Home » Eclipse Projects » Equinox » Programmatically add BuddyClass-Loading to a Bundle
Programmatically add BuddyClass-Loading to a Bundle [message #116575] Tue, 26 August 2008 17:26 Go to next message
The following situation:
- org.hibernate.eclipse has
=> Eclipse-BuddyPolicy:registered
- at.bestsolution.soccer.core.datasource.teneo has
=> Eclipse-RegisterBuddy: org.hibernate.eclipse
=> Configures hibernate-eclipse and instructs it to use jdbc as Driver
e.g. org.apache.derby.jdbc.Driver
- org.apache.derby
Naturally the hibernate plugin could not create an instance of
org.apache.derby.jdbc.Driver. This could be fixed by adding
org.apache.derby as dependency to datasource.teneo but driver is defined
by user so if there's a mysql-bundle in the system he/she could specify it.
What do you suggest how can I fix this? Could I somehow programmtically
do something like "Eclipse-RegisterBuddy: org.hibernate.eclipse" does?
So that org.hibernate.eclipse can see it?
The only plugin in the system I control is datasource.teneo. Any ideas?
Tom
B e s t S o l u t i o n . at
Tom Schindl JFace-Committer
Re: Programmatically add BuddyClass-Loading to a Bundle [message #116582 is a reply to message #116575] Wed, 27 August 2008 06:18 Go to previous messageGo to next message
Can you do the following in datasource.teneo?
Bundle dbDriverBundle = getBundle("bla");
java.sql.Driver driver = (java.sql.Driver) dbDriverBundle.loadClass("blah");
// user driver in Hibernate by specifying correct URL
AFAIK, a driver registers itself with the DriverManager. Does Hibernate
really want a driver instance or does it use the DriverManager?
Note, a DataSource might work too.
-Gunnar
Gunnar Wagenknecht
gunnar@wagenknecht.org
http://wagenknecht.org/
Re: Programmatically add BuddyClass-Loading to a Bundle [message #116589 is a reply to message #116582] Wed, 27 August 2008 07:53 Go to previous messageGo to next message
Hi Gunnar,
Teneo only wants a String "org.blabla.bla.Driver". I rethought the thing
yesterday in the evening and came to the solution that
datasource.teneo needs to provide an extension point where external
plugins register themselves against it and provide informations.
So what I have now is:
- hibernate.eclipse.
* Eclipse-BuddyPolicy:registered
- datasource.teneo
* Eclipse-RegisterBuddy: org.hibernate.eclipse
* Teneo-Extension-Point
=> hibernate-dialect
- datasource.teneo.derby
* Dependency on datasource.teneo
* Dependency on apache.derby
- apache.derby
I haven't tried it yet but this should solve the problem. This also
helps me to configure the Hibernate-Dialects available because I simply
have to query the extension point. People can now even contribute their
own Dialect.
Tom
> -Gunnar
Re: Programmatically add BuddyClass-Loading to a Bundle [message #116901 is a reply to message #116589] Mon, 01 September 2008 08:36 Go to previous messageGo to next message
Originally posted by: amottadelli_NO_SPAM.it.ibm.com
I'm curious about the reasons that make the people use "BuddyClass-Loading".
Please correct me if I'm wrong:
- usually frameworks and libraries designed to work in a J2EE
environment rely on thread context class loader to load "user" classes
- Equinox (or OSGi in general) cannot guarantee what is in the tccl
because this is out of its scope.
- Buddy class loading is an hack to work around this limitation
"forcing" the tccl looking up for the "correct" class loader in the call
stack.
In the (limited) scope of OSGi, buddy class loading is an elegant
solution to the problem, but the solution is outside the (current) scope
of OSGi.
Every application needs a thread or process model, so each application
environment is (or should) perfectly able to know and control what is in
the thread context class loader.
Sandro
Re: Programmatically add BuddyClass-Loading to a Bundle [message #116940 is a reply to message #116901] Mon, 01 September 2008 13:13 Go to previous messageGo to next message
Yes. That's the problem. Designing a Java library just with a very
specific thread/execution model in mind is a poor design choice.
Well, nobody can, not even the JVM or any other container.
> of OSGi.
IMHO buddy class loading is neither elegant nor a solution to class
loading problem. Same is true for the TCCL. If you design *any* Java
code correctly, you don't need either one (whether the code runs in a
JavaEE container, inside a mobile phone or on the desktop).
-Gunnar
Gunnar Wagenknecht
Re: Programmatically add BuddyClass-Loading to a Bundle [message #116979 is a reply to message #116940] Tue, 02 September 2008 15:12 Go to previous messageGo to next message
Don't J2EE containers do that?
>> of OSGi.
Could you elaborate? What is in your opinion the best solution to have
custom code loaded by a java library?
> -Gunnar
Sandro
Re: Programmatically add BuddyClass-Loading to a Bundle [message #117028 is a reply to message #116979] Wed, 03 September 2008 08:02 Go to previous message
IMHO it really depends on your use case. Personally, I made very good
experiences with OSGi services as well as Equinox extension points.
Of course, this means modifying (or wrapping) third party libraries in a
way that they make use of one of both. But this shouldn't be a problem
with open source libraries. Sometimes its as easy as adding a bit more
flexibility (eg.
http://code.google.com/p/google-web-toolkit/issues/detail?id =1888).
-Gunnar
Gunnar Wagenknecht
Previous Topic:Errors after Tomcat reload
Next Topic:p2.generator task
Current Time: Sat Oct 04 08:09:08 EDT 2025
Powered by FUDForum. Page generated in 0.04003 seconds
