Home » Archived » Test and Performance Tools Platform (TPTP) » Customized Outputter class
Customized Outputter class [message #117084] Mon, 05 November 2007 00:31 Go to next message
Is it possible to extend LogImportOutputter.
can i get the source code of this class.
or is there any way to manage LogView data programatically so that i can
write a customized Outputter class to update log records in log view.
or Do i need to create a customized view to display log records in a
customized fashion.
Thanks You
Prasad
Re: Customized Outputter class [message #117425 is a reply to message #117084] Tue, 06 November 2007 21:51 Go to previous messageGo to next message
Hi Prasad,
you can find the source code for the LogImportOutputter in the TPTP CVS
repository:
host: dev.eclipse.org
repository path: /cvsroot/tptp
module: monitoring/org.eclipse.hyades.logging.parsers
source file:
org.eclipse.hyades.logging.parsers\src.import\org\eclipse\hy ades\logging\parsers\adapter\outputters\LogImportOutputter.j ava.
You could extend the LogImportOutputter and use it in your custom adapter.
This way CBECommonBaseEvent objects (for each log record) are gonna be
created for you by the XMLLoader and added to a TRCAgent object. You can
then view the content of the agent in the log viewer. What is the customized
fashion you would like to display your log records ? There are no extension
points to customize the log viewer, so you would probably need to extend it
to your needs. I've already responded to this topic in a previous post.
Kind regards,
Alex Nan.
"prasad" <prasad.kumbhare@gmail.com> wrote in message
news:8f17e6c43795b2a2dd2de253df8b5bc4$1@www.eclipse.org...
> customized fashion.
> Thanks You
> Prasad
Re: Customized Outputter class [message #117955 is a reply to message #117425] Mon, 12 November 2007 05:23 Go to previous message
Hi Alan,
Thanks for the details. I have defined couple of extended data elements
which i would like to view as column data in the log view. Is there any
way to do this?
Thanks you
Prasad
Previous Topic:Open Source Software Research
Next Topic:Log view extension point
Current Time: Fri Nov 07 02:06:37 EST 2025
Powered by FUDForum. Page generated in 0.04090 seconds
