Home » Archived » BIRT » Localize drill through tooltip text
Localize drill through tooltip text [message #757517] Fri, 18 November 2011 12:55 Go to next message
When building a drill-through type hyperlink in designer, on step 6, we can enter a tooltip text wich will be displayed on hyperlink mouseover. I wonder if there is a way to localize this text? Usually in birt designer we can select a key for these kind of labels but not here. Please do someone know a way to localize this text?
thanks !
Re: Localize drill through tooltip text [message #757838 is a reply to message #757517] Fri, 18 November 2011 17:14 Go to previous messageGo to next message
Why not just remove the tooltip and use an oncreate script for the data
item like:
this.helpText = reportContext.getMessage("text1",
reportContext.getLocale());
Jason
On 11/18/2011 12:55 PM, dpardon wrote:
> thanks !
Re: Localize drill through tooltip text [message #758212 is a reply to message #757838] Tue, 22 November 2011 06:02 Go to previous messageGo to next message
it perfectly works, thanks!
Re: Localize drill through tooltip text [message #956273 is a reply to message #757517] Wed, 24 October 2012 07:28 Go to previous messageGo to next message
Thanks Smile ... just what i needed Smile
Re: Localize drill through tooltip text [message #1163981 is a reply to message #757838] Thu, 31 October 2013 06:55 Go to previous messageGo to next message
Jason Weathersby wrote on Fri, 18 November 2011 17:14
item like:
Jason
is there similar way to localize report title ?
Re: Localize drill through tooltip text [message #1163997 is a reply to message #1163981] Thu, 31 October 2013 07:10 Go to previous messageGo to next message
Ingoos Ficher wrote on Thu, 31 October 2013 06:55
This is not necessary for report titles: In Eclipse designer, select the root of the report -> properties tab -> advanced
At the end of advanced properties we have a "Title key" where we can set a localization key.
Re: Localize drill through tooltip text [message #1164025 is a reply to message #1163997] Thu, 31 October 2013 07:32 Go to previous message
I'm using birt 2.5.2, and that is not working Sad
Previous Topic:JDBC Connection via IPV6
Next Topic:Dynamic data source based on parameter
Current Time: Fri Sep 19 11:55:12 EDT 2025
Powered by FUDForum. Page generated in 0.05167 seconds
