Home » Eclipse Projects » GEF » NoClassDefFoundError
NoClassDefFoundError [message #116262] Mon, 09 February 2004 15:03 Go to next message
Originally posted by: bharath.starthis.com
Hi all,
I have a GEF editor linked to an EMF model. When I try to call the Model
Manager to create a view of my model and load it in the editor, I get a
NoClassDefFoundError. The class that I am using gets resolved without any
errors during compile time. When I launch my runtime workbench, I get this
error. Can someone clarify? I checked my classpath too, I have included
the project which contains the class under the "projects" section of build
path.
The import path is right, the class gets resolved but still it cannot be
found at run time.
Thanks is advance,
Bharath.
Re: NoClassDefFoundError [message #116273 is a reply to message #116262] Mon, 09 February 2004 16:48 Go to previous messageGo to next message
Originally posted by: phil.williams.toadmail.com
Make sure that you have the right class in the plugin.xml for the editor.
HTH,
Phil
Bharath wrote:
>Hi all,
>path.
>found at run time.
>Thanks is advance,
>Bharath.
Re: NoClassDefFoundError [message #116295 is a reply to message #116262] Mon, 09 February 2004 22:54 Go to previous messageGo to next message
Sounds like your .classpath is set incorrectly. Are you depending on a
class transatively? Plug-in A require B, which requires C, and the class is
in C, but B does not export C.
"Bharath" <bharath@starthis.com> wrote in message
news:c08p1k$397$1@eclipse.org...
> Hi all,
> path.
> found at run time.
> Thanks is advance,
> Bharath.
Re: NoClassDefFoundError [message #116831 is a reply to message #116295] Tue, 10 February 2004 09:44 Go to previous messageGo to next message
Phil & Randy:
Thanks for your advice. Though I had a .jar file with my model classes
added to my editor, I had not included the .jar file in the plugin
manifest file of the editor. Once I included the .jar file in the
<requires> tag of my plugin.xml file, it worked.
Thanks again!
> > Hi all,
> > path.
> > found at run time.
> > Thanks is advance,
> > Bharath.
Re: NoClassDefFoundError [message #117185 is a reply to message #116831] Wed, 11 February 2004 15:32 Go to previous message
You shouldn't be modifying your project's classpath manually. Right click
on your plugin.xml and let the PDE generate the appropriate one for you.
Then, all you need to do is update your plugin.xml file and your .classpath
is fixed for you.
news:c0aqo5$edg$1@eclipse.org...
> Phil & Randy:
> Thanks again!
class is
> > > Hi all,
Model
a
any
this
included
build
> > > path.
be
> > > found at run time.
> > > Thanks is advance,
> > > Bharath.
Previous Topic:Multi page editor & actions
Next Topic:emf/gef commands
Current Time: Sat Nov 08 13:35:26 EST 2025
Powered by FUDForum. Page generated in 0.24238 seconds
