| How can I start? [message #10610] |
Thu, 17 March 2005 08:01  |
Originally posted by: agustinus.ivalidator.org
Hello everybody,
I am a newbie at Hyades framework. I have downloaded Hyades 3.2.0 and
run it well on Linux SuSE 8 platform. As a starting point I have
downloaded all Hyades plug-ins and there are around 70 plugins extracted.
1. When I run the "URL Test Sample", which plug-ins are actually in
action ? For instance when I double-click the eclipseTest.testsuite,
there will be an editor opened on the workbench, with 3 tabfolders,
Overview, Http Requests and Behavior. Do these three tabfolders
correspond to certain plug-ins ?
2. I see also that some plug-ins have no extension and no
extension-points. The plug-in contains only *.jar file and is used only
for dependency for other plug-ins. Am I correct?
3. Where is the main plug-ins so that a newbie can start easily?
Thank you very much for any opinions.
Agustinus Tedja
| Re: How can I start? [message #11719 is a reply to message #11682] |
Fri, 25 March 2005 11:01  |
Hello Agustinus,
For point #2, yes, this is true, for example
org.eclipse.hyades.test.common follows that role as you described (no
extensions or extension-points specified).
-Scott E. Schneider
IBM Rational, Raleigh, NC
Todd Merriweather wrote:
> Agustinus Tedja wrote:
>> Hello everybody,
>> only for dependency for other plug-ins. Am I correct?
>> Best regards,
>> Agustinus Tedja
> Agustinus,
> 1. The URL Test Sample is a collection of assets that can be inspected
> so that new users can "sample" URL Test without actually running one.
> The creation of the sample project is handled by Eclipse functionality.
> You can reference org.eclipse.hyades.ui.sample/plugin.xml to see the
> details.
> A good place to start to see what plugins are involved when you open a
> testsuite is to look at org.eclipse.hyades.test.http/plugin.xml.
> 2. I'm not sure about this
> 3. The main plugins that comprise URL Test are:
> -org.eclipse.hyades.test.http
> -org.eclipse.hyades.execution.recorder
> -org.eclipse.hyades.execution.recorder.http
> -org.eclipse.hyades.execution.testgen
> -org.eclipse.hyades.execution.testgen.http
FUDForum. Page generated in 0.04427 seconds
