.0.1) "Visual Editor SDK" [Resolved]
 org.eclipse.ve.source (1.0.2.1) "Visual Editor Source" [Resolved]
 org.eclipse.ve.swt (1.0.2) "Visual Editor for Standard Widget Toolkit" [R=
 esolved]
 org.eclipse.wst.command.env (0.7.0) "Environment Command Framework (headl=
 ess)" [Resolved]
 org.eclipse.wst.command.env.core (0.7.0) "Environment Command Framework (=
 core)" [Resolved]
 org.eclipse.wst.command.env.ui (0.7.0) "Environment Command Framework (GU=
 I)" [Resolved]
 org.eclipse.wst.common.emf (0.7.0) "EMF Utilities" [Active]
 org.eclipse.wst.common.emfworkbench.integration (0.7.0) "EMF Workbench Ed=
 it Plug-in" [Active]
 org.eclipse.wst.common.frameworks (0.7.0) "org.eclipse.wst.common.framewo=
 rks" [Active]
 org.eclipse.wst.common.frameworks.ui (0.7.0) "WTP UI Plug-in" [Active]
 org.eclipse.wst.common.modulecore (0.7.0) "Modulecore Plug-in" [Active]
 org.eclipse.wst.common.navigator.views (0.7.0) "Common Navigator View" [A=
 ctive]
 org.eclipse.wst.common.navigator.workbench (0.7.0) "Navigator Workbench C=
 omponents" [Active]
 org.eclipse.wst.common.snippets (0.7.0) "Snippets View" [Resolved]
 org.eclipse.wst.common.ui (0.7.0) "Eclipse Base UI extensions" [Resolved]=
 org.eclipse.wst.common.ui.properties (0.7.0) "Common Properties UI" [Acti=
 ve]
 org.eclipse.wst.common.uriresolver (0.7.0) "org.eclipse.wst.common.urires=
 olver" [Active]
 org.eclipse.wst.css.core (0.7.0) "Structured Source CSS Model" [Resolved]=
 org.eclipse.wst.css.ui (0.7.0) "SSE CSS Source Editor" [Resolved]
 org.eclipse.wst.doc.isv (0.7.0) "WST ISV Documentation" [Resolved]
 org.eclipse.wst.doc.user (0.7.0) "Web Standard Tools Help User Doc Plug-i=
 n" [Resolved]
 org.eclipse.wst.dtd.core (0.7.0) "Structured Source DTD Core" [Resolved]
 org.eclipse.wst.dtd.ui (0.7.0) "SSE DTD Source Editor" [Resolved]
 org.eclipse.wst.html.core (0.7.0) "Structured Source HTML Model" [Resolve=
 d]
 org.eclipse.wst.html.standard.dtds (0.7.0) "Known DTDs" [Resolved]
 org.eclipse.wst.html.ui (0.7.0) "HTML UI Source Editor" [Resolved]
 org.eclipse.wst.internet.cache (0.7.0) "Cache URI Resolver Plug-in" [Acti=
 ve]
 org.eclipse.wst.internet.monitor.core (0.7.0) "Monitor" [Resolved]
 org.eclipse.wst.internet.monitor.ui (0.7.0) "TCP/IP Monitor" [Resolved]
 org.eclipse.wst.internet.proxy (0.7.0) "Internet Proxy Preferences" [Acti=
 ve]
 org.eclipse.wst.javascript.core (0.7.0) "Structured Source JavaScript Mod=
 el" [Resolved]
 org.eclipse.wst.javascript.ui (0.7.0) "SSE JavaScript Source Editor" [Res=
 olved]
 org.eclipse.wst.rdb.connection.ui (0.7.0) "RDB Connection.ui" [Resolved]
 org.eclipse.wst.rdb.core (0.7.0) "RDB Core" [Resolved]
 org.eclipse.wst.rdb.core.ui (0.7.0) "Core UI plugin" [Resolved]
 org.eclipse.wst.rdb.data.core (0.7.0) "Data Core Plugin" [Resolved]
 org.eclipse.wst.rdb.data.ui (0.7.0) "Data UI Plugin" [Resolved]
 org.eclipse.wst.rdb.dbdefinition.db2.iseries (0.7.0) "DB2 UDB iSeries Dat=
 abase Definition Plug-in" [Resolved]
 org.eclipse.wst.rdb.dbdefinition.db2.luw (0.7.0) "DB2 UDB Database Defini=
 org.eclipse.wst.rdb.dbdefinition.db2.zseries (0.7.0) "DB2 UDB Database De=
 org.eclipse.wst.rdb.dbdefinition.derby (0.7.0) "IBM Cloudscape Database D=
 efinition" [Resolved]
 org.eclipse.wst.rdb.dbdefinition.informix (0.7.0) "Informix Database Defi=
 org.eclipse.wst.rdb.dbdefinition.mysql (0.7.0) "DBDefinition Mysql Plug-i=
 n" [Resolved]
 org.eclipse.wst.rdb.dbdefinition.oracle (0.7.0) "Oracle Database Definiti=
 org.eclipse.wst.rdb.dbdefinition.sqlserver (0.7.0) "SQL Server Database D=
 org.eclipse.wst.rdb.dbdefinition.sybase (0.7.0) "Sybase Database Definiti=
 org.eclipse.wst.rdb.derby (0.7.0) "RDB Derby Plug-in" [Resolved]
 org.eclipse.wst.rdb.derby.ui (0.7.0) "RDB Derby Ui Plug-in" [Resolved]
 org.eclipse.wst.rdb.fe.ui (0.7.0) "FE Ui Plug-in" [Resolved]
 org.eclipse.wst.rdb.fe.ui.actions (0.7.0) "FE Ui Actions Plug-in" [Resolv=
 ed]
 org.eclipse.wst.rdb.models.dbdefinition (0.7.0) "DBDefinition Model" [Res=
 olved]
 org.eclipse.wst.rdb.models.sql (0.7.0) "SQLModel Plug-in" [Resolved]
 org.eclipse.wst.rdb.models.sql.edit (0.7.0) "SQLModel Edit Plug-in" [Reso=
 lved]
 org.eclipse.wst.rdb.mysql (0.7.0) "RDB Mysql Plug-in" [Resolved]
 org.eclipse.wst.rdb.outputview (0.7.0) "Data Output Plug-in" [Resolved]
 org.eclipse.wst.rdb.server.extensions (0.7.0) "Server Explorer Extensions=
 Plug-in" [Resolved]
 org.eclipse.wst.rdb.server.ui (0.7.0) "Server Explorer plugin" [Resolved]=
 org.eclipse.wst.rdb.sqleditor (0.7.0) "SQL Source Editor Plugin" [Resolve=
 d]
 org.eclipse.wst.rdb.sqlscrapbook (0.7.0) "Sqlscrapbook Plug-in" [Resolved=
 org.eclipse.wst.server.core (0.7.0) "Server Core" [Active]
 org.eclipse.wst.server.ui (0.7.0) "Server UI" [Active]
 org.eclipse.wst.source (0.7.0) "Webtools Platform Web Standard Tools (WST=
 ) Source Plug-in Developer Resources" [Resolved]
 org.eclipse.wst.sse.core (0.7.0) "Structured Text Model" [Active]
 org.eclipse.wst.sse.ui (0.7.0) "Structured Source Editor" [Resolved]
 org.eclipse.wst.validation (0.7.0) "Validation Framework" [Active]
 org.eclipse.wst.validation.ui (0.7.0) "Validation Framework UI" [Resolved=
 org.eclipse.wst.web (0.7.0) "Simple Web Plug-in" [Active]
 org.eclipse.wst.web.ui (0.7.0) "Simple Web UI Plug-in" [Resolved]
 org.eclipse.wst.ws (0.7.0) "Web Services" [Resolved]
 org.eclipse.wst.ws.explorer (0.7.0) "Web Services Explorer" [Resolved]
 org.eclipse.wst.ws.parser (0.7.0) "Web Services Description Parser" [Reso=
 lved]
 org.eclipse.wst.ws.ui (0.7.0) "Web Services UI" [Resolved]
 org.eclipse.wst.wsdl (0.7.0) "WSDL Model" [Active]
 org.eclipse.wst.wsdl.ui (0.7.0) "WSDL Editor" [Resolved]
 org.eclipse.wst.wsdl.validation (0.7.0) "WSDL Validator" [Resolved]
 org.eclipse.wst.wsi (0.7.0) "WSI Conformance Tools" [Resolved]
 org.eclipse.wst.wsi.ui (0.7.0) "Soap Monitor" [Resolved]
 org.eclipse.wst.xml.core (0.7.0) "Structured Source XML Model" [Active]
 org.eclipse.wst.xml.ui (0.7.0) "XML UI Plugin" [Active]
 org.eclipse.wst.xsd.core (0.7.0) "XSD Core Plugin" [Resolved]
 org.eclipse.wst.xsd.ui (0.7.0) "XML Schema Editor" [Resolved]
 org.eclipse.xsd (2.1.0) "XML Schema Infoset Model (XSD)" [Resolved]
 org.eclipse.xsd.ecore.importer (2.1.0) "XML Schema Importer for EMF" [Res=
 olved]
 org.eclipse.xsd.edit (2.1.0) "XML Schema Edit Framework" [Resolved]
 org.eclipse.xsd.editor (2.1.0) "XML Schema Editor" [Resolved]
 SD) Source" [Resolved]
 org.junit (3.8.1) "JUnit Testing Framework" [Resolved]
 org.uddi4j (1.0.0) "UDDI4J 2.0.3" [Resolved]
 org.uddi4j (0.7.0) "UDDI4J 2.0.3" [Resolved]
 org.vssplugin (1.6.1) "VSS Plugin Functions for Eclipse" [Active]
 org.wsdl4j (1.0.0) "WSDL4J 1.4" [Resolved]
 system.bundle (3.1.0) "OSGi System Bundle" [Active]
 *** User Preferences:
 #Thu Jul 07 09:50:38 EDT 2005
 /instance/org.eclipse.compare/StructureViewerAliases=3DCLASS PATH.XML=20
 /instance/org.eclipse.jdt.core/org.eclipse.jdt.core.builder. resourceCopyE=
 xclusionFilter=3D*.launch
 /instance/org.eclipse.ui.workbench/Java-ORIG_persp=3D<?xml version\=3D"1.=
 0" encoding\=3D"UTF-8"?>\r\n<perspective editorAreaVisible\=3D"1" fixed\=3D=
 "0" version\=3D"0.016">\r\n<descriptor descriptor\=3D"org.eclipse.jdt.ui.=
 JavaPerspective" id\=3D"Java-ORIG" label\=3D"Java-ORIG"/>\r\n<window heig=
 ht\=3D"768" width\=3D"1024" x\=3D"106" y\=3D"65"/>\r\n<actionSet id\=3D"c=
 om_sysdeo_eclipse_tomcat_actionSet"/>\r\n<actionSet id\=3D"org.eclipse.he=
 lp.ui.actions"/>\r\n<actionSet id\=3D"org.eclipse.jst.servlet.ui.internal=
 =2Eactions.ConvertToWebModuleTypeActionSet"/>\r\n<actionSet id\=3D"org.ec=
 lipse.jst.ws.consumption"/>\r\n<actionSet id\=3D"org.eclipse.search.searc=
 hActionSet"/>\r\n<actionSet id\=3D"org.eclipse.ui.cheatsheets.actionSet"/=
 >\r\n<actionSet id\=3D"org.eclipse.ui.edit.text.actionSet.openExternalFil=
 e"/>\r\n<actionSet id\=3D"org.eclipse.ui.edit.text.actionSet.newTextEdito=
 r"/>\r\n<actionSet id\=3D"org.eclipse.ui.edit.text.actionSet.navigation"/=
 >\r\n<actionSet id\=3D"org.eclipse.ui.edit.text.actionSet.convertLineDeli=
 mitersTo"/>\r\n<actionSet id\=3D"org.eclipse.ui.externaltools.ExternalToo=
 lsSet"/>\r\n<actionSet id\=3D"org.eclipse.ui.actionSet.keyBindings"/>\r\n=
 <actionSet id\=3D"org.eclipse.update.ui.softwareUpdates"/>\r\n<actionSet =
 id\=3D"org.eclipse.debug.ui.launchActionSet"/>\r\n<actionSet id\=3D"org.e=
 clipse.jdt.ui.JavaActionSet"/>\r\n<actionSet id\=3D"org.eclipse.jdt.ui.Ja=
 vaElementCreationActionSet"/>\r\n<actionSet id\=3D"org.eclipse.ui.Navigat=
 eActionSet"/>\r\n<actionSet id\=3D"org.eclipse.debug.ui.breakpointActionS=
 et"/>\r\n<actionSet id\=3D"org.eclipse.jdt.debug.ui.JDTDebugActionSet"/>\=
 r\n<actionSet id\=3D"org.eclipse.jdt.junit.JUnitActionSet"/>\r\n<actionSe=
 t id\=3D"org.vssplugin.menu.actionSet"/>\r\n<alwaysOnActionSet id\=3D"com=
 _sysdeo_eclipse_tomcat_actionSet"/>\r\n<alwaysOnActionSet id\=3D"org.ecli=
 pse.help.ui.actions"/>\r\n<alwaysOnActionSet id\=3D"org.eclipse.jst.servl=
 et.ui.internal.actions.ConvertToWebModuleTypeActionSet"/>\r\n <alwaysOnAct=
 ionSet id\=3D"org.eclipse.jst.ws.consumption"/>\r\n<alwaysOnActionSet id\=
 =3D"org.eclipse.search.searchActionSet"/>\r\n<alwaysOnActionSet id\=3D"or=
 g.eclipse.ui.cheatsheets.actionSet"/>\r\n<alwaysOnActionSet id\=3D"org.ec=
 lipse.ui.edit.text.actionSet.openExternalFile"/>\r\n<alwaysOnActionSet id=
 \=3D"org.eclipse.ui.edit.text.actionSet.newTextEditor"/>\r\n <alwaysOnActi=
 onSet id\=3D"org.eclipse.ui.edit.text.actionSet.navigation"/>\r\n <alwaysO=
 nActionSet id\=3D"org.eclipse.ui.edit.text.actionSet.convertLineDelimiter=
 sTo"/>\r\n<alwaysOnActionSet id\=3D"org.eclipse.ui.externaltools.External=
 ToolsSet"/>\r\n<alwaysOnActionSet id\=3D"org.eclipse.ui.actionSet.keyBind=
 ings"/>\r\n<alwaysOnActionSet id\=3D"org.eclipse.update.ui.softwareUpdate=
 s"/>\r\n<alwaysOnActionSet id\=3D"org.eclipse.debug.ui.launchActionSet"/>=
 \r\n<alwaysOnActionSet id\=3D"org.eclipse.jdt.ui.JavaActionSet"/>\r\n<alw=
 aysOnActionSet id\=3D"org.eclipse.jdt.ui.JavaElementCreationActionSet"/>\=
 r\n<alwaysOnActionSet id\=3D"org.eclipse.ui.NavigateActionSet"/>\r\n<alwa=
 ysOnActionSet id\=3D"org.eclipse.debug.ui.breakpointActionSet"/>\r\n<alwa=
 ysOnActionSet id\=3D"org.eclipse.jdt.debug.ui.JDTDebugActionSet"/>\r\n<al=
 waysOnActionSet id\=3D"org.eclipse.jdt.junit.JUnitActionSet"/>\r\n<always=
 OnActionSet id\=3D"org.vssplugin.menu.actionSet"/>\r\n<show_view_action i=
 d\=3D"org.eclipse.jdt.ui.PackageExplorer"/>\r\n<show_view_action id\=3D"o=
 rg.eclipse.jdt.ui.TypeHierarchy"/>\r\n<show_view_action id\=3D"org.eclips=
 e.jdt.ui.SourceView"/>\r\n<show_view_action id\=3D"org.eclipse.jdt.ui.Jav=
 adocView"/>\r\n<show_view_action id\=3D"org.eclipse.search.ui.views.Searc=
 hView"/>\r\n<show_view_action id\=3D"org.eclipse.ui.console.ConsoleView"/=
 >\r\n<show_view_action id\=3D"org.eclipse.ui.views.ContentOutline"/>\r\n<=
 show_view_action id\=3D"org.eclipse.ui.views.ProblemView"/>\r\n<show_view=
 _action id\=3D"org.eclipse.ui.views.ResourceNavigator"/>\r\n<show_view_ac=
 tion id\=3D"org.eclipse.ant.ui.views.AntView"/>\r\n<show_view_action id\=3D=
 "org.eclipse.pde.runtime.LogView"/>\r\n<new_wizard_action id\=3D"org.ecli=
 pse.jdt.ui.wizards.NewPackageCreationWizard"/>\r\n<new_wizard_action id\=3D=
 "org.eclipse.jdt.ui.wizards.NewClassCreationWizard"/>\r\n<new_wizard_acti=
 on id\=3D"org.eclipse.jdt.ui.wizards.NewInterfaceCreationWizard "/>\r\n<ne=
 w_wizard_action id\=3D"org.eclipse.jdt.ui.wizards.EnumCreationWizard"/>\r=
 \n<new_wizard_action id\=3D"org.eclipse.jdt.ui.wizards.NewSourceFolderCre=
 ationWizard"/>\r\n<new_wizard_action id\=3D"org.eclipse.jdt.ui.wizards.Ne=
 wSnippetFileCreationWizard"/>\r\n<new_wizard_action id\=3D"org.eclipse.ui=
 =2Ewizards.new.folder"/>\r\n<new_wizard_action id\=3D"org.eclipse.ui.wiza=
 rds.new.file"/>\r\n<new_wizard_action id\=3D"org.eclipse.jdt.junit.wizard=
 s.NewTestCaseCreationWizard"/>\r\n<perspective_action id\=3D"org.eclipse.=
 jdt.ui.JavaPerspective"/>\r\n<perspective_action id\=3D"org.eclipse.debug=
 =2Eui.DebugPerspective"/>\r\n<perspective_action id\=3D"org.eclipse.jdt.u=
 i.JavaBrowsingPerspective"/>\r\n<view id\=3D"org.eclipse.jdt.ui.PackageEx=
 plorer"/>\r\n<view id\=3D"org.eclipse.jdt.ui.TypeHierarchy"/>\r\n<view id=
 \=3D"org.eclipse.ui.views.ProblemView"/>\r\n<view id\=3D"org.eclipse.jdt.=
 ui.JavadocView"/>\r\n<view id\=3D"org.eclipse.jdt.ui.SourceView"/>\r\n<vi=
 ew id\=3D"org.eclipse.ui.views.ContentOutline"/>\r\n<view id\=3D"org.vssp=
 lugin.ui.checkout"/>\r\n<view id\=3D"org.vssplugin.ui.logview"/>\r\n<layo=
 ut>\r\n<mainWindow>\r\n<info folder\=3D"true" part\=3D"left">\r\n<folder =
 activePageID\=3D"org.eclipse.jdt.ui.PackageExplorer" appearance\=3D"2" ex=
 panded\=3D"2">\r\n<page content\=3D"org.eclipse.jdt.ui.PackageExplorer" l=
 abel\=3D"Package Explorer"/>\r\n<page content\=3D"org.eclipse.jdt.ui.Type=
 Hierarchy" label\=3D"Hierarchy"/>\r\n<page content\=3D"org.eclipse.ui.vie=
 ws.ResourceNavigator" label\=3D"LabelNotFound"/>\r\n<page content\=3D"org=
 =2Eeclipse.jdt.junit.ResultView" label\=3D"LabelNotFound"/>\r\n<presentat=
 ion id\=3D"org.eclipse.ui.presentations.WorkbenchPresentationFactory ">\r\=
 n<part id\=3D"0"/>\r\n<part id\=3D"1"/>\r\n</presentation>\r\n</folder>\r=
 \n</info>\r\n<info folder\=3D"true" part\=3D"stickyFolderRight" ratio\=3D=
 "0.74950296" ratioLeft\=3D"754" ratioRight\=3D"252" relationship\=3D"2" r=
 elative\=3D"left">\r\n<folder appearance\=3D"2" expanded\=3D"2">\r\n<page=
 content\=3D"org.eclipse.help.ui.HelpView" label\=3D"LabelNotFound"/>\r\n=
 <page content\=3D"org.eclipse.ui.internal.introview" label\=3D"LabelNotFo=
 und"/>\r\n<page content\=3D"org.eclipse.ui.cheatsheets.views.CheatSheetVi=
 ew" label\=3D"LabelNotFound"/>\r\n</folder>\r\n</info>\r\n <info part\=3D"=
 org.eclipse.ui.editorss" ratio\=3D"0.24950299" ratioLeft\=3D"251" ratioRi=
 ght\=3D"755" relationship\=3D"2" relative\=3D"left"/>\r\n<info folder\=3D=
 "true" part\=3D"bottom" ratio\=3D"0.7492163" ratioLeft\=3D"478" ratioRigh=
 t\=3D"160" relationship\=3D"4" relative\=3D"org.eclipse.ui.editorss">\r\n=
 <folder activePageID\=3D"org.eclipse.ui.views.ProblemView" appearance\=3D=
 "2" expanded\=3D"2">\r\n<page content\=3D"org.eclipse.ui.views.ProblemVie=
 w" label\=3D"Problems"/>\r\n<page content\=3D"org.eclipse.jdt.ui.JavadocV=
 iew" label\=3D"Javadoc"/>\r\n<page content\=3D"org.eclipse.jdt.ui.SourceV=
 iew" label\=3D"Declaration"/>\r\n<page content\=3D"org.eclipse.search.ui.=
 views.SearchView" label\=3D"LabelNotFound"/>\r\n<page content\=3D"org.ecl=
 ipse.ui.console.ConsoleView" label\=3D"LabelNotFound"/>\r\n<page content\=
 =3D"org.eclipse.ui.views.BookmarkView" label\=3D"LabelNotFound"/>\r\n<pag=
 e content\=3D"org.eclipse.ui.views.ProgressView" label\=3D"LabelNotFound"=
 />\r\n<presentation id\=3D"org.eclipse.ui.presentations.WorkbenchPresenta=
 tionFactory">\r\n<part id\=3D"0"/>\r\n<part id\=3D"1"/>\r\n<part id\=3D"2=
 "/>\r\n</presentation>\r\n</folder>\r\n</info>\r\n<info folder\=3D"true" =
 part\=3D"org.eclipse.ui.internal.ViewStack@1ff323" ratio\=3D"0.49933776" =
 ratioLeft\=3D"377" ratioRight\=3D"378" relationship\=3D"2" relative\=3D"b=
 ottom">\r\n<folder activePageID\=3D"org.vssplugin.ui.checkout" appearance=
 \=3D"2" expanded\=3D"2">\r\n<page content\=3D"org.vssplugin.ui.checkout" =
 label\=3D"Checked Out Files"/>\r\n<presentation id\=3D"org.eclipse.ui.pre=
 sentations.WorkbenchPresentationFactory">\r\n<part id\=3D"0"/>\r\n</prese=
 ntation>\r\n</folder>\r\n</info>\r\n<info folder\=3D"true" part\=3D"org.e=
 clipse.ui.internal.ViewStack@193b022" ratio\=3D"0.5" ratioLeft\=3D"189" r=
 atioRight\=3D"189" relationship\=3D"2" relative\=3D"org.eclipse.ui.intern=
 al.ViewStack@1ff323">\r\n<folder activePageID\=3D"org.vssplugin.ui.logvie=
 w" appearance\=3D"2" expanded\=3D"2">\r\n<page content\=3D"org.vssplugin.=
 ui.logview" label\=3D"VSS Refresh Log"/>\r\n<presentation id\=3D"org.ecli=
 pse.ui.presentations.WorkbenchPresentationFactory">\r\n<part id\=3D"0"/>\=
 r\n</presentation>\r\n</folder>\r\n</info>\r\n<info folder\=3D"true" part=
 \=3D"org.eclipse.ui.internal.ViewStack@1d97efc" ratio\=3D"0.7496689" rati=
 oLeft\=3D"566" ratioRight\=3D"189" relationship\=3D"2" relative\=3D"org.e=
 clipse.ui.editorss">\r\n<folder activePageID\=3D"org.eclipse.ui.views.Con=
 tentOutline" appearance\=3D"2" expanded\=3D"2">\r\n<page content\=3D"org.=
 eclipse.ui.views.ContentOutline" label\=3D"Outline"/>\r\n<page content\=3D=
 "org.eclipse.ant.ui.views.AntView" label\=3D"LabelNotFound"/>\r\n<present=
 ation id\=3D"org.eclipse.ui.presentations.WorkbenchPresentationFactory ">\=
 r\n<part id\=3D"0"/>\r\n</presentation>\r\n</folder>\r\n</info >\r\n</main=
 Window>\r\n</layout>\r\n</perspective>\r\n
 /instance/org.eclipse.wst.internet.proxy/userNameText=3Denco ded\:
 /instance/org.eclipse.ui.ide/EXIT_PROMPT_ON_CLOSE_LAST_WINDO W=3Dfalse
 /instance/org.eclipse.wst.sse.core/task-tag-projects-already -scanned=3D.J=
 ETEmitters,BPE,BPE-Paging,DRK Testing,Servers,SwingTest2,Tiles-Test,jakar=
 ta-jetspeed-2,jetspeed,jpetstore,IES-339
 /instance/org.eclipse.team.cvs.ui/pref_text_ksubst=3D-kk
 /instance/es.org.chemi.games.sokoban/inf_original=3D1|true|d rk|258|97|58\=
 #2|true|drk|502|147|143\#3|true|drk|377|144|95\#4|true|drk|1 027|415|254\#=
 5|true|drk|434|149|105\#6|true|drk|317|117|79\#7|true|drk|35 8|98|128\#8|t=
 rue|drk|672|262|176\#9|true|drk|592|239|166\#10|true|drk|140 9|550|334\#11=
 |false|-|0|0|0\#12|false|-|0|0|0\#13|false|-|0|0|0\#14|false |-|0|0|0\#15|=
 false|-|0|0|0\#16|false|-|0|0|0\#17|false|-|0|0|0\#18|false| -|0|0|0\#19|f=
 alse|-|0|0|0\#20|false|-|0|0|0\#21|false|-|0|0|0\#22|false|- |0|0|0\#23|fa=
 lse|-|0|0|0\#24|false|-|0|0|0\#25|false|-|0|0|0\#26|false|-| 0|0|0\#27|fal=
 se|-|0|0|0\#28|false|-|0|0|0\#29|false|-|0|0|0\#30|false|-|0 |0|0\#31|fals=
 e|-|0|0|0\#32|false|-|0|0|0\#33|false|-|0|0|0\#34|false|-|0| 0|0\#35|false=
 |-|0|0|0\#36|false|-|0|0|0\#37|false|-|0|0|0\#38|false|-|0|0 |0\#39|false|=
 -|0|0|0\#40|false|-|0|0|0\#41|false|-|0|0|0\#42|false|-|0|0| 0\#43|false|-=
 |0|0|0\#44|false|-|0|0|0\#45|false|-|0|0|0\#46|false|-|0|0|0 \#47|false|-|=
 0|0|0\#48|false|-|0|0|0\#49|false|-|0|0|0\#50|false|-|0|0|0\ #
 @org.vssplugin=3D1.6.1
 /instance/org.eclipse.ui/DOCK_PERSPECTIVE_BAR=3DtopLeft
 /instance/org.eclipse.jdt.ui/org.eclipse.jdt.ui.text.custom_ code_template=
 s=3D<?xml version\=3D"1.0" encoding\=3D"UTF-8"?><templates/>
 /instance/org.eclipse.jdt.ui/formatter_profile=3D_Custom
 /instance/org.eclipse.ui.ide/SWITCH_PERSPECTIVE_ON_PROJECT_C REATION=3Dalw=
 ays
 @org.eclipse.jst.jsp.core=3D0.7.0
 /instance/org.eclipse.ui.ide/platformState=3D936
 @org.eclipse.ui.ide=3D3.1.0
 /instance/org.eclipse.jst.server.tomcat.core/locationorg.ecl ipse.jst.serv=
 er.tomcat.runtime.32=3DC\:/Program Files/Apache Software Foundation/Tomca=
 t 3.2.4
 @org.eclipse.jdt.core=3D3.1.0
 /instance/org.eclipse.jdt.ui/spelling_ignore_digits=3Dtrue
 /instance/org.eclipse.jdt.core/org.eclipse.jdt.core.classpat hVariable.ECL=
 IPSE_HOME=3Dc\:/eclipse
 /instance/org.eclipse.jst.j2ee.ejb.annotations.xdoclet/org.e clipse.jst.j2=
 ee.ejb.annotations.xdoclet.XDOCLETBUILDERACTIVE=3Dtrue
 /instance/org.eclipse.ui.workbench/org.eclipse.jdt.ui.JavaPe rspective_per=
 sp=3D<?xml version\=3D"1.0" encoding\=3D"UTF-8"?>\r\n<perspective editorA=
 reaVisible\=3D"1" fixed\=3D"0" version\=3D"0.016">\r\n<descriptor class\=3D=
 "org.eclipse.jdt.internal.ui.JavaPerspectiveFactory" id\=3D"org.eclipse.j=
 dt.ui.JavaPerspective" label\=3D"Java"/>\r\n<window height\=3D"768" width=
 \=3D"1024" x\=3D"106" y\=3D"65"/>\r\n<actionSet id\=3D"com_sysdeo_eclipse=
 _tomcat_actionSet"/>\r\n<actionSet id\=3D"org.eclipse.help.ui.actions"/>\=
 r\n<actionSet id\=3D"org.eclipse.jst.servlet.ui.internal.actions.ConvertT=
 oWebModuleTypeActionSet"/>\r\n<actionSet id\=3D"org.eclipse.jst.ws.consum=
 ption"/>\r\n<actionSet id\=3D"org.eclipse.search.searchActionSet"/>\r\n<a=
 ctionSet id\=3D"org.eclipse.ui.cheatsheets.actionSet"/>\r\n<actionSet id\=
 =3D"org.eclipse.ui.edit.text.actionSet.openExternalFile"/>\r\n <actionSet =
 id\=3D"org.eclipse.ui.edit.text.actionSet.newTextEditor"/>\r\n <actionSet =
 id\=3D"org.eclipse.ui.edit.text.actionSet.navigation"/>\r\n <actionSet id\=
 =3D"org.eclipse.ui.edit.text.actionSet.convertLineDelimitersTo "/>\r\n<act=
 ionSet id\=3D"org.eclipse.ui.externaltools.ExternalToolsSet"/>\r\n <action=
 Set id\=3D"org.eclipse.ui.actionSet.keyBindings"/>\r\n<actionSet id\=3D"o=
 rg.eclipse.update.ui.softwareUpdates"/>\r\n<actionSet id\=3D"org.eclipse.=
 debug.ui.launchActionSet"/>\r\n<actionSet id\=3D"org.eclipse.jdt.ui.JavaA=
 ctionSet"/>\r\n<actionSet id\=3D"org.eclipse.jdt.ui.JavaElementCreationAc=
 tionSet"/>\r\n<actionSet id\=3D"org.eclipse.ui.NavigateActionSet"/>\r\n<a=
 ctionSet id\=3D"org.eclipse.debug.ui.breakpointActionSet"/>\r\n<actionSet=
 id\=3D"org.eclipse.jdt.debug.ui.JDTDebugActionSet"/>\r\n<actionSet id\=3D=
 "org.eclipse.jdt.junit.JUnitActionSet"/>\r\n<actionSet id\=3D"org.vssplug=
 in.menu.actionSet"/>\r\n<alwaysOnActionSet id\=3D"com_sysdeo_eclipse_tomc=
 at_actionSet"/>\r\n<alwaysOnActionSet id\=3D"org.eclipse.help.ui.actions"=
 />\r\n<alwaysOnActionSet id\=3D"org.eclipse.jst.servlet.ui.internal.actio=
 ns.ConvertToWebModuleTypeActionSet"/>\r\n<alwaysOnActionSet id\=3D"org.ec=
 lipse.jst.ws.consumption"/>\r\n<alwaysOnActionSet id\=3D"org.eclipse.sear=
 ch.searchActionSet"/>\r\n<alwaysOnActionSet id\=3D"org.eclipse.ui.cheatsh=
 eets.actionSet"/>\r\n<alwaysOnActionSet id\=3D"org.eclipse.ui.edit.text.a=
 ctionSet.openExternalFile"/>\r\n<alwaysOnActionSet id\=3D"org.eclipse.ui.=
 edit.text.actionSet.newTextEditor"/>\r\n<alwaysOnActionSet id\=3D"org.ecl=
 ipse.ui.edit.text.actionSet.navigation"/>\r\n<alwaysOnActionSet id\=3D"or=
 g.eclipse.ui.edit.text.actionSet.convertLineDelimitersTo"/>\r\n <alwaysOnA=
 ctionSet id\=3D"org.eclipse.ui.externaltools.ExternalToolsSet"/>\r\n <alwa=
 ysOnActionSet id\=3D"org.eclipse.ui.actionSet.keyBindings"/>\r\n<alwaysOn=
 ActionSet id\=3D"org.eclipse.update.ui.softwareUpdates"/>\r\n<alwaysOnAct=
 ionSet id\=3D"org.eclipse.debug.ui.launchActionSet"/>\r\n<alwaysOnActionS=
 et id\=3D"org.eclipse.jdt.ui.JavaActionSet"/>\r\n<alwaysOnActionSet id\=3D=
 "org.eclipse.jdt.ui.JavaElementCreationActionSet"/>\r\n<alwaysOnActionSet=
 id\=3D"org.eclipse.ui.NavigateActionSet"/>\r\n<alwaysOnActionSet id\=3D"=
 org.eclipse.debug.ui.breakpointActionSet"/>\r\n<alwaysOnActionSet id\=3D"=
 org.eclipse.jdt.debug.ui.JDTDebugActionSet"/>\r\n<alwaysOnActionSet id\=3D=
 "org.eclipse.jdt.junit.JUnitActionSet"/>\r\n<alwaysOnActionSet id\=3D"org=
 =2Evssplugin.menu.actionSet"/>\r\n<show_view_action id\=3D"org.eclipse.jd=
 t.ui.PackageExplorer"/>\r\n<show_view_action id\=3D"org.eclipse.jdt.ui.Ty=
 peHierarchy"/>\r\n<show_view_action id\=3D"org.eclipse.jdt.ui.SourceView"=
 />\r\n<show_view_action id\=3D"org.eclipse.jdt.ui.JavadocView"/>\r\n<show=
 _view_action id\=3D"org.eclipse.search.ui.views.SearchView"/>\r\n<show_vi=
 ew_action id\=3D"org.eclipse.ui.console.ConsoleView"/>\r\n<show_view_acti=
 on id\=3D"org.eclipse.ui.views.ContentOutline"/>\r\n<show_view_action id\=
 =3D"org.eclipse.ui.views.ProblemView"/>\r\n<show_view_action id\=3D"org.e=
 clipse.
| Re: The server may already be running in another process, or a system process may be using the port. [message #117575 is a reply to message #117443] | Thu, 07 July 2005 12:36   |  |
| Eclipse User  |  |  |  |  | Thanks.  On a fresh session of Eclipse, what happens when you start and stop the server from the Servers view in debug mode?  Does the Debug
 view show that the Tomcat server fully terminated?
 Tomcat 4 and up have the characteristic of waiting forever for webapps
 to fully clean up before finishing its shutdown.  I'm wondering this
 might be the cause of the inability to subsequently start Tomcat again.
 You can also try to use the Windows Task Manager to spot the Tomcat
 instance of javaw.exe and make sure it disappears when Tomcat is stopped.
 Larry
 >> GEF SDK 3.1.0
 >> QuantumDB 3.0.0
 >> Eclipse-Games 3.1.0
 >> VSS Plugin 1.6.1
 >>> Larry
 >>>> Now even after I restart eclipse I constantly get that message.  I
 >>>> have run netstat to determine if any other application is using that
 >>>> port and none are.  Any help on this would be appricieated.  I would
 >>>> Thanks
 > awt.toolkit=sun.awt.windows.WToolkit
 > eclipse.application=org.eclipse.ui.ide.workbench
 > eclipse.buildId=I20050627-1435
 > eclipse.commands=-os
 > win32
 > -ws
 > win32
 > -arch
 > x86
 > -launcher
 > -name
 > Eclipse
 > -showsplash
 > 600
 > -exitdata
 > 3f0_60
 > -data
 > -vm
 > eclipse.product=org.eclipse.sdk.ide
 > eclipse.startTime=1120740896931
 > eclipse.vm=C:\WINDOWS\system32\javaw.exe
 > eclipse.vmargs=-Xms40m
 > -Xmx256m
 > -jar
 > eof=eof
 > file.encoding=Cp1252
 > file.encoding.pkg=sun.io
 > file.separator=\
 > java.awt.graphicsenv=sun.awt.Win32GraphicsEnvironment
 > java.awt.printerjob=sun.awt.windows.WPrinterJob
 > java.class.path=C:\eclipse\startup.jar
 > java.class.version=49.0
 > java.endorsed.dirs=C:\Program Files\Java\jre1.5.0_02\lib\endorsed
 > java.ext.dirs=C:\Program Files\Java\jre1.5.0_02\lib\ext
 > java.home=C:\Program Files\Java\jre1.5.0_02
 > java.io.tmpdir=C:\DOCUME~1\dkantala\LOCALS~1\Temp\
 >  java.library.path=C:\WINDOWS\system32;.;C:\WINDOWS\system32; C:\WINDOWS;C:\oracle\ora81\bin;C:\oracle\ora81\Apache\Perl\5 .00503\bin\mswin32-x86;C:\Program  Files\Oracle\jre\1.1.7\bin;C:\WINDOWS\system32;C:\WINDOWS;C: \WINDOWS\System32\Wbem;C:\Program Files\Microsoft SQL Server\80\Tools\BINN;C:\Program Files\JProbe Profiler 5.2.1\bin
 > java.runtime.name=Java(TM) 2 Runtime Environment, Standard Edition
 > java.runtime.version=1.5.0_02-b09
 > java.specification.name=Java Platform API Specification
 > java.specification.vendor=Sun Microsystems Inc.
 > java.specification.version=1.5
 > java.vendor=Sun Microsystems Inc.
 > java.vendor.url=http://java.sun.com/
 > java.vendor.url.bug=http://java.sun.com/cgi-bin/bugreport.cgi
 > java.version=1.5.0_02
 > java.vm.info=mixed mode, sharing
 > java.vm.name=Java HotSpot(TM) Client VM
 > java.vm.specification.name=Java Virtual Machine Specification
 > java.vm.specification.vendor=Sun Microsystems Inc.
 > java.vm.specification.version=1.0
 > java.vm.vendor=Sun Microsystems Inc.
 > java.vm.version=1.5.0_02-b09
 > line.separator=
 > org.eclipse.jdt.debug.ui.debuggerActive=false
 > org.eclipse.jdt.debug.ui.instanceof.IJavaStackFrame=false
 > org.eclipse.jdt.debug.ui.scrapbookActive=false
 > org.osgi.framework.bootdelegation=*
 > org.osgi.framework.executionenvironment=J2SE-1.5
 > org.osgi.framework.language=en
 > org.osgi.framework.os.name=WindowsXP
 > org.osgi.framework.os.version=5.1
 > org.osgi.framework.processor=x86
 >  org.osgi.framework.system.packages=javax.accessibility,javax .activity,javax.crypto,javax.crypto.interfaces,javax.crypto. spec,javax.imageio,javax.imageio.event,javax.imageio.metadat a,javax.imageio.plugins.bmp,javax.imageio.plugins.jpeg,javax .imageio.spi,javax.imageio.stream,javax.management,javax.man agement.loading,javax.management.modelmbean,javax.management .monitor,javax.management.openmbean,javax.management.relatio n,javax.management.remote,javax.management.remote.rmi,javax. management.timer,javax.naming,javax.naming.directory,javax.n aming.event,javax.naming.ldap,javax.naming.spi,javax.net,jav ax.net.ssl,javax.print,javax.print.attribute,javax.print.att ribute.standard,javax.print.event,javax.rmi,javax.rmi.CORBA, javax.rmi.ssl,javax.security.auth,javax.security.auth.callba ck,javax.security.auth.kerberos,javax.security.auth.login,ja vax.security.auth.spi,javax.security.auth.x500,javax.securit y.cert,javax.security.sasl,javax.sound.midi,javax.sound.midi .spi,javax.sound.sampled,ja
 vax.sound.sampled.spi,javax.sql,javax.sql.rowset,javax.sql.r owset.serial,javax.sql.rowset.spi,javax.swing,javax.swing.bo rder,javax.swing.colorchooser,javax.swing.event,javax.swing. filechooser,javax.swing.plaf,javax.swing.plaf.basic,javax.sw ing.plaf.metal,javax.swing.plaf.multi,javax.swing.plaf.synth ,javax.swing.table,javax.swing.text,javax.swing.text.html,ja vax.swing.text.html.parser,javax.swing.text.rtf,javax.swing. tree,javax.swing.undo,javax.transaction,javax.transaction.xa ,javax.xml,javax.xml.datatype,javax.xml.namespace,javax.xml. parsers,javax.xml.transform,javax.xml.transform.dom,javax.xm l.transform.sax,javax.xml.transform.stream,javax.xml.validat ion,javax.xml.xpath,org.ietf.jgss,org.omg.CORBA,org.omg.CORB A_2_3,org.omg.CORBA_2_3.portable,org.omg.CORBA.DynAnyPackage ,org.omg.CORBA.ORBPackage,org.omg.CORBA.portable,org.omg.COR BA.TypeCodePackage,org.omg.CosNaming,org.omg.CosNaming.Namin gContextExtPackage,org.omg.CosNaming.NamingContextPackage,or g.omg.Dynamic,org.omg.DynamicA
 ny,org.omg.DynamicAny.DynAnyFactoryPackage,org.omg.DynamicAn y.DynAnyPackage,org.omg.IOP,org.omg.IOP.CodecFactoryPackage, org.omg.IOP.CodecPackage,org.omg.Messaging,org.omg.PortableI nterceptor,org.omg.PortableInterceptor.ORBInitInfoPackage,or g.omg.PortableServer,org.omg.PortableServer.CurrentPackage,o rg.omg.PortableServer.POAManagerPackage,org.omg.PortableServ er.POAPackage,org.omg.PortableServer.portable,org.omg.Portab leServer.ServantLocatorPackage,org.omg.SendingContext,org.om g.stub.java.rmi,org.w3c.dom,org.w3c.dom.bootstrap,org.w3c.do m.events,org.w3c.dom.ls,org.xml.sax,org.xml.sax.ext,org.xml. sax.helpers
 > org.osgi.framework.vendor=Eclipse
 > org.osgi.framework.version=1.3.0
 > org.osgi.supports.framework.extension=true
 > os.arch=x86
 > os.name=Windows XP
 > os.version=5.1
 > osgi.arch=x86
 > osgi.bundles=org.eclipse.core.runtime@2:start, org.eclipse.update.configurator@3:start
 >  osgi.bundlestore=c:\eclipse\configuration\org.eclipse.osgi\b undles
 > osgi.configuration.area=file:/c:/eclipse/configuration/
 >  osgi.framework=file:/c:/eclipse/plugins/org.eclipse.osgi_3.1 .0.jar
 > osgi.framework.beginningstartlevel=1
 > osgi.framework.shape=jar
 > osgi.framework.version=3.0.0
 > osgi.install.area=file:/c:/eclipse/
 > osgi.instance.area=file:/C:/eclipse/workspace/
 > osgi.instance.area.default=file:/C:/Documents and Settings/dkantala/workspace/
 > osgi.logfile=C:\eclipse\workspace\.metadata\.log
 >  osgi.manifest.cache=c:\eclipse\configuration\org.eclipse.osg i\manifests
 > osgi.nl=en_US
 > osgi.os=win32
 >  osgi.splashLocation=c:\eclipse\plugins\org.eclipse.platform_ 3.1.0\splash.bmp
 > osgi.splashPath=platform:/base/plugins/org.eclipse.platform
 > osgi.syspath=c:\eclipse\plugins
 > osgi.ws=win32
 > path.separator=;
 > sun.arch.data.model=32
 > sun.boot.class.path=C:\Program Files\Java\jre1.5.0_02\lib\rt.jar;C:\Program Files\Java\jre1.5.0_02\lib\i18n.jar;C:\Program Files\Java\jre1.5.0_02\lib\sunrsasign.jar;C:\Program Files\Java\jre1.5.0_02\lib\jsse.jar;C:\Program Files\Java\jre1.5.0_02\lib\jce.jar;C:\Program Files\Java\jre1.5.0_02\lib\charsets.jar;C:\Program Files\Java\jre1.5.0_02\classes
 > sun.boot.library.path=C:\Program Files\Java\jre1.5.0_02\bin
 > sun.cpu.endian=little
 > sun.cpu.isalist=
 > sun.desktop=windows
 > sun.io.unicode.encoding=UnicodeLittle
 > sun.jnu.encoding=Cp1252
 > sun.management.compiler=HotSpot Client Compiler
 > sun.os.patch.level=Service Pack 2
 > user.country=US
 > user.dir=C:\eclipse
 > user.home=C:\Documents and Settings\dkantala
 > user.language=en
 > user.name=dkantala
 > user.timezone=America/New_York
 > user.variant=
 > *** Features:
 > org.eclipse.emf.doc (2.1.0.I200506230200) "Eclipse Modeling Framework (EMF) Programmers Guide"
 > org.eclipse.emf.ecore.sdo (2.1.0.I200506230200) "EMF Service Data Objects (SDO)"
 > org.eclipse.emf.ecore.sdo.doc (2.1.0.I200506230200) "EMF Service Data Objects (SDO) Programmers Guide"
 > org.eclipse.emf.ecore.sdo.source (2.1.0.I200506230200) "EMF Service Data Objects (SDO) Source"
 > org.eclipse.emf.examples (2.0.1) "Examples for Eclipse Modeling Framework (EMF)"
 > org.eclipse.emf.source (2.1.0.I200506230200) "Eclipse Modeling Framework (EMF) Source"
 > org.eclipse.gef.sdk (3.1.0) "Graphical Editing Framework Developer Resources"
 > org.eclipse.gef.source (3.1.0) "Graphical Editing Framework Developer Resources"
 > org.eclipse.pde.source (3.1.0) "Eclipse Plug-in Development Environment Developer Resources"
 > org.eclipse.platform.source (3.1.0) "Eclipse Platform Plug-in Developer Resources"
 > org.eclipse.xsd.doc (2.1.0.I200506230200) "XML Schema Infoset Model (XSD) Programmers Guide"
 > org.eclipse.xsd.source (2.1.0.I200506230200) "XML Schema Infoset Model (XSD) Source"
 > com.quantum.flatfiles (3.0.0) "QuantumDB Data Export-Import Plug-in" [Resolved]
 > es.org.chemi.games.minesweeper (3.1.0) "Eclipse-Games Minesweeper Plugin" [Resolved]
 > es.org.chemi.games.minesweeper.help (3.1.0) "Eclipse-Games Minesweeper Help Plugin" [Resolved]
 > es.org.chemi.games.minesweeper2 (3.1.0) "Eclipse-Games Minesweeper II Plugin" [Resolved]
 > es.org.chemi.games.minesweeper2.help (3.1.0) "Eclipse-Games Minesweeper II Help Plugin" [Resolved]
 > es.org.chemi.games.snake.help (3.1.0) "Eclipse-Games Snake Help Plugin" [Resolved]
 > es.org.chemi.games.sokoban (3.1.0) "Eclipse-Games Sokoban Plugin" [Active]
 > es.org.chemi.games.sokoban.help (3.1.0) "Eclipse-Games Sokoban Help Plugin" [Resolved]
 > org.eclipse.core.resources.compatibility (3.1.0) "Core Resource Management Compatibility Fragment" [Resolved]
 > org.eclipse.core.resources.win32 (3.1.0) "Core Resource Management Win32 Fragment" [Resolved]
 > org.eclipse.core.runtime.compatibility (3.1.0) "Core Runtime Plug-in Compatibility" [Active]
 > org.eclipse.emf.codegen.ecore (2.1.0) "EMF Ecore Code Generation" [Resolved]
 > org.eclipse.emf.codegen.ecore.ui (2.1.0) "EMF Ecore Code Generation UI" [Resolved]
 > org.eclipse.emf.codegen.ui (2.1.0) "EMF Template Code Generator UI" [Resolved]
 > org.eclipse.emf.doc (2.1.0.I200506230200) "Eclipse Modeling Framework (EMF) Programmers Guide" [Resolved]
 > org.eclipse.emf.ecore.change.edit (2.1.0) "EMF Ecore Change Edit Support" [Resolved]
 > org.eclipse.emf.ecore.sdo (2.1.0) "EMF Service Data Objects (SDO)" [Resolved]
 > org.eclipse.emf.ecore.sdo.doc (2.1.0.I200506230200) "EMF Service Data Objects (SDO) Programmers Guide" [Resolved]
 > org.eclipse.emf.ecore.sdo.edit (2.1.0) "EMF Service Data Objects (SDO) Edit Support" [Resolved]
 > org.eclipse.emf.ecore.sdo.editor (2.1.0) "EMF Service Data Objects (SDO) Editor" [Resolved]
 > org.eclipse.emf.ecore.sdo.source (2.1.0.I200506230200) "EMF Service Data Objects (SDO) Source" [Resolved]
 > org.eclipse.emf.examples (2.0.1) "Examples for Eclipse Modeling Framework (EMF)" [Resolved]
 > org.eclipse.emf.importer.java (2.1.0) "EMF Annotated Java Importer" [Resolved]
 > org.eclipse.emf.mapping.ecore2ecore (2.1.0) "Ecore to Ecore Mapping" [Resolved]
 > org.eclipse.emf.mapping.ecore2ecore.editor (2.1.0) "Ecore to Ecore Mapping Editor" [Resolved]
 > org.eclipse.emf.mapping.ecore2xml (2.1.0) "Ecore to XML Mapping" [Resolved]
 > org.eclipse.emf.mapping.ecore2xml.ui (2.1.0) "Ecore to XML Mapping UI" [Resolved]
 > org.eclipse.emf.mapping.xsd2ecore (2.1.0) "XSD to Ecore Mapping" [Resolved]
 > org.eclipse.emf.mapping.xsd2ecore.editor (2.1.0) "XSD to Ecore Mapping Editor" [Resolved]
 > org.eclipse.emf.source (2.1.0.I200506230200) "Eclipse Modeling Framework (EMF) Source" [Resolved]
 > org.eclipse.gef.doc.isv (3.1.0) "Graphical Editing Framework Documentation" [Resolved]
 > org.eclipse.gef.examples.flow (3.0.1) "GEF Flow Editor Example" [Resolved]
 > org.eclipse.gef.examples.logic (3.0.0) "GEF Logic Editor Example" [Resolved]
 > org.eclipse.gef.source (3.1.0) "Graphical Editing Framework Developer Resources" [Resolved]
 > org.eclipse.jdt.doc.isv (3.1.0) "Eclipse JDT Plug-in Developer Guide" [Resolved]
 > org.eclipse.jdt.doc.user (3.1.0) "Eclipse Java Development User Guide" [Resolved]
 > org.eclipse.jdt.junit (3.1.0) "Java Development Tools JUnit support" [Active]
 > org.eclipse.jdt.junit.runtime (3.1.0) "Java Development Tools JUnit runtime support" [Resolved]
 > org.eclipse.jdt.launching (3.1.0) "Java Development Tools Launching Support" [Active]
 > org.eclipse.jdt.source (3.1.0) "Eclipse Java Development Tools SDK" [Resolved]
 > org.eclipse.jem.beaninfo (1.1.0) "Java EMF Model BeanInfo (Introspection) Support" [Resolved]
 > org.eclipse.jem.beaninfo (1.0.2) "Java EMF Model BeanInfo (Introspection) Support" [Installed]
 > org.eclipse.jem.workbench (1.1.0) "Java EMF Model Workbench Support" [Active]
 > org.eclipse.jem.workbench (1.0.2) "Java EMF Model Workbench Support" [Installed]
 > org.eclipse.jst.common.annotations.controller (0.7.0) "Annotation Controller Plug-in" [Resolved]
 > org.eclipse.jst.common.annotations.core (0.7.0) "Annotation Core Plug-in" [Resolved]
 > org.eclipse.jst.common.frameworks (0.7.0) "Integration Plug-in" [Resolved]
 > org.eclipse.jst.common.navigator.java (0.7.0) "Navigator Plug-in" [Active]
 > org.eclipse.jst.j2ee.ejb.annotation.model (0.7.0) "EJB Annotation Model Plug-in" [Resolved]
 > org.eclipse.jst.j2ee.ejb.annotations.emitter (0.7.0) "EJB Emitter Plug-in" [Resolved]
 > org.eclipse.jst.j2ee.ejb.annotations.ui (0.7.0) "EJB Annotations Ui Plug-in" [Resolved]
 > org.eclipse.jst.j2ee.ejb.annotations.xdoclet (0.7.0) "Xdoclet Annotations Plug-in" [Resolved]
 > org.eclipse.jst.j2ee.navigator.ui (0.7.0) "J2EE Extensions to Common Navigator" [Active]
 > org.eclipse.jst.j2ee.webservices.ui (0.7.0) "WTP Webservice UI Plug-in" [Active]
 > org.eclipse.jst.server.generic.core (0.7.0) "Generic Server Plugin" [Active]
 > org.eclipse.jst.server.generic.serverdefinitions (0.7.0) "Generic server example definitions" [Resolved]
 > org.eclipse.jst.server.generic.ui (0.7.0) "Generic Server Plugin UI" [Active]
 > org.eclipse.jst.server.geronimo.core (0.7.0) "Geronimo server support" [Resolved]
 > org.eclipse.jst.server.geronimo.ui (0.7.0) "Geronimo server UI support" [Resolved]
 > org.eclipse.jst.server.tomcat.core (0.7.0) "Apache Tomcat Support" [Active]
 > org.eclipse.jst.server.tomcat.ui (0.7.0) "Apache Tomcat UI Support" [Resolved]
 > org.eclipse.jst.server.websphere.core (0.7.0) "WebSphere Generic Server Definition Core Plug-in" [Resolved]
 > org.eclipse.jst.source (0.7.0) "Webtools Platform J2EE Standard Tools Source (JST) Plug-in Developer Resources" [Resolved]
 > org.eclipse.jst.ws.axis.consumption.core (0.7.0) "Web service Axis Consumption Core" [Resolved]
 > org.eclipse.jst.ws.axis.consumption.ui (0.7.0) "Webservice Axis Consumption UI" [Resolved]
 > org.eclipse.jst.ws.axis.creation.ui (0.7.0) "Webservice Axis Creation UI" [Resolved]
 > org.eclipse.jst.ws.consumption (0.7.0) "Web Services Consumption" [Resolved]
 > org.eclipse.jst.ws.consumption.ui (0.7.0) "Web Services Consumption Graphical User Interface" [Resolved]
 > org.eclipse.jst.ws.creation.ejb.ui (0.7.0) "Web Services Creation EJB Graphical User Interface" [Resolved]
 > org.eclipse.jst.ws.creation.ui (0.7.0) "Web Services Creation Graphical User Interface" [Resolved]
 > org.eclipse.jst.ws.uddiregistry (0.7.0) "Web Services Universal Description Discovery and Integration Registry" [Resolved]
 > org.eclipse.jst.ws.ui (0.7.0) "Web Services Graphical User Interface" [Resolved]
 > org.eclipse.pde (3.1.0) "Eclipse Plug-in Development Environment" [Resolved]
 > org.eclipse.pde.build (3.1.0) "Plug-in Development Environment Build Support" [Resolved]
 > org.eclipse.pde.doc.user (3.1.0) "Eclipse Plug-in Development User Guide" [Resolved]
 > org.eclipse.pde.runtime (3.1.0) "Plug-in Development Environment Runtime" [Resolved]
 > org.eclipse.pde.source (3.1.0) "Eclipse Plug-in Development Environment Developer Resources" [Resolved]
 > org.eclipse.platform.doc.isv (3.1.0) "Eclipse Platform Plug-in Developer Guide" [Resolved]
 > org.eclipse.platform.doc.user (3.1.0) "Eclipse Workbench User Guide" [Resolved]
 > org.eclipse.platform.source (3.1.0) "Eclipse Platform Plug-in Developer Resources" [Resolved]
 > org.eclipse.platform.source.win32.win32.x86 (3.1.0) "Eclipse Platform Plug-in Developer Resources" [Resolved]
 > org.eclipse.rcp.source (3.1.0) "Eclipse RCP Plug-in Developer Resources" [Resolved]
 > org.eclipse.rcp.source.win32.win32.x86 (3.1.0) "Eclipse RCP Plug-in Developer Resources" [Resolved]
 > org.eclipse.swt.win32.win32.x86 (3.1.0) "Standard Widget Toolkit for Windows" [Resolved]
 > org.eclipse.ui.presentations.r21 (3.1.0) "R21 Presentation Plug-in" [Resolved]
 > org.eclipse.ui.workbench.compatibility (3.1.0) "Workbench Compatibility" [Resolved]
 > org.eclipse.ui.workbench.texteditor (3.1.0) "Text Editor Framework" [Active]
 > org.eclipse.update.configurator (3.1.0) "Install/Update Configurator" [Active]
 > org.eclipse.update.core.win32 (3.1.0) "Install/Update Core for Windows" [Resolved]
 > org.eclipse.update.scheduler (3.1.0) "Automatic Updates Scheduler" [Active]
 > org.eclipse.ve.jfc (1.0.2) "Visual Editor for Java Foundation Classes" [Resolved]
 > org.eclipse.ve.propertysheet (1.0.1) "Visual Editor PropertySheet" [Resolved]
 > org.eclipse.ve.swt (1.0.2) "Visual Editor for Standard Widget Toolkit" [Resolved]
 > org.eclipse.wst.command.env (0.7.0) "Environment Command Framework (headless)" [Resolved]
 > org.eclipse.wst.command.env.core (0.7.0) "Environment Command Framework (core)" [Resolved]
 > org.eclipse.wst.command.env.ui (0.7.0) "Environment Command Framework (GUI)" [Resolved]
 > org.eclipse.wst.common.emfworkbench.integration (0.7.0) "EMF Workbench Edit Plug-in" [Active]
 > org.eclipse.wst.common.frameworks (0.7.0) "org.eclipse.wst.common.frameworks" [Active]
 > org.eclipse.wst.common.navigator.views (0.7.0) "Common Navigator View" [Active]
 > org.eclipse.wst.common.navigator.workbench (0.7.0) "Navigator Workbench Components" [Active]
 > org.eclipse.wst.common.ui.properties (0.7.0) "Common Properties UI" [Active]
 > org.eclipse.wst.common.uriresolver (0.7.0) "org.eclipse.wst.common.uriresolver" [Active]
 > org.eclipse.wst.doc.user (0.7.0) "Web Standard Tools Help User Doc Plug-in" [Resolved]
 > org.eclipse.wst.html.core (0.7.0) "Structured Source HTML Model" [Resolved]
 > org.eclipse.wst.internet.cache (0.7.0) "Cache URI Resolver Plug-in" [Active]
 > org.eclipse.wst.internet.proxy (0.7.0) "Internet Proxy Preferences" [Active]
 > org.eclipse.wst.javascript.core (0.7.0) "Structured Source JavaScript Model" [Resolved]
 > org.eclipse.wst.javascript.ui (0.7.0) "SSE JavaScript Source Editor" [Resolved]
 > org.eclipse.wst.rdb.dbdefinition.db2.iseries (0.7.0) "DB2 UDB iSeries Database Definition Plug-in" [Resolved]
 > org.eclipse.wst.rdb.dbdefinition.db2.luw (0.7.0) "DB2 UDB Database Definition Plug-in" [Resolved]
 > org.eclipse.wst.rdb.dbdefinition.db2.zseries (0.7.0) "DB2 UDB Database Definition Plug-in" [Resolved]
 > org.eclipse.wst.rdb.dbdefinition.derby (0.7.0) "IBM Cloudscape Database Definition" [Resolved]
 > org.eclipse.wst.rdb.dbdefinition.informix (0.7.0) "Informix Database Definition Plug-in" [Resolved]
 > org.eclipse.wst.rdb.dbdefinition.mysql (0.7.0) "DBDefinition Mysql Plug-in" [Resolved]
 > org.eclipse.wst.rdb.dbdefinition.oracle (0.7.0) "Oracle Database Definition Plug-in" [Resolved]
 > org.eclipse.wst.rdb.dbdefinition.sqlserver (0.7.0) "SQL Server Database Definition Plug-in" [Resolved]
 > org.eclipse.wst.rdb.dbdefinition.sybase (0.7.0) "Sybase Database Definition Plug-in" [Resolved]
 > org.eclipse.wst.rdb.fe.ui.actions (0.7.0) "FE Ui Actions Plug-in" [Resolved]
 > org.eclipse.wst.rdb.models.dbdefinition (0.7.0) "DBDefinition Model" [Resolved]
 > org.eclipse.wst.rdb.models.sql.edit (0.7.0) "SQLModel Edit Plug-in" [Resolved]
 > org.eclipse.wst.rdb.server.extensions (0.7.0) "Server Explorer Extensions Plug-in" [Resolved]
 > org.eclipse.wst.rdb.sqleditor (0.7.0) "SQL Source Editor Plugin" [Resolved]
 > org.eclipse.wst.rdb.sqlscrapbook (0.7.0) "Sqlscrapbook Plug-in" [Resolved]
 > org.eclipse.wst.source (0.7.0) "Webtools Platform Web Standard Tools (WST) Source Plug-in Developer Resources" [Resolved]
 > org.eclipse.wst.validation.ui (0.7.0) "Validation Framework UI" [Resolved]
 > org.eclipse.wst.ws.parser (0.7.0) "Web Services Description Parser" [Resolved]
 > org.eclipse.xsd.doc (2.1.0.I200506230200) "XML Schema Infoset Model (XSD) Programmers Guide" [Resolved]
 > org.eclipse.xsd.ecore.importer (2.1.0) "XML Schema Importer for EMF" [Resolved]
 > org.eclipse.xsd.source (2.1.0.I200506230200) "XML Schema Infoset Model (XSD) Source" [Resolved]
 >  /instance/org.eclipse.compare/StructureViewerAliases=CLASSPA TH.XML
 >  /instance/org.eclipse.jdt.core/org.eclipse.jdt.core.builder. resourceCopyExclusionFilter=*.launch
 > /instance/org.eclipse.ui.workbench/Java-ORIG_persp=<?xml version\="1.0" encoding\="UTF-8"?>\r\n<perspective editorAreaVisible\="1" fixed\="0" version\="0.016">\r\n<descriptor descriptor\="org.eclipse.jdt.ui.JavaPerspective" id\="Java-ORIG" label\="Java-ORIG"/>\r\n<window height\="768" width\="1024" x\="106" y\="65"/>\r\n<actionSet id\="com_sysdeo_eclipse_tomcat_actionSet"/>\r\n<actionSet id\="org.eclipse.help.ui.actions"/>\r\n<actionSet id\=" org.eclipse.jst.servlet.ui.internal.actions.ConvertToWebModu leTypeActionSet "/>\r\n<actionSet id\="org.eclipse.jst.ws.consumption"/>\r\n<actionSet id\="org.eclipse.search.searchActionSet"/>\r\n<actionSet id\="org.eclipse.ui.cheatsheets.actionSet"/>\r\n<actionSet id\="org.eclipse.ui.edit.text.actionSet.openExternalFile"/ >\r\n<actionSet id\="org.eclipse.ui.edit.text.actionSet.newTextEditor"/>\r\n <actionSet id\="org.eclipse.ui.edit.text.actionSet.navigation"/>\r\n <actionSet id\="org.eclipse.ui.edit.text.actionSet.convertLineDelimitersTo "/>
 \r\n<actionSet id\="org.eclipse.ui.externaltools.ExternalToolsSet"/>\r\n <actionSet id\="org.eclipse.ui.actionSet.keyBindings"/>\r\n<actionSet id\="org.eclipse.update.ui.softwareUpdates"/>\r\n<actionSet id\="org.eclipse.debug.ui.launchActionSet"/>\r\n<actionSet id\="org.eclipse.jdt.ui.JavaActionSet"/>\r\n<actionSet id\="org.eclipse.jdt.ui.JavaElementCreationActionSet"/>\r\n <actionSet id\="org.eclipse.ui.NavigateActionSet"/>\r\n<actionSet id\="org.eclipse.debug.ui.breakpointActionSet"/>\r\n<actionSet id\="org.eclipse.jdt.debug.ui.JDTDebugActionSet"/>\r\n<actionSet id\="org.eclipse.jdt.junit.JUnitActionSet"/>\r\n<actionSet id\="org.vssplugin.menu.actionSet"/>\r\n<alwaysOnActionSet id\="com_sysdeo_eclipse_tomcat_actionSet"/>\r\n<alwaysOnActionSet id\="org.eclipse.help.ui.actions"/>\r\n<alwaysOnActionSet id\=" org.eclipse.jst.servlet.ui.internal.actions.ConvertToWebModu leTypeActionSet "/>\r\n<alwaysOnActionSet id\="org.eclipse.jst.ws.consumption"/>\r\n<alwaysOnActionSet id\="org.ecl
 ipse.search.searchActionSet"/>\r\n<alwaysOnActionSet id\="org.eclipse.ui.cheatsheets.actionSet"/>\r\n<alwaysOnActionSet id\="org.eclipse.ui.edit.text.actionSet.openExternalFile"/ >\r\n<alwaysOnActionSet id\="org.eclipse.ui.edit.text.actionSet.newTextEditor"/>\r\n <alwaysOnActionSet id\="org.eclipse.ui.edit.text.actionSet.navigation"/>\r\n <alwaysOnActionSet id\="org.eclipse.ui.edit.text.actionSet.convertLineDelimitersTo "/>\r\n<alwaysOnActionSet id\="org.eclipse.ui.externaltools.ExternalToolsSet"/>\r\n <alwaysOnActionSet id\="org.eclipse.ui.actionSet.keyBindings"/>\r\n<alwaysOnActionSet id\="org.eclipse.update.ui.softwareUpdates"/>\r\n<alwaysOnActionSet id\="org.eclipse.debug.ui.launchActionSet"/>\r\n<alwaysOnActionSet id\="org.eclipse.jdt.ui.JavaActionSet"/>\r\n<alwaysOnActionSet id\="org.eclipse.jdt.ui.JavaElementCreationActionSet"/>\r\n <alwaysOnActionSet id\="org.eclipse.ui.NavigateActionSet"/>\r\n<alwaysOnActionSet id\="org.eclipse.debug.ui.breakpointActionSet"/>\r\n<alwaysOnA
 ctionSet id\="org.eclipse.jdt.debug.ui.JDTDebugActionSet"/>\r\n<alwaysOnActionSet id\="org.eclipse.jdt.junit.JUnitActionSet"/>\r\n<alwaysOnActionSet id\="org.vssplugin.menu.actionSet"/>\r\n<show_view_action id\="org.eclipse.jdt.ui.PackageExplorer"/>\r\n<show_view_action id\="org.eclipse.jdt.ui.TypeHierarchy"/>\r\n<show_view_action id\="org.eclipse.jdt.ui.SourceView"/>\r\n<show_view_action id\="org.eclipse.jdt.ui.JavadocView"/>\r\n<show_view_action id\="org.eclipse.search.ui.views.SearchView"/>\r\n<show_view_action id\="org.eclipse.ui.console.ConsoleView"/>\r\n<show_view_action id\="org.eclipse.ui.views.ContentOutline"/>\r\n<show_view_action id\="org.eclipse.ui.views.ProblemView"/>\r\n<show_view_action id\="org.eclipse.ui.views.ResourceNavigator"/>\r\n<show_view_action id\="org.eclipse.ant.ui.views.AntView"/>\r\n<show_view_action id\="org.eclipse.pde.runtime.LogView"/>\r\n<new_wizard_action id\="org.eclipse.jdt.ui.wizards.NewPackageCreationWizard"/ >\r\n<new_wizard_action id\="
 org.eclipse.jdt.ui.wizards.NewClassCreationWizard"/>\r\n<new_wizard_action id\="org.eclipse.jdt.ui.wizards.NewInterfaceCreationWizard"/ >\r\n<new_wizard_action id\="org.eclipse.jdt.ui.wizards.EnumCreationWizard"/>\r\n <new_wizard_action id\="org.eclipse.jdt.ui.wizards.NewSourceFolderCreationWizard "/>\r\n<new_wizard_action id\="org.eclipse.jdt.ui.wizards.NewSnippetFileCreationWizard "/>\r\n<new_wizard_action id\="org.eclipse.ui.wizards.new.folder"/>\r\n<new_wizard_action id\="org.eclipse.ui.wizards.new.file"/>\r\n<new_wizard_action id\="org.eclipse.jdt.junit.wizards.NewTestCaseCreationWizard "/>\r\n<perspective_action id\="org.eclipse.jdt.ui.JavaPerspective"/>\r\n<perspective_action id\="org.eclipse.debug.ui.DebugPerspective"/>\r\n<perspective_action id\="org.eclipse.jdt.ui.JavaBrowsingPerspective"/>\r\n<view id\="org.eclipse.jdt.ui.PackageExplorer"/>\r\n<view id\="org.eclipse.jdt.ui.TypeHierarchy"/>\r\n<view id\="org.eclipse.ui.views.ProblemView"/>\r\n<view id\="org.eclipse.jdt.u
 i.JavadocView"/>\r\n<view id\="org.eclipse.jdt.ui.SourceView"/>\r\n<view id\="org.eclipse.ui.views.ContentOutline"/>\r\n<view id\="org.vssplugin.ui.checkout"/>\r\n<view id\="org.vssplugin.ui.logview"/>\r\n<layout>\r\n<mainWindow >\r\n<info folder\="true" part\="left">\r\n<folder activePageID\="org.eclipse.jdt.ui.PackageExplorer" appearance\="2" expanded\="2">\r\n<page content\="org.eclipse.jdt.ui.PackageExplorer" label\="Package Explorer"/>\r\n<page content\="org.eclipse.jdt.ui.TypeHierarchy" label\="Hierarchy"/>\r\n<page content\="org.eclipse.ui.views.ResourceNavigator" label\="LabelNotFound"/>\r\n<page content\="org.eclipse.jdt.junit.ResultView" label\="LabelNotFound"/>\r\n<presentation id\="org.eclipse.ui.presentations.WorkbenchPresentationFactory ">\r\n<part id\="0"/>\r\n<part id\="1"/>\r\n</presentation>\r\n</folder>\r\n</info>\r\n <info folder\="true" part\="stickyFolderRight" ratio\="0.74950296" ratioLeft\="754" ratioRight\="252" relationship\="2" relative\="left">\r\n<fo
 lder appearance\="2" expanded\="2">\r\n<page content\="org.eclipse.help.ui.HelpView" label\="LabelNotFound"/>\r\n<page content\="org.eclipse.ui.internal.introview" label\="LabelNotFound"/>\r\n<page content\="org.eclipse.ui.cheatsheets.views.CheatSheetView" label\="LabelNotFound"/>\r\n</folder>\r\n</info>\r\n<info part\="org.eclipse.ui.editorss" ratio\="0.24950299" ratioLeft\="251" ratioRight\="755" relationship\="2" relative\="left"/>\r\n<info folder\="true" part\="bottom" ratio\="0.7492163" ratioLeft\="478" ratioRight\="160" relationship\="4" relative\="org.eclipse.ui.editorss">\r\n<folder activePageID\="org.eclipse.ui.views.ProblemView" appearance\="2" expanded\="2">\r\n<page content\="org.eclipse.ui.views.ProblemView" label\="Problems"/>\r\n<page content\="org.eclipse.jdt.ui.JavadocView" label\="Javadoc"/>\r\n<page content\="org.eclipse.jdt.ui.SourceView" label\="Declaration"/>\r\n<page content\="org.eclipse.search.ui.views.SearchView" label\="LabelNotFound"/>\r\n<page con
 tent\="org.eclipse.ui.console.ConsoleView" label\="LabelNotFound"/>\r\n<page content\="org.eclipse.ui.views.BookmarkView" label\="LabelNotFound"/>\r\n<page content\="org.eclipse.ui.views.ProgressView" label\="LabelNotFound"/>\r\n<presentation id\="org.eclipse.ui.presentations.WorkbenchPresentationFactory ">\r\n<part id\="0"/>\r\n<part id\="1"/>\r\n<part id\="2"/>\r\n</presentation>\r\n</folder>\r\n</info>\r\n <info folder\="true" part\="org.eclipse.ui.internal.ViewStack@1ff323" ratio\="0.49933776" ratioLeft\="377" ratioRight\="378" relationship\="2" relative\="bottom">\r\n<folder activePageID\="org.vssplugin.ui.checkout" appearance\="2" expanded\="2">\r\n<page content\="org.vssplugin.ui.checkout" label\="Checked Out Files"/>\r\n<presentation id\="org.eclipse.ui.presentations.WorkbenchPresentationFactory ">\r\n<part id\="0"/>\r\n</presentation>\r\n</folder>\r\n</info>\r\n <info folder\="true" part\="org.eclipse.ui.internal.ViewStack@193b022" ratio\="0.5" ratioLeft\="189" ratioRigh
 t\="189" relationship\="2" relative\="org.eclipse.ui.internal.ViewStack@1ff323">\r\n<folder activePageID\="org.vssplugin.ui.logview" appearance\="2" expanded\="2">\r\n<page content\="org.vssplugin.ui.logview" label\="VSS Refresh Log"/>\r\n<presentation id\="org.eclipse.ui.presentations.WorkbenchPresentationFactory ">\r\n<part id\="0"/>\r\n</presentation>\r\n</folder>\r\n</info>\r\n <info folder\="true" part\="org.eclipse.ui.internal.ViewStack@1d97efc" ratio\="0.7496689" ratioLeft\="566" ratioRight\="189" relationship\="2" relative\="org.eclipse.ui.editorss">\r\n<folder activePageID\="org.eclipse.ui.views.ContentOutline" appearance\="2" expanded\="2">\r\n<page content\="org.eclipse.ui.views.ContentOutline" label\="Outline"/>\r\n<page content\="org.eclipse.ant.ui.views.AntView" label\="LabelNotFound"/>\r\n<presentation id\="org.eclipse.ui.presentations.WorkbenchPresentationFactory ">\r\n<part id\="0"/>\r\n</presentation>\r\n</folder>\r\n</info>\r\n </mainWindow>\r\n</layout>\r\n</p
 erspective>\r\n
 >  /instance/org.eclipse.wst.internet.proxy/userNameText=encode d\:
 >  /instance/org.eclipse.ui.ide/EXIT_PROMPT_ON_CLOSE_LAST_WINDO W=false
 >  /instance/org.eclipse.wst.sse.core/task-tag-projects-already -scanned=.JETEmitters,BPE,BPE-Paging,DRK  Testing,Servers,SwingTest2,Tiles-Test,jakarta-jetspeed-2,jet speed,jpetstore,IES-339
 > /instance/org.eclipse.team.cvs.ui/pref_text_ksubst=-kk
 >  /instance/es.org.chemi.games.sokoban/inf_original=1|true|drk |258|97|58\#2|true|drk|502|147|143\#3|true|drk|377|144|95\#4 |true|drk|1027|415|254\#5|true|drk|434|149|105\#6|true|drk|3 17|117|79\#7|true|drk|358|98|128\#8|true|drk|672|262|176\#9| true|drk|592|239|166\#10|true|drk|1409|550|334\#11|false|-|0 |0|0\#12|false|-|0|0|0\#13|false|-|0|0|0\#14|false|-|0|0|0\# 15|false|-|0|0|0\#16|false|-|0|0|0\#17|false|-|0|0|0\#18|fal se|-|0|0|0\#19|false|-|0|0|0\#20|false|-|0|0|0\#21|false|-|0 |0|0\#22|false|-|0|0|0\#23|false|-|0|0|0\#24|false|-|0|0|0\# 25|false|-|0|0|0\#26|false|-|0|0|0\#27|false|-|0|0|0\#28|fal se|-|0|0|0\#29|false|-|0|0|0\#30|false|-|0|0|0\#31|false|-|0 |0|0\#32|false|-|0|0|0\#33|false|-|0|0|0\#34|false|-|0|0|0\# 35|false|-|0|0|0\#36|false|-|0|0|0\#37|false|-|0|0|0\#38|fal se|-|0|0|0\#39|false|-|0|0|0\#40|false|-|0|0|0\#41|false|-|0 |0|0\#42|false|-|0|0|0\#43|false|-|0|0|0\#44|false|-|0|0|0\# 45|false|-|0|0|0\#46|false|-|0|0|0\#47|false|-|0|0|0\#48|fal se|-|0|0|0\#49|false|-|0|0|
 0\#50|false|-|0|0|0\#
 > @org.vssplugin=1.6.1
 > /instance/org.eclipse.ui/DOCK_PERSPECTIVE_BAR=topLeft
 >  /instance/org.eclipse.jdt.ui/org.eclipse.jdt.ui.text.custom_ code_templates= <?xml version\="1.0" encoding\="UTF-8"?><templates/>
 > /instance/org.eclipse.jdt.ui/formatter_profile=_Custom
 >  /instance/org.eclipse.ui.ide/SWITCH_PERSPECTIVE_ON_PROJECT_C REATION=always
 > @org.eclipse.jst.jsp.core=0.7.0
 > /instance/org.eclipse.ui.ide/platformState=936
 > @org.eclipse.ui.ide=3.1.0
 >  /instance/org.eclipse.jst.server.tomcat.core/locationorg.ecl ipse.jst.server.tomcat.runtime.32=C\:/Program Files/Apache Software Foundation/Tomcat 3.2.4
 > @org.eclipse.jdt.core=3.1.0
 > /instance/org.eclipse.jdt.ui/spelling_ignore_digits=true
 >  /instance/org.eclipse.jdt.core/org.eclipse.jdt.core.classpat hVariable.ECLIPSE_HOME=c\:/eclipse
 >  /instance/org.eclipse.jst.j2ee.ejb.annotations.xdoclet/org.e clipse.jst.j2ee.ejb.annotations.xdoclet.XDOCLETBUILDERACTIVE =true
 >  /instance/org.eclipse.ui.workbench/org.eclipse.jdt.ui.JavaPe rspective_persp= <?xml version\="1.0" encoding\="UTF-8"?>\r\n<perspective editorAreaVisible\="1" fixed\="0" version\="0.016">\r\n<descriptor class\="org.eclipse.jdt.internal.ui.JavaPerspectiveFactory" id\="org.eclipse.jdt.ui.JavaPerspective" label\="Java"/>\r\n<window height\="768" width\="1024" x\="106" y\="65"/>\r\n<actionSet id\="com_sysdeo_eclipse_tomcat_actionSet"/>\r\n<actionSet id\="org.eclipse.help.ui.actions"/>\r\n<actionSet id\=" org.eclipse.jst.servlet.ui.internal.actions.ConvertToWebModu leTypeActionSet "/>\r\n<actionSet id\="org.eclipse.jst.ws.consumption"/>\r\n<actionSet id\="org.eclipse.search.searchActionSet"/>\r\n<actionSet id\="org.eclipse.ui.cheatsheets.actionSet"/>\r\n<actionSet id\="org.eclipse.ui.edit.text.actionSet.openExternalFile"/ >\r\n<actionSet id\="org.eclipse.ui.edit.text.actionSet.newTextEditor"/>\r\n <actionSet id\="org.eclipse.ui.edit.text.actionSet.navigation"/>\r\n <actionSet id\="org.e
 clipse.ui.edit.text.actionSet.convertLineDelimitersTo"/>\r\n <actionSet id\="org.eclipse.ui.externaltools.ExternalToolsSet"/>\r\n <actionSet id\="org.eclipse.ui.actionSet.keyBindings"/>\r\n<actionSet id\="org.eclipse.update.ui.softwareUpdates"/>\r\n<actionSet id\="org.eclipse.debug.ui.launchActionSet"/>\r\n<actionSet id\="org.eclipse.jdt.ui.JavaActionSet"/>\r\n<actionSet id\="org.eclipse.jdt.ui.JavaElementCreationActionSet"/>\r\n <actionSet id\="org.eclipse.ui.NavigateActionSet"/>\r\n<actionSet id\="org.eclipse.debug.ui.breakpointActionSet"/>\r\n<actionSet id\="org.eclipse.jdt.debug.ui.JDTDebugActionSet"/>\r\n<actionSet id\="org.eclipse.jdt.junit.JUnitActionSet"/>\r\n<actionSet id\="org.vssplugin.menu.actionSet"/>\r\n<alwaysOnActionSet id\="com_sysdeo_eclipse_tomcat_actionSet"/>\r\n<alwaysOnActionSet id\="org.eclipse.help.ui.actions"/>\r\n<alwaysOnActionSet id\=" org.eclipse.jst.servlet.ui.internal.actions.ConvertToWebModu leTypeActionSet "/>\r\n<alwaysOnActionSet id\="org.eclipse.
 jst.ws.consumption"/>\r\n<alwaysOnActionSet id\="org.eclipse.search.searchActionSet"/>\r\n<alwaysOnActionSet id\="org.eclipse.ui.cheatsheets.actionSet"/>\r\n<alwaysOnActionSet id\="org.eclipse.ui.edit.text.actionSet.openExternalFile"/ >\r\n<alwaysOnActionSet id\="org.eclipse.ui.edit.text.actionSet.newTextEditor"/>\r\n <alwaysOnActionSet id\="org.eclipse.ui.edit.text.actionSet.navigation"/>\r\n <alwaysOnActionSet id\="org.eclipse.ui.edit.text.actionSet.convertLineDelimitersTo "/>\r\n<alwaysOnActionSet id\="org.eclipse.ui.externaltools.ExternalToolsSet"/>\r\n <alwaysOnActionSet id\="org.eclipse.ui.actionSet.keyBindings"/>\r\n<alwaysOnActionSet id\="org.eclipse.update.ui.softwareUpdates"/>\r\n<alwaysOnActionSet id\="org.eclipse.debug.ui.launchActionSet"/>\r\n<alwaysOnActionSet id\="org.eclipse.jdt.ui.JavaActionSet"/>\r\n<alwaysOnActionSet id\="org.eclipse.jdt.ui.JavaElementCreationActionSet"/>\r\n <alwaysOnActionSet id\="org.eclipse.ui.NavigateActionSet"/>\r\n<alwaysOnActionSet id\="o
 rg.eclipse.debug.ui.breakpointActionSet"/>\r\n<alwaysOnActionSet id\="org.eclipse.jdt.debug.ui.JDTDebugActionSet"/>\r\n<alwaysOnActionSet id\="org.eclipse.jdt.junit.JUnitActionSet"/>\r\n<alwaysOnActionSet id\="org.vssplugin.menu.actionSet"/>\r\n<show_view_action id\="org.eclipse.jdt.ui.PackageExplorer"/>\r\n<show_view_action id\="org.eclipse.jdt.ui.TypeHierarchy"/>\r\n<show_view_action id\="org.eclipse.jdt.ui.SourceView"/>\r\n<show_view_action id\="org.eclipse.jdt.ui.JavadocView"/>\r\n<show_view_action id\="org.eclipse.search.ui.views.SearchView"/>\r\n<show_view_action id\="org.eclipse.ui.console.ConsoleView"/>\r\n<show_view_action id\="org.eclipse.ui.views.ContentOutline"/>\r\n<show_view_action id\="org.eclipse.ui.views.ProblemView"/>\r\n<show_view_action id\="org.eclipse.ui.views.ResourceNavigator"/>\r\n<show_view_action id\="org.eclipse.ant.ui.views.AntView"/>\r\n<show_view_action id\="org.eclipse.pde.runtime.LogView"/>\r\n<new_wizard_action id\="org.eclipse.jdt.ui.wizards
 ..NewPackageCreationWizard"/>\r\n<new_wizard_action id\="org.eclipse.jdt.ui.wizards.NewClassCreationWizard"/>\r\n <new_wizard_action id\="org.eclipse.jdt.ui.wizards.NewInterfaceCreationWizard"/ >\r\n<new_wizard_action id\="org.eclipse.jdt.ui.wizards.EnumCreationWizard"/>\r\n <new_wizard_action id\="org.eclipse.jdt.ui.wizards.NewSourceFolderCreationWizard "/>\r\n<new_wizard_action id\="org.eclipse.jdt.ui.wizards.NewSnippetFileCreationWizard "/>\r\n<new_wizard_action id\="org.eclipse.ui.wizards.new.folder"/>\r\n<new_wizard_action id\="org.eclipse.ui.wizards.new.file"/>\r\n<new_wizard_action id\="org.eclipse.jdt.junit.wizards.NewTestCaseCreationWizard "/>\r\n<perspective_action id\="org.eclipse.jdt.ui.JavaPerspective"/>\r\n<perspective_action id\="org.eclipse.debug.ui
| Re: The server may already be running in another process, or a system process may be using the port. [message #117607 is a reply to message #117575] | Thu, 07 July 2005 13:17   |  |
| Eclipse User  |  |  |  |  | Originally posted by: dkantala.modulant.com
 I shut down the system when I left last night.  I booted it up, started
 eclipse and tried to launch the server and recieved the same message.  I
 have not been able to sucessfully start the server today.  I can however
 start it using the SYSDEO Tomcat plugin (which currently does not allow
 me to step through debugging).
 Whenever I was able to start/stop the server, the debug view did show
 that the server was terminated.  Whenever the server would not start, I
 looked at the system process and notice an Apache.exe running.  I killed
 that process, but the server still would not start.  There was also an
 javaw.exe process running, but that was my eclipse process (figured that
 out from past experience).
 Thanks for your help,
 Dmytro
 > Cheers,
 > Larry
 > Dmytro Kantala wrote:
 >> I meant to attach my configuration details with the last message
 >>> Operating System is Windows XP Service Pack 2
 >>> Here is my configuration Details:
 >>> Eclipse SDK 3.1.0 Build id: I20050627-1435
 >>> EMF SDK 2.1.0.I200506230200
 >>> GEF SDK 3.1.0
 >>> J2EE Standard Tools Feature and Web Standard Tools Feature SDK 0.7.0
 >>> Java EMF Model SDK 1.1.0
 >>> Visual Editor SDK 1.0.2.1
 >>> Additional plugins that may or may not effect the server:
 >>> QuantumDB 3.0.0
 >>> Eclipse-Games 3.1.0
 >>> VSS Plugin 1.6.1
 >>> SYSDEO 3.1.0.beta (this does launch Tomcat fine)
 >>> I am using Tomcat 5.5 on JRE 1.5
 >>> I did not setup a generic server, I used the one located under
 >>> Apache. Tomcat is installed in default location:  C:\Program
 >>> Files\Apache Software Foundation\Tomcat 5.5
 >>> Eclipse is installed at C:\eclipse
 >>> Workspace I am using is within eclipse folder
 >>> Larry Isaacs wrote:
 >>>> What are the details of WTP and the system you are running?
 >>>> Larry
 >>>>> I use to be able to start a tomcat server without any issues.  Now
 >>>>> I am consistently running into this problem.   If I get this
 >>>>> message when starting the server, I am always given that message
 >>>>> when I keep trying. I have to restart eclipse so that the server
 >>>>> will start.  Now even after I restart eclipse I constantly get that
 >>>>> message.  I have run netstat to determine if any other application
 >>>>> is using that port and none are.  Any help on this would be
 >>>>> appricieated.  I would rather start/stop server from within eclipse
 >>>>> than to do it externally.
 >>>>> Thanks
 >> *** Date: Thu Jul 07 09:50:38 EDT 2005
 >> *** Platform Details:
 >> *** System properties:
 >> win32
 >> -ws
 >> win32
 >> -arch
 >> x86
 >> -launcher
 >> C:\eclipse\eclipse.exe
 >> -name
 >> Eclipse
 >> -showsplash
 >> 600
 >> -exitdata
 >> 3f0_60
 >> -data
 >> -vm
 >> -Xmx256m
 >> -jar
 >> eof=eof
 >> file.separator=\
 >> Profiler 5.2.1\bin
 >> line.separator=
 a
 icA
 >> os.arch=x86
 >> os.name=Windows XP
 >> os.version=5.1
 >> osgi.arch=x86
 >> osgi.nl=en_US
 >> osgi.os=win32
 >> osgi.ws=win32
 >> path.separator=;
 >> sun.cpu.isalist=
 >> sun.desktop=windows
 >> user.country=US
 >> user.dir=C:\eclipse
 >> user.language=en
 >> user.name=dkantala
 >> user.variant=
 >> *** Features:
 >> es.org.chemi.games (3.1.0) "Eclipse-Games"
 >> org.eclipse.emf (2.1.0.I200506230200) "Eclipse Modeling Framework (EMF)"
 >> Objects (SDO)"
 >> Framework (EMF)"
 >> org.eclipse.gef (3.1.0) "Graphical Editing Framework"
 >> org.eclipse.gef.examples (3.0.1) "GEF Examples"
 >> Resources"
 >> Resources"
 >> org.eclipse.jdt (3.1.0) "Eclipse Java Development Tools"
 >> org.eclipse.jem (1.1.0) "Java EMF Model"
 >> org.eclipse.jem.sdk (1.1.0) "Java EMF Model SDK"
 >> org.eclipse.jem.source (1.1.0) "Java EMF Model Source"
 >> org.eclipse.platform (3.1.0) "Eclipse Platform"
 >> org.eclipse.rcp (3.1.0) "Eclipse RCP"
 >> org.eclipse.sdk (3.1.0) "Eclipse Project SDK"
 >> org.eclipse.ve (1.0.2.1) "Visual Editor"
 >> org.eclipse.ve.sdk (1.0.2.1) "Visual Editor SDK"
 >> org.eclipse.ve.source (1.0.2.1) "Visual Editor Source"
 >> org.eclipse.xsd (2.1.0.I200506230200) "XML Schema Infoset Model (XSD)"
 >> (XSD) Source"
 >> *** Plug-in Registry:
 >> com.ibm.etools.emf.event (3.0.0.1) "Event Model" [Resolved]
 >> com.ibm.wtp.common.util (1.0.1) "Logging Plug-in" [Resolved]
 >> com.ibm.wtp.emf.workbench (1.0.1.2) "EMF Workbench" [Resolved]
 >> com.quantum.dbunit (3.0.0) "QuantumDB DbUnit Plug-in" [Resolved]
 >> [Resolved]
 >> com.quantum.help (3.0.0) "Help Plug-in" [Resolved]
 >> com.quantum.Quantum (3.0.0) "Quantum DB Utility" [Resolved]
 >> com.sysdeo.eclipse.tomcat (3.1.0.beta) "Tomcat Plugin" [Active]
 >> es.org.chemi.games (3.1.0) "Eclipse-Games" [Active]
 >> Plugin" [Resolved]
 >> Plugin" [Resolved]
 >> es.org.chemi.games.snake (3.1.0) "Eclipse-Games Snake Plugin" [Resolved]
 >> Plugin" [Resolved]
 >> [Active]
 >> Plugin" [Resolved]
 >> org.apache.ant (1.6.5) "Apache Ant" [Resolved]
 >> org.apache.axis11 (1.1.0) "Apache Axis 1.1 Plug-in" [Resolved]
 >> org.apache.axis11 (0.7.0) "Apache Axis 1.1 Plug-in" [Resolved]
 >> org.apache.lucene (1.4.3) "Apache Lucene" [Resolved]
 >> org.apache.wsil4j (1.0.0) "Apache WSIL4J 1.0" [Resolved]
 >> org.apache.wsil4j (0.7.0) "Apache WSIL4J 1.0" [Resolved]
 >> org.apache.xerces (2.6.2) "Apache Xerces Content" [Resolved]
 >> org.eclipse.ant.core (3.1.0) "Ant Build Tool Core" [Resolved]
 >> org.eclipse.ant.ui (3.1.0) "Ant UI" [Resolved]
 >> org.eclipse.compare (3.1.0) "Compare Support" [Active]
 >> org.eclipse.core.boot (3.1.0) "Core Boot" [Resolved]
 >> org.eclipse.core.commands (3.1.0) "Commands" [Active]
 >> org.eclipse.core.expressions (3.1.0) "Expression Language" [Active]
 >> org.eclipse.core.filebuffers (3.1.0) "File Buffers" [Active]
 >> org.eclipse.core.resources (3.1.0) "Core Resource Management" [Active]
 >> org.eclipse.core.runtime (3.1.0) "Core Runtime" [Active]
 >> org.eclipse.core.variables (3.1.0) "Core Variables" [Resolved]
 >> org.eclipse.debug.core (3.1.0) "Debug Core" [Active]
 >> org.eclipse.debug.ui (3.1.0) "Debug UI" [Active]
 >> org.eclipse.draw2d (3.1.0) "Draw2d" [Resolved]
 >> org.eclipse.draw2d.doc.isv (3.1.0) "Draw2D Documentation" [Resolved]
 >> org.eclipse.emf (2.1.0) "Eclipse Modeling Framework (EMF)" [Resolved]
 >> org.eclipse.emf.activities (2.0.0) "EMF Activities" [Resolved]
 >> org.eclipse.emf.ant (2.1.0) "EMF Ant Tasks" [Resolved]
 >> org.eclipse.emf.codegen (2.1.0) "EMF Template Code Generator" [Resolved]
 >> [Resolved]
 >> UI" [Resolved]
 >> [Resolved]
 >> org.eclipse.emf.common (2.1.0) "EMF Common" [Active]
 >> org.eclipse.emf.common.ui (2.1.0) "EMF Common UI" [Resolved]
 >> org.eclipse.emf.commonj.sdo (2.1.0) "CommonJ SDO" [Resolved]
 >> org.eclipse.emf.ecore (2.1.0) "EMF Ecore" [Active]
 >> org.eclipse.emf.ecore.change (2.1.0) "EMF Ecore Change Model" [Resolved]
 >> Support" [Resolved]
 >> org.eclipse.emf.ecore.edit (2.1.0) "EMF Ecore Edit Support" [Resolved]
 >> org.eclipse.emf.ecore.editor (2.1.0) "Sample Ecore Editor" [Resolved]
 >> [Resolved]
 >> org.eclipse.emf.ecore.xmi (2.1.0) "EMF XMI" [Active]
 >> org.eclipse.emf.edit (2.1.0) "EMF Edit" [Active]
 >> org.eclipse.emf.edit.ui (2.1.0) "EMF Edit UI" [Active]
 >> org.eclipse.emf.importer (2.1.0) "EMF Model Import Support" [Resolved]
 >> org.eclipse.emf.importer.ecore (2.1.0) "EMF Ecore Importer" [Resolved]
 >> [Resolved]
 >> org.eclipse.emf.importer.rose (2.1.0) "EMF Rose Importer" [Resolved]
 >> org.eclipse.emf.java (2.0.1) "EMF Java" [Resolved]
 >> org.eclipse.emf.java.edit (2.0.0) "EMF Java Edit" [Resolved]
 >> org.eclipse.emf.java.editor (2.0.1) "EMF Java Editor" [Resolved]
 >> org.eclipse.emf.mapping (2.1.0) "EMF Mapping" [Resolved]
 >> [Resolved]
 >> [Resolved]
 >> [Resolved]
 >> org.eclipse.emf.mapping.ui (2.1.0) "EMF Mapping UI" [Resolved]
 >> [Resolved]
 >> Editor" [Resolved]
 >> org.eclipse.gef (3.1.0) "Graphical Editing Framework" [Resolved]
 >> [Resolved]
 >> [Resolved]
 >> org.eclipse.gef.examples.source (3.0.1) "GEF Examples" [Resolved]
 >> org.eclipse.help (3.1.0) "Help System Core" [Active]
 >> org.eclipse.help.appserver (3.1.0) "Help Application Server" [Resolved]
 >> org.eclipse.help.base (3.1.0) "Help System Base" [Resolved]
 >> org.eclipse.help.ui (3.1.0) "Help System UI" [Resolved]
 >> org.eclipse.help.webapp (3.1.0) "Help System Webapp" [Resolved]
 >> org.eclipse.jdt (3.1.0) "Eclipse Java Development Tools" [Resolved]
 >> org.eclipse.jdt.core (3.1.0) "Java Development Tools Core" [Active]
 >> org.eclipse.jdt.debug (3.1.0) "JDI Debug Model" [Active]
 >> org.eclipse.jdt.debug.ui (3.1.0) "JDI Debug UI" [Active]
 >> [Resolved]
 >> [Resolved]
 >> [Active]
 >> Support" [Active]
 >> [Resolved]
 >> org.eclipse.jdt.ui (3.1.0) "Java Development Tools UI" [Active]
 >> org.eclipse.jem (1.1.0) "Java EMF Model" [Active]
 >> org.eclipse.jem (1.0.2) "Java EMF Model" [Installed]
 >> org.eclipse.jem.proxy (1.1.0) "Java EMF Model Proxy Support" [Resolved]
 >> org.eclipse.jem.proxy (1.0.2) "Java EMF Model Proxy Support" [Installed]
 >> org.eclipse.jem.sdk (1.1.0) "Java EMF Model SDK" [Resolved]
 >> org.eclipse.jem.sdk (1.0.1) "Java EMF Model SDK" [Resolved]
 >> org.eclipse.jem.source (1.1.0) "Java EMF Model Source" [Resolved]
 >> org.eclipse.jem.source (1.0.2.1) "Java EMF Model Source" [Installed]
 >> org.eclipse.jem.ui (1.1.0) "Java EMF Model UI" [Resolved]
 >> org.eclipse.jem.ui (1.0.1) "Java EMF Model UI" [Installed]
 >> org.eclipse.jem.util (1.1.0) "Java EMF Model Utilities" [Active]
 >> [Active]
 >> [Installed]
 >> org.eclipse.jface (3.1.0) "JFace" [Active]
 >> org.eclipse.jface.text (3.1.0) "JFace Text" [Active]
 >> Plug-in" [Resolved]
 >> org.eclipse.jst.common.annotations.ui (0.7.0) "Ui Plug-in" [Resolved]
 >> [Resolved]
 >> [Active]
 >> org.eclipse.jst.doc.isv (0.7.0) "JST ISV Documentation" [Resolved]
 >> org.eclipse.jst.doc.user (0.7.0) "JST User Doc Plug-in" [Resolved]
 >> org.eclipse.jst.ejb.ui (0.7.0) "WTP EJB UI Plug-in" [Resolved]
 >> org.eclipse.jst.j2ee (0.7.0) "J2EE Component" [Active]
 >> org.eclipse.jst.j2ee.core (0.7.0) "J2EE Core Component" [Active]
 >> org.eclipse.jst.j2ee.ejb (0.7.0) "EJB component Plug-in" [Active]
 >> Plug-in" [Resolved]
 >> Plug-in" [Resolved]
 >> org.eclipse.jst.j2ee.jca (0.7.0) "JCA Plug-in" [Active]
 >> org.eclipse.jst.j2ee.jca.ui (0.7.0) "WTP JCA UI Plug-in" [Resolved]
 >> Navigator" [Active]
 >> org.eclipse.jst.j2ee.ui (0.7.0) "WTP J2EE UI Plug-in" [Active]
 >> org.eclipse.jst.j2ee.web (0.7.0) "Web Plug-in" [Active]
 >> org.eclipse.jst.j2ee.webservice (0.7.0) "Web Service Plug-in" [Active]
 >> Plug-in" [Active]
 >> org.eclipse.jst.jsp.core (0.7.0) "Structured Source JSP Model" [Active]
 >> org.eclipse.jst.jsp.ui (0.7.0) "SSE JSP Source Editor" [Active]
 >> org.eclipse.jst.server.core (0.7.0) "Java Server Support" [Active]
 >> [Active]
 >> [Active]
 >> [Resolved]
 >> support" [Resolved]
 >> [Active]
 >> [Resolved]
 >> org.eclipse.jst.server.ui (0.7.0) "Java Server UI Support" [Resolved]
 >> org.eclipse.jst.servlet.ui (0.7.0) "WTP Servlet UI Plug-in" [Resolved]
 >> org.eclipse.jst.ws (0.7.0) "Web Services" [Resolved]
 >> UI" [Resolved]
 >> [Resolved]
 >> [Resolved]
 >> org.eclipse.ltk.core.refactoring (3.1.0) "Refactoring Core" [Active]
 >> org.eclipse.ltk.ui.refactoring (3.1.0) "Refactoring UI" [Active]
 >> org.eclipse.osgi.services (3.1.0) "OSGi Release 3 Services" [Resolved]
 >> org.eclipse.osgi.util (3.1.0) "OSGi R3 Utility Classes" [Resolved]
 >> [Resolved]
 >> Support" [Resolved]
 >> org.eclipse.pde.core (3.1.0) "Plug-in Development Core" [Active]
 >> Guide" [Resolved]
 >> org.eclipse.pde.junit.runtime (3.1.0) "PDE JUnit Plug-in Test" [Resolved]
 >> Runtime" [Resolved]
 >> org.eclipse.pde.ui (3.1.0) "Plug-in Development UI" [Active]
 >> org.eclipse.platform (3.1.0) "Eclipse Platform" [Resolved]
 >> [Resolved]
 >> org.eclipse.rcp (3.1.0) "Eclipse RCP" [Resolved]
 >> org.eclipse.sdk (3.1.0) "Eclipse Project SDK" [Resolved]
 >> org.eclipse.search (3.1.0) "Search Support" [Active]
 >> org.eclipse.swt (3.1.0) "Standard Widget Toolkit" [Resolved]
 >> Windows" [Resolved]
 >> org.eclipse.team.core (3.1.0) "Team Support Core" [Active]
 >> org.eclipse.team.cvs.core (3.1.0) "CVS Team Provider Core" [Active]
 >> org.eclipse.team.cvs.ssh (3.1.0) "CVS SSH Core" [Resolved]
 >> org.eclipse.team.cvs.ssh2 (3.1.0) "CVS SSH2" [Resolved]
 >> org.eclipse.team.cvs.ui (3.1.0) "CVS Team Provider UI" [Active]
 >> org.eclipse.team.ui (3.1.0) "Team Support UI" [Active]
 >> org.eclipse.text (3.1.0) "Text" [Active]
 >> org.eclipse.tomcat (4.1.30.1) "Tomcat Wrapper" [Resolved]
 >> org.eclipse.ui (3.1.0) "Eclipse UI" [Active]
 >> org.eclipse.ui.browser (3.1.0) "Browser Support" [Active]
 >> org.eclipse.ui.cheatsheets (3.1.0) "Cheat Sheets" [Resolved]
 >> org.eclipse.ui.console (3.1.0) "Console" [Active]
 >> org.eclipse.ui.editors (3.1.0) "Default Text Editor" [Active]
 >> org.eclipse.ui.externaltools (3.1.0) "External Tools" [Active]
 >> org.eclipse.ui.forms (3.1.0) "Eclipse Forms" [Active]
 >> org.eclipse.ui.ide (3.1.0) "Eclipse IDE UI" [Active]
 >> org.eclipse.ui.intro (3.1.0) "Welcome Framework" [Resolved]
 >> [Resolved]
 >> org.eclipse.ui.views (3.1.0) "Views" [Active]
 >> org.eclipse.ui.win32 (3.1.0) "Eclipse UI Win32 Enhancements" [Resolved]
 >> org.eclipse.ui.workbench (3.1.0) "Workbench" [Active]
 >> [Active]
 >> [Active]
 >> org.eclipse.update.core (3.1.0) "Install/Update Core" [Active]
 >> Windows" [Resolved]
 >> [Active]
 >> org.eclipse.update.ui (3.1.0) "Install/Update UI" [Active]
 >> org.eclipse.ve (1.0.1) "Visual Editor" [Resolved]
 >> org.eclipse.ve.cde (1.0.2) "Visual Editor Common Data Editor" [Resolved]
 >> org.eclipse.ve.doc (1.0.1) "Visual Editor User Guide" [Resolved]
 >> org.eclipse.ve.java.core (1.0.2.1) "Visual Editor Java Core" [Resolved]
 >> [Resolved]
 >> [Resolved]
 >> org.eclipse.ve.sdk (1.0.1) "Visual Editor SDK" [Resolved]
 >> org.eclipse.ve.source (1.0.2.1) "Visual Editor Source" [Resolved]
 >> [Resolved]
 >> (GUI)" [Resolved]
 >> org.eclipse.wst.common.emf (0.7.0) "EMF Utilities" [Active]
 >> org.eclipse.wst.common.frameworks.ui (0.7.0) "WTP UI Plug-in" [Active]
 >> org.eclipse.wst.common.modulecore (0.7.0) "Modulecore Plug-in" [Active]
 >> [Active]
 >> org.eclipse.wst.common.snippets (0.7.0) "Snippets View" [Resolved]
 >> org.eclipse.wst.common.ui (0.7.0) "Eclipse Base UI extensions" [Resolved]
 >> [Active]
 >> org.eclipse.wst.css.core (0.7.0) "Structured Source CSS Model" [Resolved]
 >> org.eclipse.wst.css.ui (0.7.0) "SSE CSS Source Editor" [Resolved]
 >> org.eclipse.wst.doc.isv (0.7.0) "WST ISV Documentation" [Resolved]
 >> Plug-in" [Resolved]
 >> org.eclipse.wst.dtd.core (0.7.0) "Structured Source DTD Core" [Resolved]
 >> org.eclipse.wst.dtd.ui (0.7.0) "SSE DTD Source Editor" [Resolved]
 >> [Resolved]
 >> org.eclipse.wst.html.standard.dtds (0.7.0) "Known DTDs" [Resolved]
 >> org.eclipse.wst.html.ui (0.7.0) "HTML UI Source Editor" [Resolved]
 >> [Active]
 >> org.eclipse.wst.internet.monitor.core (0.7.0) "Monitor" [Resolved]
 >> org.eclipse.wst.internet.monitor.ui (0.7.0) "TCP/IP Monitor" [Resolved]
 >> [Active]
 >> Model" [Resolved]
 >> [Resolved]
 >> org.eclipse.wst.rdb.connection.ui (0.7.0) "RDB Connection.ui" [Resolved]
 >> org.eclipse.wst.rdb.core (0.7.0) "RDB Core" [Resolved]
 >> org.eclipse.wst.rdb.core.ui (0.7.0) "Core UI plugin" [Resolved]
 >> org.eclipse.wst.rdb.data.core (0.7.0) "Data Core Plugin" [Resolved]
 >> org.eclipse.wst.rdb.data.ui (0.7.0) "Data UI Plugin" [Resolved]
 >> Plug-in" [Resolved]
 >> org.eclipse.wst.rdb.derby (0.7.0) "RDB Derby Plug-in" [Resolved]
 >> org.eclipse.wst.rdb.derby.ui (0.7.0) "RDB Derby Ui Plug-in" [Resolved]
 >> org.eclipse.wst.rdb.fe.ui (0.7.0) "FE Ui Plug-in" [Resolved]
 >> [Resolved]
 >> [Resolved]
 >> org.eclipse.wst.rdb.models.sql (0.7.0) "SQLModel Plug-in" [Resolved]
 >> [Resolved]
 >> org.eclipse.wst.rdb.mysql (0.7.0) "RDB Mysql Plug-in" [Resolved]
 >> org.eclipse.wst.rdb.outputview (0.7.0) "Data Output Plug-in" [Resolved]
 >> org.eclipse.wst.rdb.server.ui (0.7.0) "Server Explorer plugin" [Resolved]
 >> [Resolved]
 >> [Resolved]
 >> org.eclipse.wst.server.core (0.7.0) "Server Core" [Active]
 >> org.eclipse.wst.server.ui (0.7.0) "Server UI" [Active]
 >> org.eclipse.wst.sse.core (0.7.0) "Structured Text Model" [Active]
 >> org.eclipse.wst.sse.ui (0.7.0) "Structured Source Editor" [Resolved]
 >> org.eclipse.wst.validation (0.7.0) "Validation Framework" [Active]
 >> [Resolved]
 >> org.eclipse.wst.web (0.7.0) "Simple Web Plug-in" [Active]
 >> org.eclipse.wst.web.ui (0.7.0) "Simple Web UI Plug-in" [Resolved]
 >> org.eclipse.wst.ws (0.7.0) "Web Services" [Resolved]
 >> org.eclipse.wst.ws.explorer (0.7.0) "Web Services Explorer" [Resolved]
 >> [Resolved]
 >> org.eclipse.wst.ws.ui (0.7.0) "Web Services UI" [Resolved]
 >> org.eclipse.wst.wsdl (0.7.0) "WSDL Model" [Active]
 >> org.eclipse.wst.wsdl.ui (0.7.0) "WSDL Editor" [Resolved]
 >> org.eclipse.wst.wsdl.validation (0.7.0) "WSDL Validator" [Resolved]
 >> org.eclipse.wst.wsi (0.7.0) "WSI Conformance Tools" [Resolved]
 >> org.eclipse.wst.wsi.ui (0.7.0) "Soap Monitor" [Resolved]
 >> org.eclipse.wst.xml.core (0.7.0) "Structured Source XML Model" [Active]
 >> org.eclipse.wst.xml.ui (0.7.0) "XML UI Plugin" [Active]
 >> org.eclipse.wst.xsd.core (0.7.0) "XSD Core Plugin" [Resolved]
 >> org.eclipse.wst.xsd.ui (0.7.0) "XML Schema Editor" [Resolved]
 >> org.eclipse.xsd (2.1.0) "XML Schema Infoset Model (XSD)" [Resolved]
 >> [Resolved]
 >> org.eclipse.xsd.edit (2.1.0) "XML Schema Edit Framework" [Resolved]
 >> org.eclipse.xsd.editor (2.1.0) "XML Schema Editor" [Resolved]
 >> org.junit (3.8.1) "JUnit Testing Framework" [Resolved]
 >> org.uddi4j (1.0.0) "UDDI4J 2.0.3" [Resolved]
 >> org.uddi4j (0.7.0) "UDDI4J 2.0.3" [Resolved]
 >> org.vssplugin (1.6.1) "VSS Plugin Functions for Eclipse" [Active]
 >> org.wsdl4j (1.0.0) "WSDL4J 1.4" [Resolved]
 >> system.bundle (3.1.0) "OSGi System Bundle" [Active]
 >> *** User Preferences:
 >> #Thu Jul 07 09:50:38 EDT 2005
 > \r\n<actionSet
 > ctionSet
 > id\="
 > id\="0"/>\r\n<part
 > erspective>\r\n
| Re: The server may already be running in another process, or a system process may be using the port. [message #117622 is a reply to message #117607] | Thu, 07 July 2005 13:40   |  |
| Eclipse User  |  |  |  |  | Which port(s) does the error message report as in use?  If you change the configuration to use a different port(s) than the one(s) mentioned,
 does it still have start/stop problems?
 Larry
 > Dmytro
 >> Debug view show that the Tomcat server fully terminated?
 >> again.  You can also try to use the Windows Task Manager to spot the
 >> Tomcat instance of javaw.exe and make sure it disappears when Tomcat
 >> is stopped.
 >> Cheers,
 >> Larry
 >>>> GEF SDK 3.1.0
 >>>> QuantumDB 3.0.0
 >>>> Eclipse-Games 3.1.0
 >>>> VSS Plugin 1.6.1
 >>>>> Larry
 >>>>>> that message.  I have run netstat to determine if any other
 >>>>>> application is using that port and none are.  Any help on this
 >>>>>> would be appricieated.  I would rather start/stop server from
 >>>>>> within eclipse than to do it externally.
 >>>>>> Thanks
 <snip/>
| Re: The server may already be running in another process, or a system process may be using the port. [message #117633 is a reply to message #117622] | Thu, 07 July 2005 14:08   |  |
 Its currently setup to:
 admin on port 8005
 HTTP 8080
 AJP/1.3 8009
 When I first received the error I said fine, changed all three ports to
 something different  (8006/8081/8010).  Received the same message.  I
 have tried to do that more than once with different port numbers.
 8080 is the port that I am currently using.  Whats funny is that I have
 the SYSDEO plungin pointing to the server.xml within the Server project.
 So WTP and SYSDEO is using the exact same configuration.  When I
 launch  WTP server, I receive the error.  I close the dialog box and can
 immediately launch tomcat from SYSDEO without issues.
 A little more background information.  I intermediately receive this
 error when using WTP M4.  I was able to do the restart eclipse
 workaround to restart servers.  I updated to M5 hoping the problem might
 be resolved (or go away).  The first few hours everything seemed fine,
 but then the errors started again.  Before today, I was still able to
 restart eclipse as a workaround solution.  As an FYI, I did make a
 backup of my M4 eclipse,  installed 3.1 and configured M5, then imported
 my previous workspace.  So I believe 3.1 with M5 is properly installed
 and configured.
 > Larry
 >> started eclipse and tried to launch the server and recieved the same
 >> message.  I have not been able to sucessfully start the server today.
 >> I can however start it using the SYSDEO Tomcat plugin (which currently
 >> does not allow me to step through debugging).
 >> I looked at the system process and notice an Apache.exe running.  I
 >> killed that process, but the server still would not start.  There was
 >> also an javaw.exe process running, but that was my eclipse process
 >> (figured that out from past experience).
 >> Dmytro
 >>> webapps to fully clean up before finishing its shutdown.  I'm
 >>> wondering this might be the cause of the inability to subsequently
 >>> start Tomcat again.  You can also try to use the Windows Task Manager
 >>> to spot the Tomcat instance of javaw.exe and make sure it disappears
 >>> Cheers,
 >>> Larry
 >>>>> GEF SDK 3.1.0
 >>>>> QuantumDB 3.0.0
 >>>>> Eclipse-Games 3.1.0
 >>>>> VSS Plugin 1.6.1
 >>>>>> Larry
 >>>>>>> Now I am consistently running into this problem.   If I get this
 >>>>>>> Thanks
 > <snip/>
| Re: The server may already be running in another process, or a system process may be using the port. [message #117657 is a reply to message #117633] | Thu, 07 July 2005 15:08   |  |
| Eclipse User  |  |  |  |  | From inspecting source code, this error can only occur if WTP thinks the port is in use.  WTP tries to create a server socket for the port in
 question and any exception causes the port to be considered as being
 used.  An unexpected form of exception may be occurring which is
 unrelated to the port actually being in use.  A source tweak will be
 required to find out more.  Do you happen to be using the WTP SDK, which
 includes the sources?
 Larry
 > admin on port 8005
 > HTTP 8080
 > AJP/1.3 8009
 > and configured.
 >> mentioned, does it still have start/stop problems?
 >> Larry
 >>> today.  I can however start it using the SYSDEO Tomcat plugin (which
 >>> currently does not allow me to step through debugging).
 >>> Dmytro
 >>>> Manager to spot the Tomcat instance of javaw.exe and make sure it
 >>>> Cheers,
 >>>> Larry
 >>>>>> GEF SDK 3.1.0
 >>>>>> QuantumDB 3.0.0
 >>>>>> Eclipse-Games 3.1.0
 >>>>>> VSS Plugin 1.6.1
 >>>>>>> Larry
 >>>>>>>> Thanks
 >> <snip/>
| Re: The server may already be running in another process, or a system process may be using the port. [message #117682 is a reply to message #117657] | Thu, 07 July 2005 15:23   |  |
 Yes, I am running WTP SDK.  I am not sure how to import/complile/run it
 yet.  I am looking for some tutorials now.
 > Larry
 >> admin on port 8005
 >> HTTP 8080
 >> AJP/1.3 8009
 >> to something different  (8006/8081/8010).  Received the same message.
 >> I have tried to do that more than once with different port numbers.
 >> have the SYSDEO plungin pointing to the server.xml within the Server
 >> project.  So WTP and SYSDEO is using the exact same configuration.
 >> When I launch  WTP server, I receive the error.  I close the dialog
 >> box and can immediately launch tomcat from SYSDEO without issues.
 >> might be resolved (or go away).  The first few hours everything seemed
 >> fine, but then the errors started again.  Before today, I was still
 >> able to restart eclipse as a workaround solution.  As an FYI, I did
 >> make a backup of my M4 eclipse,  installed 3.1 and configured M5, then
 >> imported my previous workspace.  So I believe 3.1 with M5 is properly
 >> installed and configured.
 >>> Larry
 >>>> show that the server was terminated.  Whenever the server would not
 >>>> start, I looked at the system process and notice an Apache.exe
 >>>> running.  I killed that process, but the server still would not
 >>>> start.  There was also an javaw.exe process running, but that was my
 >>>> eclipse process (figured that out from past experience).
 >>>> Dmytro
 >>>>> Cheers,
 >>>>> Larry
 >>>>>>> GEF SDK 3.1.0
 >>>>>>> QuantumDB 3.0.0
 >>>>>>> Eclipse-Games 3.1.0
 >>>>>>> VSS Plugin 1.6.1
 >>>>>>>> Larry
 >>>>>>>>> this message when starting the server, I am always given that
 >>>>>>>>> message when I keep trying. I have to restart eclipse so that
 >>>>>>>>> the server will start.  Now even after I restart eclipse I
 >>>>>>>>> constantly get that message.  I have run netstat to determine
 >>>>>>>>> if any other application is using that port and none are.  Any
 >>>>>>>>> help on this would be appricieated.  I would rather start/stop
 >>>>>>>>> server from within eclipse than to do it externally.
 >>>>>>>>> Thanks
 >>> <snip/>
| Re: The server may already be running in another process, or a system process may be using the port. [message #117706 is a reply to message #117682] | Thu, 07 July 2005 16:02   |  |
| Eclipse User  |  |  |  |  | Here is what to do:
 1) Start Eclipse in a fresh workspace (recommended).
 2) Execute File->Import... and select External Plug-ins and Fragments.
 3) Click Next and change the "Import As" radio selection to "Projects
 with source folders".
 3) Click Next, select the "org.eclipse.wst.server.core" and click "Add-->".
 4) Click Finish and you should see a new plug-in project in your workspace.
 5) Open the org.eclipse.wst.server.core.util.SocketUtil Java file.
 6) In the isPortInUse(int port) method, add "e.printStackTrace();" just
 above each "return true;" statement.
 7) Save the changes and select the org.eclipse.wst.server.core project
 in the Navigator or Package Explorer.
 8) Execute Debug -> Debug As -> Eclipse Application and try to duplicate
 your problem.  Hopefully you will see some useful output in the Console
 of the first Eclipse.  You can also set breakpoints to see what path is
 being taken through the isPortInUse(int port) method.
 Let me know what you find out.
 Larry
 >> in question and any exception causes the port to be considered as
 >> being used.  An unexpected form of exception may be occurring which is
 >> which includes the sources?
 >> Larry
 >>> admin on port 8005
 >>> HTTP 8080
 >>> AJP/1.3 8009
 >>> message.  I have tried to do that more than once with different port
 >>> numbers.
 >>> seemed fine, but then the errors started again.  Before today, I was
 >>> still able to restart eclipse as a workaround solution.  As an FYI, I
 >>> did make a backup of my M4 eclipse,  installed 3.1 and configured M5,
 >>> then imported my previous workspace.  So I believe 3.1 with M5 is
 >>> properly installed and configured.
 >>>> Larry
 >>>>> same message.  I have not been able to sucessfully start the server
 >>>>> (which currently does not allow me to step through debugging).
 >>>>> my eclipse process (figured that out from past experience).
 >>>>> Dmytro
 >>>>> Larry Isaacs wrote:
 >>>>>> Thanks.  On a fresh session of Eclipse, what happens when you
 >>>>>> start and stop the server from the Servers view in debug mode?
 >>>>>> Does the Debug view show that the Tomcat server fully terminated?
 >>>>>> Tomcat 4 and up have the characteristic of waiting forever for
 >>>>>> disappears when Tomcat is stopped.
 >>>>>> Cheers,
 >>>>>> Larry
 >>>>>>>> GEF SDK 3.1.0
 >>>>>>>> 0.7.0
 >>>>>>>> QuantumDB 3.0.0
 >>>>>>>> Eclipse-Games 3.1.0
 >>>>>>>> VSS Plugin 1.6.1
 >>>>>>>>> Larry
 >>>>>>>>>> Thanks
 >>>> <snip/>
| Re: The server may already be running in another process, or a system process may be using the port. [message #118004 is a reply to message #117826] | Fri, 08 July 2005 09:25   |  |
 I actually have multiple servers running.  Our product runs on multiple
 production environments tomcat 4.1/jdk 1.4 tomcat 5.0/jdk 1.4 and one
 tomcat 5.5/jdk 1.5.   Each run into the same problem when trying to
 launch.  When I stated earlier JRE 1.5, its really JDK 1.5.
 After I setup the environment like Larry has stated, everything seems to
 be running fine.   I am debugging the workspace that has all my servers
 and stuff.  I am just waiting now for whenever the problem occurs again.
 David Williams wrote:
 > On Thu, 07 Jul 2005 13:17:10 -0400, Dmytro Kantala
 > Just out of curiosity (I haven't carefully read all
 > the posts on this, but have you tried Tomcat 5.0x with JDK 1.4?
 > Plus, you do mention "JRE 1.5" ... you know you usually want to use a
 > JDK for
 > server runtimes ... not JREs"
 > All of these are long shots, but if you can rule out some cases, that might
 > help Larry and others pin it down easier.
 > Thanks.
| Re: The server may already be running in another process, or a system process may be using the port. [message #118017 is a reply to message #118004] | Fri, 08 July 2005 09:26  |  |
 I should have clarified.  I dont try to run them all at same time.  When
 one ran into the problem.  I would try to stop it (but its already
 stopped) and try to launch one of the others.  I get the same message.
 >> JDK for
 >> might
 >> Thanks.
 Current Time: Fri Oct 31 04:01:46 EDT 2025
 Powered by FUDForum . Page generated in 0.05621 seconds |
