Home » Eclipse Projects » Eclipse Platform » Clarification needed - Copy menu item and tool bar button - Global Actions
Clarification needed - Copy menu item and tool bar button - Global Actions [message #116542] Tue, 26 August 2003 06:37 Go to next message
All,
I have a "Copy" menu item and i used setGlobalActionHandler api to register
my action for the
same. This works fine for the menu items. I need the same to work for tool
bar icons.
I assumed that, copy/paste/cut tool bar icons will be provided by default
and the
programmers needs to register their actions, so that based on the editor,
relevant actions will be fired.
I searched the eclipse documentations, and concluded that
setGlobalActionHandler api is with respect
to MENU ITEMS, what should we do for tool bar buttons.??
Does eclipse provides api's similar to setGlobalActionHandler api for
registering the actions related
to tool bar buttons.
Could anyone help me in this regard?
Also you can mail the replies to vamirthalingam@selectica.com
venkat
Re: Clarification needed - Copy menu item and tool bar button - Global Actions [message #116683 is a reply to message #116542] Tue, 26 August 2003 14:05 Go to previous messageGo to next message
What documentation did you consult?
http://www.eclipse.org/documentation/html/plugins/org.eclips e.platform.doc.i
sv/doc/reference/api/org/eclipse/ui/IActionBars.html
states this:
Used by a part to access its menu, toolbar, and status line managers.
Within the workbench each part, editor or view, has a private set of action
bars. This set, which contains a menu, toolbar, and status line, appears in
the local toolbar for a view and in the window for an editor. The view may
provide an implementation for pre-existing actions or add new actions to the
action bars.
In a workbench window there a number of actions which are applicable to all
parts. Some common examples are CUT, COPY and PASTE. These actions, known as
"global actions", are contributed to the workbench window by the window
itself and shared by all parts. The presentation is owned by the window. The
implementation is delegated to the active part.
To participate in the global action design an IWorkbenchPart should register
a handler for each global action which is implemented by the part. This can
be done by calling setGlobalActionHandler. For convenience, the standard
global actions are defined in org.eclipse.ui.IWorkbenchActionConstants.
"venkat amirthalingam" <vamirthalingam@selectica.com> wrote in message
news:bifd3f$p46$1@eclipse.org...
> All,
register
> my action for the
> bar icons.
> and the
> Regards,
> venkat
Re: Clarification needed - Copy menu item and tool bar button - Global Actions [message #117096 is a reply to message #116683] Wed, 27 August 2003 02:34 Go to previous messageGo to next message
Already , i read this documentation and my question is simple,
is with respect to menu items only, what should we do for tool bar buttons?
Hope you got my question.
When is used JDT, i couldn't see copy,cut,paste icons in the tool bar. Why
is it so? Does eclipse provide
global tool bar buttons for copy,paste,cut, etc...?
-venkat
"Chris Laffra" <Chris_Laffra@oti.com> wrote in message
news:big7gd$l7v$1@eclipse.org...
> states this:
action
in
the
> action bars.
all
as
The
register
can
> > All,
> register
> > my action for the
tool
> > bar icons.
default
> > and the
editor,
> > Regards,
> > venkat
Re: Clarification needed - Copy menu item and tool bar button - Global Actions [message #117390 is a reply to message #117096] Wed, 27 August 2003 11:55 Go to previous messageGo to next message
Originally posted by: simon.ibm.oti.lab
The eclipse IDE does not place the cut/copy/paste actions on the toolbar
Simon :-)
news:bihj7l$oj4$1@eclipse.org...
buttons?
> -venkat
> > states this:
> action
> in
may
> the
> > action bars.
> all
known
> as
> The
> register
> can
> > > All,
> > register
> > > my action for the
> tool
> > > bar icons.
> default
> > > and the
> editor,
> > > Regards,
> > > venkat
Re: Clarification needed - Copy menu item and tool bar button - Global Actions [message #117733 is a reply to message #117390] Wed, 27 August 2003 23:08 Go to previous messageGo to next message
So, what should we do, if we need the same action to be registered for tool
bar buttons?
Another Question: As per your answer, if there are different editors, having
their own actions
for copy/cut/paste, the menu item will be common, but tool bar buttons can
differ. Is this the
understanding?
-venkat
"Simon Arsenault" <simon@ibm.oti.lab> wrote in message
news:biik91$r67$1@eclipse.org...
> Simon :-)
> buttons?
Why
> > -venkat
> > > states this:
> > action
appears
> > in
> may
to
> > the
> > > action bars.
to
> > all
> known
> > as
window
window.
> > The
> > register
This
> > can
standard
> > > > All,
> > > register
> > > > my action for the
for
> > tool
> > > > bar icons.
> > default
> > > > and the
> > editor,
for
> > > > Regards,
> > > > venkat
Re: Clarification needed - Copy menu item and tool bar button - Global Actions [message #118920 is a reply to message #117733] Thu, 28 August 2003 14:06 Go to previous messageGo to next message
The code for setGlobalActionHandler is not menu specific, it works for tool
bar also. The eclipse ide just does not add the cut/copy/paste retarget
actions to the tool bar. You could provide an action set that added these
retarget actions. Just need to make sure the "actionDefinitionId" matches
the one used for the menu items (i.e. org.eclipse.ui.edit.copy for the copy
retarget action, etc)
This whole story will become much easier to understand and use with the new
"command" work that is going on.
Simon :-)
news:bijrgs$1oa$1@eclipse.org...
tool
> bar buttons?
having
> their own actions
> differ. Is this the
> understanding?
> -venkat
> > Simon :-)
> > buttons?
> Why
> > > -venkat
> > > > states this:
managers.
> > > action
> appears
> > > in
view
> > may
actions
> to
> > > the
> > > > action bars.
> to
> > > all
> > known
> > > as
> window
> window.
> > > The
> > > register
> This
> > > can
> standard
message
> > > > > All,
> > > > register
> > > > > my action for the
> for
> > > tool
> > > > > bar icons.
> > > default
> > > > > and the
> > > editor,
> for
> > > > > Regards,
> > > > > venkat
Re: Clarification needed - Copy menu item and tool bar button - Global Actions [message #120201 is a reply to message #118920] Mon, 01 September 2003 22:56 Go to previous messageGo to next message
Simon,
Instead, can i override getImageDescriptor method in Action class? This way,
i need not create
a retarget actions, and still i can get the tool bar button placed in the
tool bar.
Please clarify this.
-venkat
news:bilga3$q1v$1@eclipse.org...
tool
copy
new
> Simon :-)
> tool
> > bar buttons?
> having
> > their own actions
can
> > differ. Is this the
> > understanding?
> > -venkat
toolbar
> > > Simon :-)
> > > buttons?
bar.
> > Why
> > > > -venkat
> > > > > states this:
> managers.
of
> > > > action
> > appears
> > > > in
> view
> > > may
> actions
> > to
> > > > the
> > > > > action bars.
applicable
> > to
> > > > all
actions,
> > > known
> > > > as
> > window
> > window.
> > > > The
should
> > > > register
> > This
> > > > can
> > standard
> message
> > > > > > All,
to
> > > > > register
> > > > > > my action for the
work
> > for
> > > > tool
> > > > > > bar icons.
by
> > > > default
> > > > > > and the
the
> > > > editor,
api
> > for
> > > > > > Regards,
> > > > > > venkat
Re: Clarification needed - Copy menu item and tool bar button - Global Actions [message #120532 is a reply to message #120201] Tue, 02 September 2003 13:06 Go to previous messageGo to next message
Sorry, I do not understand what you mean. How can overriding
getImageDescriptor() solve your problem of having the cut/copy/paste actions
on the toolbar?
Simon :-)
news:bj10m2$lcn$1@eclipse.org...
> Simon,
way,
> i need not create
> tool bar.
> -venkat
> tool
these
matches
> copy
> new
> > Simon :-)
> > tool
> > > bar buttons?
> > having
> > > their own actions
> can
> > > differ. Is this the
> > > understanding?
> > > -venkat
> toolbar
> > > > Simon :-)
message
> > > > buttons?
> bar.
> > > Why
> > > > > -venkat
> > > > > > states this:
> > managers.
set
> of
> > > > > action
> > > appears
> > > > > in
The
> > view
> > > > may
> > actions
> > > to
> > > > > the
> > > > > > action bars.
> applicable
> > > to
> > > > > all
> actions,
> > > > known
> > > > > as
> > > window
> > > window.
> > > > > The
> should
> > > > > register
part.
> > > This
> > > > > can
> > > standard
> > message
> > > > > > > All,
api
> to
> > > > > > register
> > > > > > > my action for the
> work
> > > for
> > > > > tool
> > > > > > > bar icons.
> by
> > > > > default
> > > > > > > and the
> the
> > > > > editor,
> api
> > > for
> > > > > > > Regards,
> > > > > > > venkat
Re: Clarification needed - Copy menu item and tool bar button - Global Actions [message #121643 is a reply to message #120532] Tue, 02 September 2003 23:16 Go to previous messageGo to next message
Simon,
I have a class
MyCopyAction extends Action
public void run()
//Implement the necessary logic
public ImageDescriptor getImageDescriptor()
//Return the tool bar icon for copy
And in setGlobalActionHandler(), i register the above action class, so that
the above run() method is
invoked, if our editor is active. Since i had overriden the
getImageDescriptor(), i get the icon for copy in
the tool bar (if our editor is active), and the same run() method gets
invoked, if i click on the copy icon.
Am i clear now?
Could you please clarify my earlier question?
-venkat
news:bj2im5$a8v$1@eclipse.org...
actions
> on the toolbar?
> Simon :-)
> > Simon,
> way,
> > i need not create
the
> > tool bar.
> > -venkat
> > tool
retarget
> these
> matches
> > copy
the
> > new
> > > Simon :-)
for
> > > tool
> > > > bar buttons?
editors,
> > > having
> > > > their own actions
buttons
> > can
> > > > differ. Is this the
> > > > understanding?
> > > > -venkat
> > toolbar
> > > > > Simon :-)
> message
bar
> > > > > buttons?
tool
> > bar.
> > > > Why
> > > > > > -venkat
> > > > > > > states this:
> > > managers.
> set
> > of
> > > > > > action
line,
> > > > appears
> > > > > > in
> The
> > > view
> > > > > may
> > > actions
> > > > to
> > > > > > the
> > > > > > > action bars.
> > applicable
> > > > to
> > > > > > all
> > actions,
> > > > > known
> > > > > > as
the
> > > > window
the
> > > > window.
> > > > > > The
> > should
> > > > > > register
> part.
> > > > This
> > > > > > can
the
> > > > standard
> > > message
> > > > > > > > All,
> api
> > to
> > > > > > > register
> > > > > > > > my action for the
> > work
> > > > for
> > > > > > tool
> > > > > > > > bar icons.
provided
> > by
> > > > > > default
> > > > > > > > and the
on
> > the
> > > > > > editor,
> > api
> > > > for
> > > > > > > > Regards,
> > > > > > > > venkat
Re: Clarification needed - Copy menu item and tool bar button - Global Actions [message #122192 is a reply to message #121643] Wed, 03 September 2003 11:38 Go to previous messageGo to next message
If I understand correctly, your editor is contributing the MyCopyAction to
the toolbar. And also registering it using setGlobalActionHandler to hook
the Edit>Copy menu item. Right? If so, that is an acceptable solution.
Instead of overriding getImageDescriptor, why not call setImageDescriptor
instead?
Simon :-)
news:bj3m8c$blj$1@eclipse.org...
> Simon,
> I have a class
> public void run()
that
> Am i clear now?
> -venkat
> actions
> > on the toolbar?
> > Simon :-)
> > > Simon,
This
> > way,
> > > i need not create
> the
> > > tool bar.
> > > -venkat
for
> > > tool
> retarget
> > these
> > matches
the
> > > copy
> the
> > > new
> > > > Simon :-)
message
> for
> > > > tool
> > > > > bar buttons?
> editors,
> > > > having
> > > > > their own actions
> buttons
> > > can
> > > > > differ. Is this the
> > > > > understanding?
> > > > > -venkat
> > > toolbar
> > > > > > Simon :-)
> > message
> bar
> > > > > > buttons?
> tool
> > > bar.
> > > > > Why
> > > > > > > -venkat
> > > > > > > > states this:
> > > > managers.
private
> > set
> > > of
> > > > > > > action
> line,
> > > > > appears
> > > > > > > in
editor.
> > The
> > > > view
> > > > > > may
new
> > > > actions
> > > > > to
> > > > > > > the
> > > > > > > > action bars.
> > > applicable
> > > > > to
> > > > > > > all
> > > actions,
> > > > > > known
> > > > > > > as
> the
> > > > > window
> the
> > > > > window.
> > > > > > > The
> > > should
> > > > > > > register
> > part.
> > > > > This
> > > > > > > can
> the
> > > > > standard
in
> > > > message
> > > > > > > > > All,
> > api
> > > to
> > > > > > > > register
> > > > > > > > > my action for the
to
> > > work
> > > > > for
> > > > > > > tool
> > > > > > > > > bar icons.
> provided
> > > by
> > > > > > > default
> > > > > > > > > and the
> on
> > > the
> > > > > > > editor,
> > > api
> > > > > for
> > > > > > > > > Regards,
> > > > > > > > > venkat
Re: Clarification needed - Copy menu item and tool bar button - Global Actions [message #122461 is a reply to message #122192] Wed, 03 September 2003 23:11 Go to previous messageGo to next message
Simon,
I am unable to understand...where do you want me to call setImageDescriptor?
-venkat
news:bj51rh$p9o$1@eclipse.org...
> instead?
> Simon :-)
> > Simon,
> > I have a class
> > public void run()
> that
> > Am i clear now?
> > -venkat
> > actions
> > > on the toolbar?
> > > Simon :-)
> > > > Simon,
> This
> > > way,
> > > > i need not create
in
> > the
> > > > tool bar.
> > > > -venkat
> for
> > > > tool
> > retarget
added
> > > these
> > > matches
> the
> > > > copy
with
> > the
> > > > new
> > > > > Simon :-)
> message
registered
> > for
> > > > > tool
> > > > > > bar buttons?
> > editors,
> > > > > having
> > > > > > their own actions
> > buttons
> > > > can
> > > > > > differ. Is this the
> > > > > > understanding?
> > > > > > -venkat
the
> > > > toolbar
> > > > > > > Simon :-)
> > > message
simple,
tool
> > bar
> > > > > > > buttons?
> > tool
> > > > bar.
> > > > > > Why
> > > > > > > > -venkat
> > > > > > > > > states this:
line
> > > > > managers.
> private
> > > set
> > > > of
> > > > > > > > action
> > line,
> > > > > > appears
> > > > > > > > in
> editor.
> > > The
> > > > > view
> > > > > > > may
> new
> > > > > actions
> > > > > > to
> > > > > > > > the
> > > > > > > > > action bars.
> > > > applicable
> > > > > > to
> > > > > > > > all
> > > > actions,
> > > > > > > known
> > > > > > > > as
by
> > the
> > > > > > window
by
> > the
> > > > > > window.
> > > > > > > > The
IWorkbenchPart
> > > > should
> > > > > > > > register
the
> > > part.
> > > > > > This
> > > > > > > > can
convenience,
> > the
> > > > > > standard
wrote
> in
> > > > > message
> > > > > > > > > > All,
> > > api
> > > > to
> > > > > > > > > register
> > > > > > > > > > my action for the
same
> to
> > > > work
> > > > > > for
> > > > > > > > tool
> > > > > > > > > > bar icons.
> > provided
> > > > by
> > > > > > > > default
> > > > > > > > > > and the
based
> > on
> > > > the
> > > > > > > > editor,
that
> > > > api
> > > > > > for
> > > > > > > > > > Regards,
> > > > > > > > > > venkat
Re: Clarification needed - Copy menu item and tool bar button - Global Actions [message #122719 is a reply to message #122461] Thu, 04 September 2003 11:28 Go to previous messageGo to next message
How about in the constructor of the MyCopyAction? Or maybe in the method who
is creating an instance of MyCopyAction?
Simon :-)
news:bj6aah$13n$1@eclipse.org...
> Simon,
setImageDescriptor?
> -venkat
to
hook
setImageDescriptor
> > instead?
> > Simon :-)
> > > Simon,
> > > I have a class
> > > public void run()
> > that
> > > Am i clear now?
> > > -venkat
> > > actions
> > > > on the toolbar?
> > > > Simon :-)
message
> > > > > Simon,
> > This
> > > > way,
> > > > > i need not create
> in
> > > the
> > > > > tool bar.
> > > > > -venkat
works
> > for
> > > > > tool
> > > retarget
> added
> > > > these
> > > > matches
for
> > the
> > > > > copy
> with
> > > the
> > > > > new
> > > > > > Simon :-)
> > message
> registered
> > > for
> > > > > > tool
> > > > > > > bar buttons?
> > > editors,
> > > > > > having
> > > > > > > their own actions
> > > buttons
> > > > > can
> > > > > > > differ. Is this the
> > > > > > > understanding?
> > > > > > > -venkat
> the
> > > > > toolbar
> > > > > > > > Simon :-)
in
> > > > message
> simple,
> tool
> > > bar
> > > > > > > > buttons?
the
> > > tool
> > > > > bar.
> > > > > > > Why
> > > > > > > > > -venkat
> > > > > > > > > > states this:
> line
> > > > > > managers.
> > private
> > > > set
> > > > > of
> > > > > > > > > action
status
> > > line,
> > > > > > > appears
> > > > > > > > > in
> > editor.
> > > > The
> > > > > > view
> > > > > > > > may
add
> > new
> > > > > > actions
> > > > > > > to
> > > > > > > > > the
> > > > > > > > > > action bars.
are
> > > > > applicable
> > > > > > > to
> > > > > > > > > all
These
> > > > > actions,
> > > > > > > > known
> > > > > > > > > as
window
> by
> > > the
> > > > > > > window
owned
> by
> > > the
> > > > > > > window.
> > > > > > > > > The
> IWorkbenchPart
> > > > > should
> > > > > > > > > register
> the
> > > > part.
> > > > > > > This
> > > > > > > > > can
> convenience,
> > > the
> > > > > > > standard
> wrote
> > in
> > > > > > message
> > > > > > > > > > > All,
> > > > api
> > > > > to
> > > > > > > > > > register
> > > > > > > > > > > my action for the
> same
> > to
> > > > > work
> > > > > > > for
> > > > > > > > > tool
> > > > > > > > > > > bar icons.
> > > provided
> > > > > by
> > > > > > > > > default
> > > > > > > > > > > and the
> based
> > > on
> > > > > the
> > > > > > > > > editor,
> that
buttons.??
> > > > > api
> > > > > > > for
> > > > > > > > > > > Regards,
> > > > > > > > > > > venkat
Re: Clarification needed - Copy menu item and tool bar button - Global Actions [message #123992 is a reply to message #122719] Mon, 08 September 2003 02:38 Go to previous message
Simon,
I found an elegant way to solve this.
Instead of using get/set ImageDescriptor, i modified the MyCopyAction class
as:
MyCopyAction extends Action implements IEditorActionDelegate
public void run()
//Implementation of run
public void setActiveEditor(IAction action, IEditorPart targetEditor)
public void run(IAction action)
run() ;
public void selectionChanged(IAction action, ISelection selection) { }
In this way, i registered the above action class in setGlobalActionHandler
as well as in
plugin.xml
Hope this is the simplest way :)
Please let me know your comments
venkat
news:bj7lmb$ash$1@eclipse.org...
who
> Simon :-)
> > Simon,
> setImageDescriptor?
> > -venkat
MyCopyAction
> to
> hook
> setImageDescriptor
> > > instead?
> > > Simon :-)
> > > > Simon,
> > > > I have a class
> > > > public void run()
so
> > > that
gets
> > > > Am i clear now?
> > > > -venkat
cut/copy/paste
> > > > actions
> > > > > on the toolbar?
> > > > > Simon :-)
> message
> > > > > > Simon,
class?
> > > This
> > > > > way,
> > > > > > i need not create
placed
> > in
> > > > the
> > > > > > tool bar.
> > > > > > -venkat
> works
> > > for
> > > > > > tool
> > > > retarget
> > added
> > > > > these
> > > > > matches
> for
> > > the
> > > > > > copy
> > with
> > > > the
> > > > > > new
> > > > > > > Simon :-)
> > > message
> > registered
> > > > for
> > > > > > > tool
> > > > > > > > bar buttons?
> > > > editors,
> > > > > > > having
> > > > > > > > their own actions
bar
> > > > buttons
> > > > > > can
> > > > > > > > differ. Is this the
> > > > > > > > understanding?
> > > > > > > > -venkat
on
> > the
> > > > > > toolbar
> > > > > > > > > Simon :-)
wrote
> in
> > > > > message
> > simple,
for
> > tool
> > > > bar
> > > > > > > > > buttons?
> the
> > > > tool
> > > > > > bar.
> > > > > > > > Why
> > > > > > > > > > -venkat
> > > > > > > > > > > states this:
> > line
> > > > > > > managers.
> > > private
> > > > > set
> > > > > > of
> > > > > > > > > > action
> status
> > > > line,
> > > > > > > > appears
> > > > > > > > > > in
> > > editor.
> > > > > The
> > > > > > > view
> > > > > > > > > may
> add
> > > new
> > > > > > > actions
> > > > > > > > to
> > > > > > > > > > the
> > > > > > > > > > > action bars.
> are
> > > > > > applicable
> > > > > > > > to
> > > > > > > > > > all
> These
> > > > > > actions,
> > > > > > > > > known
> > > > > > > > > > as
> window
> > by
> > > > the
> > > > > > > > window
> owned
> > by
> > > > the
> > > > > > > > window.
> > > > > > > > > > The
> > IWorkbenchPart
> > > > > > should
> > > > > > > > > > register
by
> > the
> > > > > part.
> > > > > > > > This
> > > > > > > > > > can
> > convenience,
> > > > the
> > > > > > > > standard
> > wrote
> > > in
> > > > > > > message
> > > > > > > > > > > > All,
> > > > > api
> > > > > > to
> > > > > > > > > > > register
> > > > > > > > > > > > my action for the
> > same
> > > to
> > > > > > work
> > > > > > > > for
> > > > > > > > > > tool
> > > > > > > > > > > > bar icons.
be
> > > > provided
> > > > > > by
> > > > > > > > > > default
> > > > > > > > > > > > and the
> > based
> > > > on
> > > > > > the
> > > > > > > > > > editor,
> > that
> buttons.??
> > > > > > api
> > > > > > > > for
> > > > > > > > > > > > Regards,
> > > > > > > > > > > > venkat
Previous Topic:Running security tests, LoginContext
Next Topic:How to find the selection of an action
Current Time: Fri Nov 14 23:22:49 EST 2025
Powered by FUDForum. Page generated in 0.07013 seconds
