| unable to add tomcat installation [message #116576] |
Wed, 06 July 2005 06:46  |
Originally posted by: joerg.eschke.net
I try to add a tomcat v5 to the Installed Server Runtime Environment within
the preferences but recieve "The Tomcat installation directory is not
correct. It does not point to a valid Tomcat installation." from the
wizard.
I am running 0.7m5 using the default tomcat 5 installation
provided by SuSE Linux 9.3
Any hints ?
How does the wizard determine a so called "valid" tomcat installation ?
Greets,
Joerg
| Re: unable to add tomcat installation [message #116768 is a reply to message #116682] |
Wed, 06 July 2005 11:49   |
Hmm, the directory structure doesn't seem to be the problems cause.
Using a SuSE Linux 9.1 installation where the tomcat directory structure is
identically the wizard does his job as expected.
Larry Isaacs wrote:
> I don't have a *nix system to play with at the moment, so I can't say
> exactly why the symlinks aren't being accepted. I'll see what I can
> find out. I don't know of a reason not to try to make this work.
> Cheers,
> Larry
> Jörg wrote:
>> the directory structure look like this:
>> /usr/share/tomcat5/
>> bin
>> common
>> conf -> /srv/www/tomcat5/base/conf
>> logs -> /srv/www/tomcat5/base/logs
>> server
>> shared
>> temp -> /srv/www/tomcat5/base/temp
>> webapps -> /srv/www/tomcat5/base/webapps
>> work -> /srv/www/tomcat5/base/work
>> You are right, after installing a Tomcat .tar.gz binary distribution from
>> the Apache Jakarta Page everything works fine.
>> Thanks,
>> Joerg
>> Larry Isaacs wrote:
>>>The Tomcat support expects the Tomcat installation to be under a single
>>>install directory, like what is found the tar.gz binary distributions
>>>that can be downloaded from Apache Jakarta. I assume the problem is
>>>that the Tomcat installation appears under multiple directories.
>>>If you identify your directory structure, I may be able to suggest how
>>>to trick the Tomcat support in to accepting that structure. You are
>>>also welcome to file an enhancement request in the Bug database.
>>>Cheers,
>>>Larry
>>>>within the preferences but recieve "The Tomcat installation directory is
>>>>not correct. It does not point to a valid Tomcat installation." from the
>>>>wizard.
>>>>Any hints ?
>>>>Greets,
>>>>Joerg
| Re: unable to add tomcat installation [message #157786 is a reply to message #157755] |
Mon, 23 January 2006 21:26  |
I did a fresh install with tomcat 5.5 and now it works. So the problem
seems be related to the symbolic links.
Is this behaviour wanted?
Max
Max Giesbert wrote:
> Tomcat 5.0 came along with my Fedora Core 4 installation. Actually all
> folders are there in /usr/share/tomcat5 as in the tar.gz. the only
> difference is that almost all of the directories are symbolic links.
> Max
> Nitin Dahyabhai wrote:
>> Max Giesbert wrote:
>>> Has the problem finally been solved? I just expereience the same
>>> problem running wtp1.0 and tomcat5. i can't get the wizard to accept
>>> my directory as valid.
>> Does the layout of your Tomcat 5.0 directory differ from the layout in
>> the .zip/.tar files provided by Apache?
FUDForum. Page generated in 0.07668 seconds
