Home » Eclipse Projects » Remote Application Platform (RAP) » TreeViewer not expanding, and Tree widget
TreeViewer not expanding, and Tree widget [message #116956] Mon, 22 December 2008 15:20 Go to next message
I have been testing with RAP and I took the TreeViewer example from the
demo site and have been making changes to it. I am having a problem where
that I want to add a Text field above my TreeViewer, so I have done the
following;
Composite contents = new Composite(parent, SWT.HORIZONTAL);
contents.setLayout(new GridLayout(1,false));
Text inputText = new Text(contents, SWT.BORDER);
inputText.setLayoutData(
new GridData(GridData.FILL_HORIZONTAL));
viewer = new TreeViewer(contents);
and the Input text expands to fill the screen, but not the TreeViewer.
However there is no method for "setLayoutData" on the Treeviewer, so I
can't expand it that way, and at the moment its crunched up on the left.
(2nd question - whats the difference between the SWT Tree widget and the
jface TreeViewer, can either be used, or one rather than the other?)
Many Thanks,
Tom
Re: TreeViewer not expanding, and Tree widget [message #116970 is a reply to message #116956] Mon, 22 December 2008 15:41 Go to previous messageGo to next message
Ah, almost immediately after posting that, is discovered;
viewer.getTree().setLayoutData(new GridData(GridData.FILL_BOTH));
The question on the difference between the jface and the swt widgets still
stands though?
Tom
Re: TreeViewer not expanding, and Tree widget [message #117009 is a reply to message #116970] Tue, 23 December 2008 05:35 Go to previous messageGo to next message
http://wiki.eclipse.org/JFace
http://wiki.eclipse.org/SWT
HTH
Rüdiger
> still stands though?
> Tom
Re: TreeViewer not expanding, and Tree widget [message #117021 is a reply to message #117009] Tue, 23 December 2008 05:46 Go to previous messageGo to next message
So I should be using jface toolkit objects in preference to SWT widgets
when available?
Re: TreeViewer not expanding, and Tree widget [message #117055 is a reply to message #117021] Tue, 23 December 2008 08:31 Go to previous message
yes, in most cases you will be better off using JFace.
> when available?
Previous Topic:Problem with ScrolledComposite
Next Topic:updating table from server push in RAP
Current Time: Sat Jul 26 12:45:59 EDT 2025
Powered by FUDForum. Page generated in 0.04126 seconds
