| VE not working (IllegalAccessException) [message #116630] |
Thu, 02 February 2006 04:00  |
Originally posted by: cc.yahoo.it
Hi all,
I've installed VE 1.2M1 on:
- JDK 5.0 update 6
- Eclipse-SDK-3.2M4 (file )
- EMF build 2.2.0M4 (file emf-sdo-runtime-2.2.0M4.zip)
- GEF Build 3.2M4 (file GEF-runtime-3.2M4.zip)
When I create a visual class that extends the Class Composite, the Visual
Editor windows opens without showing the Composite area in which I should
put my widgets
I noticed that if I move the mouse over the area where the Composite should
be I obtain a the following error displayed inside a tooltip:
IllegalAccessException (Class
org.eclipse.jem.internal.proxy.initparser.tree.ExpressionPro cesser cannot
access a member of class org.eclipse.swt.widgets.Composite with modifier...)
I opened the .log file and I read the following errors:
!SESSION 2006-02-01
17:11:51.463 -----------------------------------------------
eclipse.buildId=I20051215-1506
java.version=1.5.0_06
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=it_IT
Command-line arguments: -os win32 -ws win32 -arch x86 -clean -consolelog
!ENTRY org.eclipse.jem.proxy 2 0 2006-02-01 17:15:37.027
!MESSAGE
+++ Warning +++: Wed Feb 01 17:15:37 CET 2006 Project
(IrriGraph2D)-Beaninfo:err>
java.lang.NoClassDefFoundError:
org/eclipse/jem/internal/proxy/vm/remote/RemoteVMApplication
!ENTRY org.eclipse.jem.proxy 2 0 2006-02-01 17:15:39.381
!MESSAGE IWAV0138E Remote VM terminated too soon. See .log file for trace of
output. For VM "Project (IrriGraph2D)-Beaninfo".
IWAV0072I Remote VM terminated before any commands can be sent. Following
are the error and output streams.
-- Error Stream --
Exception in thread "main"
-- Output Stream --
-- End of Stream Output --
!ENTRY org.eclipse.jem.proxy 2 0 2006-02-01 17:15:39.411
!MESSAGE No Server to retrieve a connection.
!ENTRY org.eclipse.jem.proxy 2 0 2006-02-01 17:15:39.421
!MESSAGE
+++ Warning +++: Wed Feb 01 17:15:39 CET 2006 Project
!ENTRY org.eclipse.jem.beaninfo 2 0 2006-02-01 17:15:39.441
!MESSAGE IWAV0155E Introspection failed on class "java.lang.Object." msg="."
!STACK 0
java.lang.IllegalStateException: IWAV0171E Could not create a socket
connection to remote vm.
at
org.eclipse.jem.internal.proxy.remote.REMProxyFactoryRegistr y.createConnection(REMProxyFactoryRegistry.java:439)
at
org.eclipse.jem.internal.proxy.remote.REMProxyFactoryRegistr y.getFreeConnection(REMProxyFactoryRegistry.java:374)
at
org.eclipse.jem.internal.proxy.remote.REMStandardBeanTypePro xyFactory.getBeanTypeProxy(REMStandardBeanTypeProxyFactory.j ava:364)
at
org.eclipse.jem.internal.proxy.remote.REMStandardBeanTypePro xyFactory.getBeanTypeProxy(REMStandardBeanTypeProxyFactory.j ava:267)
at
org.eclipse.jem.internal.proxy.remote.awt.REMRegisterAWT.reg isterAWT(REMRegisterAWT.java:31)
at
org.eclipse.jem.internal.proxy.remote.LocalProxyLaunchDelega te.launch(LocalProxyLaunchDelegate.java:412)
at
org.eclipse.debug.internal.core.LaunchConfiguration.launch(L aunchConfiguration.java:639)
at
org.eclipse.debug.internal.core.LaunchConfiguration.launch(L aunchConfiguration.java:565)
at
org.eclipse.debug.internal.core.LaunchConfiguration.launch(L aunchConfiguration.java:558)
at
org.eclipse.jem.internal.proxy.core.ProxyLaunchSupport.start Implementation(ProxyLaunchSupport.java:463)
at
org.eclipse.jem.internal.proxy.core.ProxyLaunchSupport.start Implementation(ProxyLaunchSupport.java:330)
at
org.eclipse.jem.internal.beaninfo.adapters.BeaninfoNature.cr eateRegistry(BeaninfoNature.java:474)
at
org.eclipse.jem.internal.beaninfo.adapters.CreateRegistryJob Handler.doCreateRegistry(CreateRegistryJobHandler.java:159)
at
org.eclipse.jem.internal.beaninfo.adapters.CreateRegistryJob Handler.processCreateRegistry(CreateRegistryJobHandler.java: 114)
at
org.eclipse.jem.internal.beaninfo.adapters.UICreateRegistryJ obHandler.processCreateRegistry(UICreateRegistryJobHandler.j ava:52)
at
org.eclipse.jem.internal.beaninfo.adapters.CreateRegistryJob Handler.createRegistry(CreateRegistryJobHandler.java:80)
at
org.eclipse.jem.internal.beaninfo.adapters.BeaninfoNature.ge tRegistry(BeaninfoNature.java:455)
Could you help me in solving this problem?
Thank you very much in advance.
| Re: VE not working (IllegalAccessException) [message #116744 is a reply to message #116694] |
Thu, 02 February 2006 09:18   |
Hi Jeff,
I've done what you suggested, but now I keep on seeing nothing on the Visual
Editor Windows and get the following error:
Help please!!! :-)
!SESSION 2006-02-02
15:10:06.753 -----------------------------------------------
This is a continuation of log file C:\eclipse 3.2M4\.metadata\.bak_3.log
Created Time: 2006-02-02 15:13:18.649
!ENTRY org.eclipse.jem.beaninfo 2 0 2006-02-02 15:13:18.649
"org.eclipse.swt.widgets.Widget." msg="."
!STACK 0
at
org.eclipse.jem.internal.beaninfo.adapters.BeaninfoProxyCons tants. <init>(BeaninfoProxyConstants.java:58)
at
org.eclipse.jem.internal.beaninfo.adapters.BeaninfoProxyCons tants.getConstants(BeaninfoProxyConstants.java:45)
at
org.eclipse.jem.internal.beaninfo.adapters.BeaninfoClassAdap ter.getProxyConstants(BeaninfoClassAdapter.java:1177)
at
org.eclipse.jem.internal.beaninfo.adapters.BeaninfoClassAdap ter.introspect(BeaninfoClassAdapter.java:731)
at
org.eclipse.jem.internal.beaninfo.adapters.BeaninfoClassAdap ter.introspectIfNecessary(BeaninfoClassAdapter.java:429)
at
org.eclipse.jem.internal.beaninfo.adapters.BeaninfoClassAdap ter.introspectIfNecessary(BeaninfoClassAdapter.java:416)
at
org.eclipse.jem.internal.beaninfo.adapters.BeaninfoClassAdap ter.introspect(BeaninfoClassAdapter.java:637)
at
at
at
org.eclipse.jem.java.internal.impl.JavaClassImpl.getEAnnotat ions(JavaClassImpl.java:387)
at
org.eclipse.ve.internal.cde.emf.ClassDecoratorTypeIterator.f indDecorator(ClassDecoratorTypeIterator.java:37)
at
org.eclipse.ve.internal.cde.emf.ClassDecoratorIterator.findN ext(ClassDecoratorIterator.java:76)
at
org.eclipse.ve.internal.cde.emf.ClassDecoratorIterator.findN ext(ClassDecoratorIterator.java:78)
at
org.eclipse.ve.internal.cde.emf.ClassDecoratorIterator.next( ClassDecoratorIterator.java:61)
at
org.eclipse.ve.internal.cde.emf.ClassDecoratorFeatureAccess. getDecoratorWithFeature(ClassDecoratorFeatureAccess.java:44)
at
org.eclipse.ve.internal.cde.emf.ClassDescriptorDecoratorPoli cy.findDecorator(ClassDescriptorDecoratorPolicy.java:128)
at
org.eclipse.ve.internal.cde.emf.ClassDescriptorDecoratorPoli cy.getModelAdapterClassname(ClassDescriptorDecoratorPolicy.j ava:195)
at
org.eclipse.ve.internal.cde.emf.DefaultModelAdapterFactory.c reateAdapter(DefaultModelAdapterFactory.java:106)
at
org.eclipse.ve.internal.cde.emf.DefaultModelAdapterFactory.c reateAdapter(DefaultModelAdapterFactory.java:95)
at
org.eclipse.ve.internal.cde.emf.DefaultModelAdapterFactory.g etAdapter(DefaultModelAdapterFactory.java:61)
at
org.eclipse.ve.internal.cde.emf.AbstractEMFContainerPolicy.g etTrueChild(AbstractEMFContainerPolicy.java:259)
at
org.eclipse.ve.internal.java.vce.SubclassCompositionContaine rPolicy.getTrueChild(SubclassCompositionContainerPolicy.java :44)
at
org.eclipse.ve.internal.cde.emf.AbstractEMFContainerPolicy.g etTrueChildren(AbstractEMFContainerPolicy.java:307)
at
org.eclipse.ve.internal.cde.emf.AbstractEMFContainerPolicy.g etDeleteDependentCommand(AbstractEMFContainerPolicy.java:597 )
at
org.eclipse.ve.internal.cde.core.ContainerPolicy.getDeleteDe pendentCommand(ContainerPolicy.java:244)
at
org.eclipse.ve.internal.cde.core.ContainerPolicy.getCommand( ContainerPolicy.java:389)
at
org.eclipse.ve.internal.cde.core.VisualInfoXYLayoutEditPolic y.getDeleteDependantCommand(VisualInfoXYLayoutEditPolicy.jav a:136)
at
org.eclipse.gef.editpolicies.LayoutEditPolicy.getCommand(Lay outEditPolicy.java:184)
at
org.eclipse.gef.editpolicies.ConstrainedLayoutEditPolicy.get Command(ConstrainedLayoutEditPolicy.java:154)
at
org.eclipse.ve.internal.cde.core.XYLayoutEditPolicy.getComma nd(XYLayoutEditPolicy.java:255)
at
org.eclipse.ve.internal.cde.core.VisualInfoXYLayoutEditPolic y.getCommand(VisualInfoXYLayoutEditPolicy.java:209)
at
org.eclipse.gef.editparts.AbstractEditPart.getCommand(Abstra ctEditPart.java:489)
at
org.eclipse.ve.internal.cde.core.DefaultComponentEditPolicy. createDeleteCommand(DefaultComponentEditPolicy.java:33)
at
org.eclipse.gef.editpolicies.ComponentEditPolicy.getDeleteCo mmand(ComponentEditPolicy.java:67)
at
org.eclipse.gef.editpolicies.ComponentEditPolicy.getCommand( ComponentEditPolicy.java:56)
at
at
org.eclipse.ve.internal.java.core.CutJavaBeanAction.calculat eEnabled(CutJavaBeanAction.java:56)
at
org.eclipse.gef.ui.actions.WorkbenchPartAction.isEnabled(Wor kbenchPartAction.java:111)
at
org.eclipse.ui.texteditor.RetargetTextEditorAction.setAction (RetargetTextEditorAction.java:188)
at
org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itorPart$4.focusGained(JavaVisualEditorPart.java:2507)
at
org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:105)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :66)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:914)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:938)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:919)
at org.eclipse.swt.widgets.Control.sendFocusEvent(Control.java: 1939)
at org.eclipse.swt.widgets.Widget.wmSetFocus(Widget.java:2101)
at org.eclipse.swt.widgets.Control.WM_SETFOCUS(Control.java:382 1)
at org.eclipse.swt.widgets.Canvas.WM_SETFOCUS(Canvas.java:296)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:3277 )
at org.eclipse.swt.widgets.Display.windowProc(Display.java:3963 )
at org.eclipse.swt.internal.win32.OS.SetFocus(Native Method)
at org.eclipse.swt.widgets.Control.forceFocus(Control.java:704)
at org.eclipse.swt.widgets.Control.setFocus(Control.java:2295)
at org.eclipse.swt.widgets.Composite.setFocus(Composite.java:75 0)
at
org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itorPart.setFocus(JavaVisualEditorPart.java:2814)
at org.eclipse.ui.internal.PartPane.setFocus(PartPane.java:304)
at org.eclipse.ui.internal.EditorPane.setFocus(EditorPane.java: 116)
at org.eclipse.ui.internal.WorkbenchPage$3.run(WorkbenchPage.ja va:571)
at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:37)
at org.eclipse.core.runtime.Platform.run(Platform.java:785)
at
org.eclipse.ui.internal.WorkbenchPage.activatePart(Workbench Page.java:566)
at
org.eclipse.ui.internal.WorkbenchPage.setActivePart(Workbenc hPage.java:2962)
at
org.eclipse.ui.internal.WorkbenchPage.requestActivation(Work benchPage.java:2534)
at org.eclipse.ui.internal.PartPane.requestActivation(PartPane. java:251)
at org.eclipse.ui.internal.EditorPane.requestActivation(EditorP ane.java:88)
at org.eclipse.ui.internal.PartPane.handleEvent(PartPane.java:2 16)
at org.eclipse.swt.widgets.Shell.setActiveControl(Shell.java:10 49)
at org.eclipse.swt.widgets.Shell.WM_MOUSEACTIVATE(Shell.java:16 86)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:3253 )
at org.eclipse.swt.widgets.Decorations.windowProc(Decorations.j ava:1538)
at org.eclipse.swt.internal.win32.OS.DefWindowProcW(Native Method)
at org.eclipse.swt.internal.win32.OS.DefWindowProc(OS.java:1700 )
at org.eclipse.swt.widgets.Scrollable.callWindowProc(Scrollable .java:77)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:3299 )
at org.eclipse.swt.internal.win32.OS.PeekMessageW(Native Method)
at org.eclipse.swt.internal.win32.OS.PeekMessage(OS.java:2160)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2900)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1762)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1726)
at
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:397)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:143)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:106)
at
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:109)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:92)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:68)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:379)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:177)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:338 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:282)
at org.eclipse.core.launcher.Main.run(Main.java:977)
at org.eclipse.core.launcher.Main.main(Main.java:952)
!ENTRY org.eclipse.jem.beaninfo 2 0 2006-02-02 15:13:18.669
"org.eclipse.swt.widgets.Control." msg="."
!STACK 0
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
!ENTRY org.eclipse.ui 4 4 2006-02-02 15:13:18.769
!MESSAGE Unhandled event loop exception
!ENTRY org.eclipse.ui 4 0 2006-02-02 15:13:18.769
!MESSAGE Failed to execute runnable (java.lang.NullPointerException)
!STACK 0
org.eclipse.swt.SWTException: Failed to execute runnable
at org.eclipse.swt.SWT.error(SWT.java:3283)
at org.eclipse.swt.SWT.error(SWT.java:3206)
at
org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:126)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.jav a:3262)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2908)
at
at
at
at
at
at
at
org.eclipse.ve.internal.java.core.BeanPropertyDescriptorAdap ter.isReadOnly(BeanPropertyDescriptorAdapter.java:390)
at
org.eclipse.ve.internal.propertysheet.AbstractPropertySheetE ntry.refreshChildEntries(AbstractPropertySheetEntry.java:802 )
at
org.eclipse.ve.internal.propertysheet.AbstractPropertySheetE ntry.setValues(AbstractPropertySheetEntry.java:1028)
at
org.eclipse.ui.views.properties.PropertySheetViewer.setInput (PropertySheetViewer.java:916)
at
org.eclipse.ui.views.properties.PropertySheetPage.selectionC hanged(PropertySheetPage.java:392)
at
org.eclipse.ve.internal.propertysheet.EToolsPropertySheetPag e.superSelectionChanged(EToolsPropertySheetPage.java:250)
at
org.eclipse.ve.internal.propertysheet.EToolsPropertySheetPag e.access$2(EToolsPropertySheetPage.java:243)
at
org.eclipse.ve.internal.propertysheet.EToolsPropertySheetPag e$1.run(EToolsPropertySheetPage.java:236)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:3 5)
at
org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:123)
... 20 more
"Jeff Myers" <jeff.myers@eclipse.org> wrote in message
news:drt2u2$cej$1@utils.eclipse.org...
> Let's try a different set of steps.
> 1. Create a Java Project.
> 2. Create a Visual Class, extending Composite through the wizard.
> 3. Profit!
> The New Visual Class wizard will handle configuring your project to use
> the SWT libraries for you. VE won't work properly if you add the SWT jars
> to your project manually.
> - Jeff
> ccc wrote:
>> Hi Jeff,
>> I disabled firewall and re-installed eclipse SDK and Visual Editor. After
>> that, I followed the steps below:
>> 1. I created a Java project
>> 2. I configured the project build path in order to add the
>> "org.eclipse.swt.win32.win32.x86_3.2.0.v3218.jar" library
>> 3. I imported into the project the files swt-gdip-win32-3218.dll and
>> swt-win32-3218.dll (these dlls are necessary for the development of my
>> visual class)
>> 4. I created my visual class extending Composite (through the wizard)
>> After few seconds, during Visual Editor window loading, I received a
>> pop-up window saying:
>> An internal error occurred during: "Create Remote VM for Visual Editor
>> for Java"
>> So I didn't solve my problem disabling the firewall. Here attached the
>> .log file, I hope it could help you!
>> news:drstm5$30d$2@utils.eclipse.org...
>>>> msg="."
>>>> !STACK 0
>>> It looks like you're having trouble creating a network connection to the
>>> remote VMs. Do you have a firewall or other software installed that will
>>> prevent tcp/ip connections to localhost (127.0.0.1)?
>>> - Jeff
| Re: VE not working (IllegalAccessException) [message #116758 is a reply to message #116744] |
Thu, 02 February 2006 09:31   |
I cleaned my project and the new problem disappeared!
I noticed that the error:
An internal error occurred during: "Create Remote VM for Visual Editor for
Java"
now occurs randomly when I close eclipse (after leaving Visual Editor Window
opened) and reopen it.
Any ideas?
"ccc" <cc@yahoo.it> wrote in message news:drt4cj$fq8$1@utils.eclipse.org...
> Hi Jeff,
> Visual Editor Windows and get the following error:
> Help please!!! :-)
> !SESSION 2006-02-02
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 20 more
>> 3. Profit!
>> jars to your project manually.
>> - Jeff
>> ccc wrote:
>>> Hi Jeff,
>>> After that, I followed the steps below:
>>> visual class)
>>> for Java"
>>>>> msg="."
>>>>> !STACK 0
>>>> the
>>>> will
>>>> - Jeff
| Re: VE not working (IllegalAccessException) [message #116771 is a reply to message #116758] |
Thu, 02 February 2006 09:41  |
> Java"
> Any ideas?
Hmmm... does your .log have anything new when this error occurs? It's
possible that it's trying to start up a new VM when you're shutting down
Eclipse and getting confused. If this is the case, please open a bug in
bugzilla: https://bugs.eclipse.org/bugs/enter_bug.cgi?product=VE
- Jeff
| Re: VE not working (IllegalAccessException) [message #611944 is a reply to message #116630] |
Thu, 02 February 2006 07:24  |
> !STACK 0
- Jeff
| Re: VE not working (IllegalAccessException) [message #611948 is a reply to message #116666] |
Thu, 02 February 2006 08:54  |
3. Profit!
- Jeff
ccc wrote:
> Hi Jeff,
> visual class)
> After few seconds, during Visual Editor window loading, I received a pop-up
> window saying:
> Java"
> So I didn't solve my problem disabling the firewall. Here attached the .log
>>> msg="."
>>> !STACK 0
>> - Jeff
| Re: VE not working (IllegalAccessException) [message #611952 is a reply to message #116694] |
Hi Jeff,
Help please!!! :-)
!SESSION 2006-02-02
!STACK 0
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
!STACK 0
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
!STACK 0
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
... 20 more
> 3. Profit!
> - Jeff
> ccc wrote:
>> Hi Jeff,
>> visual class)
>> for Java"
>>>> msg="."
>>>> !STACK 0
>>> - Jeff
| Re: VE not working (IllegalAccessException) [message #611953 is a reply to message #116744] |
Java"
Any ideas?
> Hi Jeff,
> Help please!!! :-)
> !SESSION 2006-02-02
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 20 more
>> 3. Profit!
>> - Jeff
>> ccc wrote:
>>> Hi Jeff,
>>> visual class)
>>> for Java"
>>>>> msg="."
>>>>> !STACK 0
>>>> the
>>>> will
>>>> - Jeff
| Re: VE not working (IllegalAccessException) [message #611954 is a reply to message #116758] |
> Java"
> Any ideas?
- Jeff
FUDForum. Page generated in 0.24557 seconds
