Home » Language IDEs » ServerTools (WTP) » Standalone WS client tutorial
Standalone WS client tutorial [message #116717] Wed, 06 July 2005 11:22 Go to next message
Originally posted by: zen.rem.this.debian.linux.org.pl
Hi there,
I must develope simple Java app, some kind of indicator. It should query
web service (currently deveoped with PHP) and display simple data:
user count, stats and so on.
Is there any (quick and simple) way to create class skeleton from
existing wsdl, and use it in this app (visual part is ready ;)
thx
Tomasz 'Zen' Napierala
JID: tzn@jabber.org | GSM: 509694518
http://debian.linux.org.pl | http://www.alrauna.org
RLU: 312924 | Debian SID | Firefox 1.0
Re: Standalone WS client tutorial [message #116919 is a reply to message #116717] Wed, 06 July 2005 14:41 Go to previous message
Hi Tomasz,
if I understand correctly, you want to create a Java client for your
existing Web service. Is that right?
The Web service's implementation doesn't matter as long as the endpoint
URL in the WSDL points to a valid and running Web service. To create a
Java client and fully implemented proxy class, you can use the Web
service Client wizard in WTP.
Here's the tutorial:
http://www.eclipse.org/webtools/jst/components/ws/M5/tutoria ls/WebServiceClient.html
From that, it shouldn't be too too difficult to hook it up to your UI.
Good luck!
Seng
Tomasz Z. Napierala wrote:
> Hi there,
> web service (currently deveoped with PHP) and display simple data: user
> thx
Previous Topic:publishing error
Next Topic:Axis runtime-Errors-on-1.0M5
Current Time: Sun Jul 20 14:26:13 EDT 2025
Powered by FUDForum. Page generated in 0.08301 seconds
