Home » Language IDEs » ServerTools (WTP) » Jboss 4.0.2
Jboss 4.0.2 [message #115069] Fri, 01 July 2005 09:58 Go to next message
Christopher solution for jboss4.0.1 is still working in the new M5 WTP?
J
Re: Jboss 4.0.2 [message #115234 is a reply to message #115069] Fri, 01 July 2005 11:42 Go to previous messageGo to next message
I got it to working, just need to remove the isLibrary attribute from the
serverdef file for jboss 4.
Re: Jboss 4.0.2 [message #116072 is a reply to message #115069] Mon, 04 July 2005 18:27 Go to previous messageGo to next message
Originally posted by: rdenis.ad.skynet.be
Seems to me a good idea to integrate it to wtp before 0.7 final version.
It would be somewhat strange to have Geronimo 1.0M3 support and not
JBoss 4.x... what do you think?
> J
Re: Jboss 4.0.2 [message #116298 is a reply to message #116072] Tue, 05 July 2005 09:54 Go to previous messageGo to next message
You are right, it should be, I was hoping that it will be included in M5
build. Is there a way to get it before this weekend release ?
Re: Jboss 4.0.2 [message #123701 is a reply to message #115069] Wed, 20 July 2005 16:53 Go to previous message
Salut !!!
> J
nope, for me it does not work. Whenever
i start a selfmade server (copied from default)
the server starts with a correct MK-kernel
message in the log, that the container was
successfully startet.
Some secs later an Eclipse popup-window is telling me,
that the server-start was not successful ????!!???
Indeed, on the system no java-process, running an
container is active.
Does somebody has the same problem?
I am running the system unter Linux (Suse9.3).
Thanks for any help
Christian
Previous Topic:Generic Server set up with only "Run" option
Next Topic:XML Catalog and plugin.xml
Current Time: Sat Jul 19 13:48:09 EDT 2025
Powered by FUDForum. Page generated in 0.04499 seconds
