installation [message #1156375] |
Sat, 26 October 2013 10:06  |
I'd like to discovered Eclipse but I didn't manage to install it.
I follow this documentation
https://wiki.eclipse.org/Eclipse/Installation
but once I launch eclipse.exe I've this error
A JDE or JDK must be avaible to run Eclipse. No JVM was found after searching the following location : c:\program files (x86)\eclipse\jre\bin\javaw.exe
javaw.exe in your current path.
I'd like to say to Eclipse : that's normal, my JRE is at that path :
C:\Program Files (x86)\Java\jre7
what's the solution ?
I downloaded the "Eclipse Standard 4.3.1" & I'm on Win7
thank you
Re: installation [message #1162010 is a reply to message #1161845] |
Wed, 30 October 2013 01:13   |
On 10/29/2013 08:39 PM, robert rios wrote:
> Hello Russell,
> I don't know what info. you are needing but I am having the same problem
> i'm running windows 7 64 bit I downloaded the standard eclipse to my
> desktop and I downloaded jre-7u45 to desktop and jdk7u45 to desktop.
> But when I try to run eclipse.exe from desktop folder I get this message:
> avaliable to run Eclipce. No JVM was found after searching the following
> locations c:\users\robert\desktop\eclipse\jre\bin\java.exe
> java.exe in your current path
> What is weird when I search for eclipse on my c drive and hit the
> eclipse.exe the programs loads but not from my desktop?
> I read your response to the post but can you please explain the answer
> in steps I don't know exactly what I should do when you said something
> about putting -vm before the two lines statement where and how do I do
> that....thanks
There used to be a simple, useful page in eclipsipedia, but it's now
gone. This page explained, for three platforms, how to specify where
your JRE is in the file eclipse.ini. Unfortunately I overlooked that I
had not mentioned the name of that file in my response. Usually, I just
posted the link for the answer.
I guess Eclipse no longer wants us to touch eclipse.ini. Too bad there's
not doc on why. Still, it works. As an example, here's my own
eclipse.ini (but it's for Linux):
-startup
plugins/org.eclipse.equinox.launcher_1.3.0.v20130327-1440.jar
--launcher.library
plugins/org.eclipse.equinox.launcher.gtk.linux.x86_64_1.1.200.v20130521-0416
-product
org.eclipse.epp.package.jee.product
--launcher.defaultAction
openFile
-showsplash
org.eclipse.platform
--launcher.XXMaxPermSize
256m
openFile
--launcher.appendVmargs
-vm
/home/russ/dev/jdk1.7.0_25/bin/java
-vmargs
-Dosgi.requiredJavaVersion=1.6
-XX:MaxPermSize=256m
-Xms40m
-Xmx512m
Re: installation [message #1163025 is a reply to message #1156375] |
Wed, 30 October 2013 15:47  |
YOu have a 64-bit OS and what I'm guessing is a 64-bit Eclipse download, but only a 32-bit Java installation. The simplest thing to do is to get the corresponding 32-bit Eclipse download and use that.
FUDForum. Page generated in 0.09185 seconds
