Home » Archived » Test and Performance Tools Platform (TPTP) » Recording Preference Dialog events
Recording Preference Dialog events [message #116432] Mon, 29 October 2007 05:33 Go to next message
Hi All,
In my prefernce dialog i am having some right-click menus to add and
remove items in the tree viewer(like Run configuration dialog). Now i am
trying to record all the user actions(using add and remove menus) using
AGR. I am not facing any problem at the time of recording, But while
running the test suite i am getting error messages.
Actually i am getting error message when right-click menus are used.
Please help me?
Pushparaj
Re: Recording Preference Dialog events [message #116449 is a reply to message #116432] Mon, 29 October 2007 06:22 Go to previous messageGo to next message
I am getting the following error while running the test suite
org.eclipse.core.runtime.CoreException
Line 15: Cannot locate menu item: {{New}}-{{1.0}}
org.eclipse.core.runtime.CoreException: Line 15: Cannot locate menu item:
{{New}}-{{1.0}}
at
org.eclipse.tptp.test.auto.gui.internal.AutoGUIUtil.throwCor eException(AutoGUIUtil.java:616)
at
org.eclipse.tptp.test.auto.gui.internal.AutoGUIUtil.throwCor eException(AutoGUIUtil.java:608)
at
org.eclipse.tptp.test.auto.gui.internal.macro.MacroObjectLoc ator.locatePopupMenuItem(MacroObjectLocator.java:432)
at
org.eclipse.tptp.test.auto.gui.internal.macro.MacroObjectLoc ator.locateCommandTarget(MacroObjectLocator.java:92)
at
org.eclipse.tptp.test.auto.gui.internal.commands.BooleanSele ctionCommand.playback(BooleanSelectionCommand.java:258)
at
org.eclipse.tptp.test.auto.gui.internal.commands.MacroComman dShell$4.run(MacroCommandShell.java:1160)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:3 5)
at
org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:123)
Pushparaj
Re: Recording Preference Dialog events [message #117305 is a reply to message #116449] Tue, 06 November 2007 07:48 Go to previous messageGo to next message
Hi Pushparaj,
The AGR cannot locate the correct menu item. For more
information on the solution, see the Widget Resolving Mechanism section in
the AGR documentation:
http://www.eclipse.org/tptp/test/documents/userguides/Intro- Auto-GUI-4-4-0.html#2.4
Paul
"Pushparaj" <pushparaj_94@yahoo.com> wrote in message
news:fda27fbfd867e49469a82d74972fd3c7$1@www.eclipse.org...
> {{New}}-{{1.0}}
> at
> at
> at
> at
> at
> at
> at
> Pushparaj
Re: Recording Preference Dialog events [message #118576 is a reply to message #117305] Mon, 26 November 2007 03:16 Go to previous messageGo to next message
Hi Paul,
I am using org.eclipse.swi.widgets.MenuItem in my code,
So i insert following lines in widgetReg.xml,
<class name = "org.eclipse.swt.widgets.MenuItem" matchThreshold = "0.6">
<method name = "getDescription" weight = "0.6"/>
<method name = "getID" weight = "0.6"/>
</class>
But still i am facing the same problem.
Pushparaj
Re: Recording Preference Dialog events [message #118582 is a reply to message #118576] Mon, 26 November 2007 07:21 Go to previous messageGo to next message
The description/ID of the menu must be different than what is in the
recorded macro. Record a new test with that menu and compare the
description/ID.
Paul
news:52c2cac809a7f17489ddd5d2b68b9949$1@www.eclipse.org...
> Hi Paul,
> </class>
> Pushparaj
Re: Recording Preference Dialog events [message #118609 is a reply to message #118582] Mon, 26 November 2007 07:29 Go to previous messageGo to next message
Hi Paul,
I recorded the new test. But still i am facing the same problem.
Pushparaj
Re: Recording Preference Dialog events [message #118719 is a reply to message #118609] Wed, 28 November 2007 06:52 Go to previous messageGo to next message
Make sure the ID of the widget is unique in your code.
PS
news:d99c1b1ca8a4f17c076aefb5cf73db34$1@www.eclipse.org...
> Hi Paul,
> Pushparaj
Re: Recording Preference Dialog events [message #118897 is a reply to message #118719] Mon, 03 December 2007 06:41 Go to previous messageGo to next message
Hi Paul,
How/Where can i set the ID for my widget?
Pushparaj.
Re: Recording Preference Dialog events [message #118988 is a reply to message #118897] Tue, 04 December 2007 06:39 Go to previous message
Add a method called getId() to your widget and add that megthod to your
widget resolver:
news:ee7f42bda50d67ee3665d5b600864c3c$1@www.eclipse.org...
> Hi Paul,
> Pushparaj.
Previous Topic:FileTransferAgent - strange behaviour
Next Topic:proxy recorder _not_ listening to port1080
Current Time: Thu Nov 06 01:53:02 EST 2025
Powered by FUDForum. Page generated in 0.05714 seconds
