Home » Language IDEs » ServerTools (WTP) » XMLBuddy and M5
XMLBuddy and M5 [message #115386] Fri, 01 July 2005 20:36 Go to next message
Originally posted by: bob.objfac.com
They seem to co-exist fairly well (assuming that xsd editor exception
wasn't caused by a conflict - it didn't look like it). I installed WST
by unzipping in a clean 3.1 final, then added XMLBuddy Pro from an
internal update site. It's kind of random which editors get to be the
default - XMLBuddy for *.xml, WST for *.xsd and *.dtd - but other than
that, no problems so far.
Bob Foster
http://xmlbuddy.com/
Re: XMLBuddy and M5 [message #115424 is a reply to message #115386] Sat, 02 July 2005 11:43 Go to previous messageGo to next message
I spoke too soon. :( I opened an XML file in WST editor. Seemed to be
fine. Closed and reopened with XMLBuddy. Fine. Closed and reopened with
WST editor. No syntax coloring.
Bob
> Bob Foster
Re: XMLBuddy and M5 [message #115457 is a reply to message #115424] Sat, 02 July 2005 12:37 Go to previous messageGo to next message
Internally, lots of exceptions thrown as wst editor tried to call my
partitioner.
Bob
> Bob
>> Bob Foster
Re: XMLBuddy and M5 [message #116974 is a reply to message #115424] Wed, 06 July 2005 16:48 Go to previous messageGo to next message
Bob, I tried re-creating a conflict with our WTP M5 editors and "version 2 based editors"
by using the sample XML editor the PDE will build as a sample ... but, they seem to
co-exist just fine. Do you have any insight into why that editor might work but yours
would not?
Also, a bugzilla with the logs/config attached would be helpful.
Seems especially odd your observed bugs would be order dependendent.
I assume you're using a "neutral" XML file? Not one like web.xml (which is
access by several parts of WTP, at different times)?
Re: XMLBuddy and M5 [message #117078 is a reply to message #116974] Wed, 06 July 2005 20:39 Go to previous messageGo to next message
Sure. The reason is you're still using the default partitioner. When
XMLBuddy starts, if it doesn't find its partitioner in a document, it
replaces it.
Yes to "neutral" XML.
The only real solution that will keep us out of each other's hair is to
stop using the default partitioner. This is just a bug waiting to
happen. I have detailed the reasons I haven't done it already. What are
yours? ;-}
Bob
> 2 based editors"
> they seem to
> work but yours
> would not?
Re: XMLBuddy and M5 [message #117482 is a reply to message #117078] Thu, 07 July 2005 11:03 Go to previous message
On Wed, 06 Jul 2005 20:39:25 -0400, Bob Foster <bob@objfac.com> wrote:
> What are
> yours? ;-}
Not sure ... in fact, I initially discounted some of this thread because I thought for
we were not using it any longer (I remember removing it) but now that I look at it, seems
we are setting it to "NullPartioner" in some cases. I suspect we were finding NPE's if not set to something,
so put in this "catch all" ... but reading the API spec's, it sounds like the old getPartioner() * is * allowed to return null, which I'm guessing, is what you are suggesting we do? And if so, we'll look into that this week, and see if we can re-create any problems doing so. If not, we'll simply stop doing and
humbling request you recheck.
When you say you check add your partioner if not there, I assume you mean by finding getPartioner returns null, then you set with setPartioner(partioner)? This would work for exactly two conflicts, right? Ours and yours but no other 2.1 based editors following same scheme?
I've opened Bug 103022 (XML Editor conflicts with 2.1 based editors).
Please follow that, if interested, and we can document issues there.
Thanks for clarifying.
Previous Topic:WebService : The AXIS engine could not find a target service to invoke!
Next Topic:HTML editor does not open
Current Time: Sat Nov 08 17:05:33 EST 2025
Powered by FUDForum. Page generated in 0.04854 seconds
