Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » TENEO - ID is coming as null(MySQLIntegrityConstraintViolationException, ID cannot be null.)
TENEO - ID is coming as null [message #1162356] Wed, 30 October 2013 06:19 Go to next message
I have an EMF model A which refernces Model B. B has list of models c which is of non containement relationship. Iam trying to persist Model A into database using TENEO framework.
I have set following property
PersistenceOptions.FETCH_ASSOCIATION_EXTRA_LAZY as true.
Whenever i try to persist Model A iam getting following error.
com.mysql.jdbc.exceptions.jdbc4.MySQLIntegrityConstraintViolationException: Column 'B_id' cannot be null.
Plese let me know what is causing the above error.
Chandru
Re: TENEO - ID is coming as null [message #1163781 is a reply to message #1162356] Thu, 31 October 2013 03:55 Go to previous messageGo to next message
Hi Chandre,
Not sure but I guess you are not using auto-generated primary keys, I guess. Or maybe in this case you can also check
the cascade settings of the A-->B association. Maybe persist/create is not cascaded.
For info on cascade settings the Hibernate/JPA docs can tell you more.
gr. Martin
On 10/30/2013 11:19 AM, Chandre Gowda wrote:
> trying to persist Model A into database using TENEO framework. I have set following property
> Thanks
> Chandru
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Mail: mtaal@xxxxxxxx - mtaal@xxxxxxxx
Re: TENEO - ID is coming as null [message #1164111 is a reply to message #1163781] Thu, 31 October 2013 08:48 Go to previous messageGo to next message
Thanks Martin.
Iam using autogenerated id(e_id).
I have set following cascade policy while intializing the DATASTORE.
PersistenceOptions.CASCADE_POLICY_ON_NON_CONTAINMENT, "REFRESH,PERSIST,MERGE".
The above error comes if i set following property as true.
PersistenceOptions.FETCH_ASSOCIATION_EXTRA_LAZY, "true"
If i set PersistenceOptions.FETCH_ASSOCIATION_EXTRA_LAZY as false,
then records will be inserted into superclass table(A) and association table.
But i will get other error as 'lazy initialization failed-session closed'.
SO i want to fetch all the attributes(including containement and noncontainement)
at once.
Am i missing any options that needs to be set during initialization..?
[Updated on: Thu, 31 October 2013 09:05] by Moderator
Re: TENEO - ID is coming as null [message #1164723 is a reply to message #1164111] Thu, 31 October 2013 17:57 Go to previous messageGo to next message
Hi Chandre,
The extra lazy option is for performance reasons. So I guess you should first get everything working without this and
other options. Setting cascade options makes sense.
I think it is best if you first increase your hibernate knowledge. It seems that most questions are related on how to
handle association loading and such. There are many blog posts on various hibernate topics on the net.
Also read the Hibernate docs thoroughly and search for things like long transactions/sessions, or this one:
https://community.jboss.org/wiki/OpenSessionInView
gr. Martin
On 10/31/2013 01:48 PM, Chandre Gowda wrote:
> Thanks Martin. I have set following cascade policy while intializing the DATASTORE.
> If i set PersistenceOptions.FETCH_ASSOCIATION_EXTRA_LAZY as false, then records will be inserted into superclass
> at once.
The Netherlands
Re: TENEO - ID is coming as null [message #1165943 is a reply to message #1164723] Fri, 01 November 2013 13:08 Go to previous messageGo to next message
Thanks Martin.I had gone through the opensessionInView filter and other hibernate articles on lazy loading. I could try those options, but i wanted to try loading all the containement and non-containement attributes at once even if performance is going to be down. Because currently our EMF Metamodel is bit complex. So Setting the following option
giving error as 'B_e_id cannot be null' during save(object) operation(B is non-containement relationship with A).
Can we try fetching noncontainement and containement attributes at once in TENEO or am i missing any option that needs to be set.
Re: TENEO - ID is coming as null [message #1169570 is a reply to message #1165943] Sun, 03 November 2013 22:56 Go to previous messageGo to next message
Oh.. I was assuming
would fetch all the non containement asscoiations at once without requiring any sessionfilter. Actually this flag makes the association loading extra lazy. I want to know whether any option available in TENEO which fetches all non containement at once without using any session filter and not taking advantage of Hibernate lazy loading.
Re: TENEO - ID is coming as null [message #1169857 is a reply to message #1169570] Mon, 04 November 2013 03:32 Go to previous messageGo to next message
Hi Chandre,
There is no specific option to eagerly load all the associations (many and single). What you can do is annotate the
ecore model before you initialize the datastore. So write some code which traverses the model and programmatically add
annotations to it.
Then you can use standard JPA annotations to force eager loading.
gr. Martin
On 11/04/2013 04:56 AM, Chandre Gowda wrote:
> Oh.. I was assuming PersistenceOptions.FETCH_ASSOCIATION_EXTRA_LAZY, "true" would fetch all the non containement
The Netherlands
Re: TENEO - ID is coming as null [message #1220925 is a reply to message #1169857] Mon, 16 December 2013 03:16 Go to previous messageGo to next message
Iam sorry for taking so much time.
I couldn't understand 'annotating the ecore model. I have a class 'LOG' which has noncontainement attribute 'entries'(list). I want to load this attribute eagerly. Please let me know how to accomplish this.
Chandru
Re: TENEO - ID is coming as null [message #1220941 is a reply to message #1220925] Mon, 16 December 2013 04:32 Go to previous messageGo to next message
Hi Chandre,
Annotating the ecore model means specifying the JPA annotations in the EAnnotations of the model. So not in the java
code, but in the ecore or xsd file.
Teneo has fairly extensive wiki content on this:
http://wiki.eclipse.org/Teneo/Hibernate#Model_Relational_Mapping_with_EJB3.2FJPA_Annotations
Can you go through all these pages? If you have remaining questions, can you then ask specific questions on which
specific part of these wiki documents are not clear?
This will also help to further improve the wiki.
gr. Martin
> Thanks
> Chandru
The Netherlands
Re: TENEO - ID is coming as null [message #1221219 is a reply to message #1220941] Tue, 17 December 2013 01:22 Go to previous messageGo to next message
Thanks Martin.
I have edited ecore in text editor and placed following code for that attribute.
<eAnnotations source="teneo.jpa">
<details key="appinfo" value="@OneToMany(fetch=FetchType.EAGER)"/>
</eAnnotations>.
Its working now. The attribute is loading eagerly.
However I couldn't understand the other way of annotating i.e through XML files.
How do we link ecore model and xml file ?
Chandru
Re: TENEO - ID is coming as null [message #1221230 is a reply to message #1221219] Tue, 17 December 2013 02:04 Go to previous message
Hi Chandre,
It was mentioned in this wiki page, but I changed the wording a bit to make it more explicit, see the (new) second
paragraph here:
https://wiki.eclipse.org/Teneo/Hibernate/ModelRelational/Annotations_Format#JPA_Annotations_in_XML
You don't need to edit the ecore manually, you can also add eannotations in the ecore editor, right click on different
nodes, there should be an option to add an eannotation child somewhere.
gr. Martin
On 12/17/2013 07:22 AM, Chandre Gowda wrote:
> Thanks Martin.
> </eAnnotations>.
> Its working now. The attribute is loading eagerly. However I couldn't understand the other way of annotating i.e through
> XML files.
> Thanks
> Chandru
The Netherlands
Previous Topic:[Teneo] inheritance mapping - cannot alter default strategy
Next Topic:Declaration of super interfaces during code generation
Current Time: Mon Jul 21 07:21:27 EDT 2025
Powered by FUDForum. Page generated in 0.06647 seconds
