Home » Newcomers » Newcomers » Exproting plugin
Exproting plugin [message #116802] Fri, 11 November 2005 06:22 Go to next message
Originally posted by: shaiju.nair.einfochips.com
I am using export plugin and fragments wizard to create my plugin . I
am using eclipse version 3.1 . While export it is found that few class
files are not present in the jar file. These class files are present in bin
Folder.
I don't know why this happens. I tries export jar wizard and found it is
taking all .
Any idea why this happens ?
Shaiju.P
Re: Exproting plugin [message #117375 is a reply to message #116802] Sun, 13 November 2005 04:33 Go to previous messageGo to next message
There is a build tab at the bottom in the UI of plugin.xml. Or build.xml
file will be present in your project. Mention the files you need to export
there and try.
Re: Exproting plugin [message #117387 is a reply to message #117375] Sun, 13 November 2005 04:34 Go to previous message
Sorry its build.properties
> there and try.
Previous Topic:no output after build/complie
Next Topic:REQUEST FOR SOLUTION: Eclipse installation problem: UnsatisfiedLinkError
Current Time: Sat Jul 26 20:01:42 EDT 2025
Powered by FUDForum. Page generated in 0.08263 seconds
