Home » Eclipse Projects » Remote Application Platform (RAP) » qooxdoo 0.7.4
qooxdoo 0.7.4 [message #116201] Thu, 18 December 2008 15:02 Go to next message
i just read "qx-0.7.4 is also in the 1.1 SR branch".
What does that mean exactly?
Will the RAP-Team release a new 1.1.1 SR1 Version based on qx 0.7.4?
If so, this would be very much appreciated as we run a RAP Application on
the 1.1 Release and can't change to 1.2 Milestones yet because of IE 6.
Andrej
Re: qooxdoo 0.7.4 [message #116275 is a reply to message #116201] Fri, 19 December 2008 05:17 Go to previous messageGo to next message
Andrej,
as RAP takes part in the Ganymede coordinated release, there will be
an SR2 build. For details please see here:
http://www.eclipse.org/projects/project_summary.php?projecti d=rt.rap
or here:
http://wiki.eclipse.org/Ganymede#Coordinated_Service_Release s
Why does IE6 prevents you from changing to 1.2?
HTH
Rüdiger
adiinfo wrote:
> Hi
> on the 1.1 Release and can't change to 1.2 Milestones yet because of IE 6.
> Thanks
> Andrej
Re: qooxdoo 0.7.4 [message #116314 is a reply to message #116275] Fri, 19 December 2008 06:08 Go to previous messageGo to next message
Hi Rüdiger
i tried our application with RAP 1.2 M2 (actually running with 1.1.1 SR1)
and it worked with any browser except with IE 6. I just got a blank screen
in IE 6, that's all.
And as your RAP 1.2 plan states that you support in RAP 1.2 only IE 7 and
later, i thought it was intentionally so that i got a blank screen when
starting my RAP Application with IE 6.
Does your question imply that RAP 1.2 should work with IE6, even if it's
not supported?
If so, i would like very much to switch to the 1.2 version.
I suspected that IE 6 did not work because of your newly introduced
Javascript compression.
Andrej
Re: qooxdoo 0.7.4 [message #116324 is a reply to message #116314] Fri, 19 December 2008 07:31 Go to previous message
Andrej,
though I think IE6 isn't a good choice for performance reasons, RAP
1.2 should work on IE6.
If you can reproduce the IE6 blank screen, feel free to file a bugzilla.
Rüdiger
adiinfo wrote:
> Hi Rüdiger
> SR1) and it worked with any browser except with IE 6. I just got a blank
> screen in IE 6, that's all.
> and later, i thought it was intentionally so that i got a blank screen
> when starting my RAP Application with IE 6.
> not supported?
> Thanks
> Andrej
Previous Topic:How to change the color of toolbar?
Next Topic:illegal character browser error when RAP application run on Tomcat
Current Time: Wed Jul 30 19:20:08 EDT 2025
Powered by FUDForum. Page generated in 0.06109 seconds
